Old 11-06-2012, 05:50 PM   #31
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,961
I see a big problem riding a bike with linked brakes when the ABS is not working. If you brake with the front hard enough to break the rear loose, You can't get control of the back wheel without letting up on the brakes, you may not have the option to do so.
bemiiten is offline   Reply With Quote
Old 11-06-2012, 05:58 PM   #32
MJS
MJS's Avatar
Oddometer: 1,905
Originally Posted by JimVonBaden View Post
So changing the module fixed your odometer and speedometer?
Sorry, I don't get that at all. They are not related. The usual fix for that is a rear speed sensor. This is often caused by crud on the sensor, or a damaged sensor.
Jim
On the servo bikes (and likely the later ones also), the ABS module is responsible for transmitting the speed sensor signal onto the data bus. If you look at the wiring diagram you'll see the speed sensors are connected to the ABS module. Only connection between the ABS unit and the Kombi and ZFE is the data bus.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 11-06-2012, 06:15 PM   #33
JimVonBaden
"Cool" Aid!
Oddometer: 53,266
Interesting that the servo unit can be removed and you still have speedo and odometer then.
Jim
Old 11-06-2012, 06:50 PM   #34
Wallowa
Oddometer: 5,444
Happens..There Is Still Control
What you describe happens often where I ride..since I ride almost 100% dirt, a lot is down hill with weight forward and rear light...you still need the front brake and learn to feather in the rear as you apply the front...no big deal, just a touch you learn...remember the linked brakes, which I love, are 70% front and 30% rear when you apply only the front brake [which I always cover while riding], but you can feed in more rear sooner to keep it planted. ABS can be a life saver on pavement...but many of us rode bikes before ABS and learned to ride and stop without it...admittedly sometimes fear and inexperience could result in bad things happening when panic braking...but the front usually was tucked under and ther rear was not the biggest problem..
Just my experience...
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 11-06-2012, 06:52 PM   #35
MJS
MJS's Avatar
Oddometer: 1,905
On my 05 I had to reroute the rear speed sensor wires to the ZFE and have the bike reprogrammed.
I think some others have piped around the servo but left the servo module in place. As long as the servo is still connected and doesn't have an electronic fault in it's processor (unlikely IMO) the speedo would still work. Not really sure about the newer non-servo bikes though.
Old 06-12-2014, 01:06 PM   #36
Clayton Bigsby
Ready
Clayton Bigsby's Avatar
Oddometer: 647
On my 2006, this error was caused by a sticking brake switch behind the front brake lever. A quick shot of wd40 fixed the problem. Whew.
Clayton Bigsby is offline   Reply With Quote
Old 06-13-2014, 12:54 AM   #37
Hawaiidc
Hawaiidc's Avatar
Oddometer: 4
I too think I have this problem. Just bought 07 GS with 28k and the brake failure light is on constantly and it never flashes. Took it in the dirt and no abs when I locked up the brakes. Can't seem to get any results when using abs button and I have not checked wiring. Could abs sensor in wheels shut down whole system?
My question is: how do I tell which abs system I have? I ask this because there is a video on how to repair the abs motor. Doesn't look too bad.
Also if the motor works will a brake flush/bleed be easy or will I need a vac pump/syringe? I have bled brakes before,just not abs.
Sent from my XT1080 using Tapatalk
Hawaiidc is offline   Reply With Quote
Old 06-13-2014, 09:25 AM   #38
gwally99
Oddometer: 28
MM did a great job on my ABS unit
For what it's worth, when my 07 GS ABS unit went bad, Module Masters repaired my unit for a few hundred dollars compared to $2K+ from BMW. Would use them again but hope never have to.
gwally99 is offline   Reply With Quote
Old 06-13-2014, 11:08 AM   #39
Swinefahrt
RooteR
Swinefahrt's Avatar
Oddometer: 588
Your '07 doesn't have servos.
'07 GS
If its got tits or wheels, it'll give you problems!
Swinefahrt is offline   Reply With Quote
Old 06-13-2014, 11:13 AM   #40
Hawaiidc
Hawaiidc's Avatar
Oddometer: 4
Thanks Swinefhart. I may be attempting the motor repair in the near future.
Old 06-13-2014, 02:03 PM   #41
Beemerlover
Oddometer: 334
Question
I thought that all ABS units employed servo-driven hydraulic valves. Guess ya learn something new every day!
I'm puzzled over how an ABS system could work without them, though.
Beemerlover is offline   Reply With Quote
Old 06-14-2014, 08:59 PM   #42
JimVonBaden
"Cool" Aid!
Oddometer: 53,266
They all have servos, but the 07+ has no servo-assist, which is what is generally meant by servo-ABS.
Old 07-05-2014, 12:42 PM   #43
Desperatedan
Oddometer: 1
Am I right in thinking On 2007 non servo assist ABS systems. You should hear the pump running for a few seconds after turning on the ignition?
If it don't and all wiring is ok, is it likely to be the motor brushes seized?
Desperatedan is offline   Reply With Quote
Old 07-05-2014, 02:37 PM   #44
JimVonBaden
"Cool" Aid!
Oddometer: 53,266
Typically you hear nothing on the 2007+ except the fuel pump and the stepper motors on the throttle bodies.
Times are GMT -7.   It's 01:01 AM.
