Old 11-04-2012, 11:21 AM   #1
Muug OP
Muug
Oddometer: 40
KTM 950 : TPS = important or not ?
Hi,
I own a KTM 950, year 2005. The last ones with carbs. Now I was giving the bike a maintenance (adjusting valves etc , the lot, you know) and suddenly some blue cable was loose. This is the picture :
It belongs to the TPS-sensor, which is fixed to the side of the front carb. Now, I'm running this bike without SAS and EPC and I would like to know if I should repair this cable or not ? Is the TPS signal used by the ECU ?
Thanks for your advice,
Paul
Muug is offline   Reply With Quote
Old 11-04-2012, 12:59 PM   #2
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,000
I would yes. The TPS helps the ECU determine ignition advance.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 11-04-2012, 02:23 PM   #3
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,121
The ignition retards the timing at low RPM and advances it after 2500 rpm*, or so. The TPS is removed on my bike because I have FCR carbs. It still runs like wild, just a bit harder to start and rougher low RPM feeling.
It would benefit the runability to have it hooked up!
*old research and can''t be precise with the number
snowhawk jockey is offline   Reply With Quote
Old 11-04-2012, 10:09 PM   #4
groovyspuds
groovyspuds's Avatar
Oddometer: 48
C'mon, we all know how important the TPS reports are.
groovyspuds is offline   Reply With Quote
Old 11-05-2012, 12:32 AM   #5
MORT666
MORT666's Avatar
Oddometer: 214
Its throttle position censer.Cold start & idle.
MORT666 is offline   Reply With Quote
Old 11-05-2012, 04:23 AM   #6
Muug OP
Muug
Oddometer: 40
I sense some irony here ? (I hope)
Old 11-05-2012, 07:41 AM   #7
SS in Vzla.
Totally Normal? I'm not!
Oddometer: 1,197
No irony. If you are running the stock carbs, the TPS is important. If I where you, I'd fix it.
SS. '98 BMW F650 / '06 WR250F / '07 KTM 990 Adv
Caracas, Venezuela
SS in Vzla. is offline   Reply With Quote
Old 11-05-2012, 12:52 PM   #8
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,121
Muug,
Its a spot of tin away from happiness! Disassemble the plug and get out the metal probe with broken connection, solder the wire back onto the probe, stick the probe back into the plug, and connect it to harness again.
Times are GMT -7.   It's 10:51 PM.
