11-02-2012, 07:19 AM
#16 |
Ride that nasty thing
Oddometer: 1,425
On occasion mine develops this issue, it is my sign to clean the oil jet. Works everytime. But that's just mine.
"04" 950 Adventure S 34,000+ miles Smokin Hole Rally 1,2,3,4,5,6...upcoming 7 Cromag 05, 08. "The Grim Brothers" Where's my 690 rally replica |
11-02-2012, 04:40 PM
#17 |
Oddometer: 15
Yep, same here. Clean the clutch jet out and make sure the clutch pack is assembled as it says in the LC8 manual. I had given my clutch pack some heavy work on a 2 day rally in Wales a few months ago. In the end I had to refinish the steelplates as they had been over heated but none were warped and the fibre plates were still in spec.
You definately need to keep on top of it to get the best performance. |
11-07-2012, 04:41 AM
#18 |
Oddometer: 76
I have done the oil jet(totally blocked) its now clean with a hole through. and the clutch is in order now, there was one steel plate out of order...
And its working! So simple to fix, so much pease in mind. |
11-08-2012, 06:44 AM
#19 |
Oddometer: 243
When you say one steel plate out of order, what do you mean?
I am having clutch/creeping issues. Just trying to learn as much as possible. |
11-08-2012, 11:03 AM
#20 | |
Miles of Smiles
Oddometer: 665
In other words, read the thread, completely, and all will be revealed. ![]()
13 TRIUMPH TIGER 800XC . . the new kitty in the litterbox 04 KTM 950 Adventure . . . . Farkelization Completed - soon to be up for adoption 00 SUZUKI DRZ-400E. . . . . . DS Plated |
11-08-2012, 11:45 AM
#21 |
Oddometer: 76
11-08-2012, 10:33 PM
#22 |
MotorcycleMayhem
Oddometer: 2,158
if the clutch pack is not below the minium stack height, then I would inspect all the plates. If the steel plates are not overheated and warped, then I have had very good success with the following:
1. round up a piece of plate glass, 12x12 inch or slightly bigger, tempered would be best. 2. spray contact cement 3. full sheet of 400 wet dry sand paper. glue the paper to the glass lightly sand the friction surfaces of steel plates while flushing the paper with fluid of choice (I use this setup in the solvent tank). Sand each side of the plates until there are no shiny spots. Now do the same to the friction plates (LIGHTLY!) to remove most of the burnished effect on the surface of the friction plates. Flush well with solvent, blow clean/dry, cover all plates with oil and reassemble clutch. will be butter smooth
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
11-09-2012, 02:21 AM
#23 |
Oddometer: 143
me too
my 04 950ADV has started doing exactly the same thing. As soon as it warms up it disappears. I'll change the clutch push rod for a later model one as the 03 & 04 ones have an alloy multi-piece one which can compress slightly as it wears causing issues. It's a simple straight swap.
Nick (wantok) |
11-10-2012, 04:40 AM
#24 | |
Gnarly!
Oddometer: 1,017
When funds come available the Beastie will get a Rekluse
"Over the Mountains Of the Moon, Down the Valley of the Shadow, Ride, boldly ride," The shade replied- "If you seek for Eldorado!" E.A.P. 1849 04 KTM 950 ADV ~ "BEASTIE", '08 KTM 450 XCF-W, '95 KTM 300 EXC |
11-11-2012, 08:00 PM
#25 |
Oddometer: 594
I was doing the same thing for that problem. But sometimes when riding with others I didn't have time to wait.After stalling and almost falling down I decided to do something about it. I found the inner steel plate had a ring worn in it and replaced it. I also cleaned the oil jet and put on an Oberon slave cylinder. I'm not sure what did the trick, but it now works smoothly and will shift into neutral easily.I used 5w BelRay fork oil in the clutch master cylinder.
I prefer a short life with width to a narrow one with length-Avicenna http://www.advrider.com/forums/showthread.php?t=810149 Ouray Adv http://www.advrider.com/forums/showthread.php?t=800723 Cortez & Moab Didn't Global Warming start at the end of the last Ice Age? |
