Old 11-07-2012, 11:15 AM   #586
Zebedee
Zebedee's Avatar
Oddometer: 823
Originally Posted by rudolf35 View Post
That is the one, thank you for the link and information.
The PO has already installed the H4 so there should be no interference issue. As to the nail, I got a hint from a BMW Indy to heat the nail part until the plastic is hot and with pliers pull out the nail part. Then after shaping the head part of the nail using heat reinsert it into the plastic.
Why not go the whole nine yards and fit a keyless ignition system ... $0.10
No endorsement, just as a "for example", 'cos I know that there are other systems available.
http://www.digitalguarddawg.com/keyless.html
John
The perverse must persevere
Zebedee is offline   Reply With Quote
Old 11-13-2012, 02:22 PM   #587
toshibasz
Oddometer: 43
Originally Posted by DoktorT View Post
Points for /5 through 78/7 are one off.
sorry..but those Bosch 6 volt coils for VW beetle are not the same as those for airhead? Whats the difference? If not, what are other options for i-coils?
(a little late with my reply / question...sorry)
the passion to keep fly...thats the best life cause the motorcycle...-moon92
toshibasz is offline   Reply With Quote
Old 11-13-2012, 10:31 PM   #588
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,157
The bosch coils are the same for VWs, but there were different ones - just make sure they've got the same resistance.
Old 11-23-2012, 01:24 PM   #589
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,506
If I'm not mistaken the VW coils are slightly larger in diameter.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 11-23-2012, 02:53 PM   #590
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,626
Yep, larger in diameter and a bit longer too. The stock mounting brackets will work, but you might have to bend them in a bit so the coil doesn't rub on the tank.
I was was riding in the hills last week and a damn goat came and knocked me off my bike. There behooves all up in my face and shit...
Big Bamboo is online now   Reply With Quote
Old 12-05-2012, 04:03 PM   #591
newride
newride's Avatar
Oddometer: 704
Can anyone recommend cheaper alternatives to mufflers (other than the very expensive BMW ones) for an airhead?
1975 BMW R90/6
My moto blog: http://jbloggie1.blogspot.com/
newride is offline   Reply With Quote
Old 12-05-2012, 04:09 PM   #592
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,626
JCWhitney has Emgos for reasonable prices: http://www.jcwhitney.com/chrome-plat...?filterid=u0j3
Old 12-05-2012, 04:11 PM   #593
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,517
Emgo, Sito, ebay...amongst others.
boxerboy81 is offline   Reply With Quote
Old 12-05-2012, 04:21 PM   #594
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,517
"Not available for export and have been removed from the cart"!
Old 12-05-2012, 04:25 PM   #595
Zebedee
Zebedee's Avatar
Oddometer: 823
What about some home grown Staintune pipes?
Old 12-05-2012, 04:32 PM   #596
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,517
Got 'em already, but looking for some cheap backup, especially if they're "real cheap:! The %OZ very good atm so trying to take advantage.
Old 12-05-2012, 10:42 PM   #597
Beemerboff
Oddometer: 2,322
If you are not fussy about originality there are good quality replicas of the Norton peashooters and Dunstall Decibels, etc, around - Flatracer in England or Trojan Classics in Oz usually have them.
Some of the classic guys stateside have them too, at a considerably higher price.
I have a Decibel with a Overland 2 in 1 system on my R75/7 and it fitted straight on to the OEM bracket.
It has a long straight taper like a Hoske, has better than OEM chrome, sounds better than OEM and flows a bit better too - the stock muffler struggled to cope with the flow from a 2 in 1 but the decibel copes fine.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 01-03-2013, 07:29 PM   #598
Humboldt Airhead
Oddometer: 86
wheel bearing shims
Anyone have a good source for wheel bearing shims for a 74 R90/6 front?
Thanks!!
Humboldt Airhead is offline   Reply With Quote
Old 01-03-2013, 07:45 PM   #599
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,626
Thanks!!
Duane Ausherman is still selling them, but no front /6?: How to obtain shims
I can provide shims for either the /2 or /5. The /5 shims fit the /6 & /7 rear and the older R26 and R27 too. Included is a set of 6 and that is enough to do one wheel, in the worst case, and usually two wheels. Print these pages for your instructions. Six shims of various sizes will allow you to shim spacers to within .001," which is more accurate than either the /2 or /5 wedding ring system. The shims are worth about 5 cents each, but the die costs about $900, for each of the two types. A set of six, two of three sizes, of these shims cost $10, postage included. I sell these by the honor system. Email me with your address and I will mail them out to you with a SASE. It is up to you to insert payment and return. If you don't know how to use them, or don't like them, just return them in the SASE. Less book work for me means a cheaper price to you, so please honor this simple system. Thanks.
The kit has six shims, two shims of three sizes from .002" to about .005". This allows adding length to the inside spacer from .002" up to .020", in increments of .001". That is double the accuracy of changing the /5 wedding bands and four times for the /2.
Sometimes the shims are cut from metric sized shim material and sometimes American sized, but you still get a useful variety. You may get shims of 2,3 and 4 and sometimes 2, 3 and 5 thou. It matters none at all, because you will have what is needed to get a great variety.
I changed my email address in late 2006, but forgot to change it here. Many riders have not been able to order shim kits. I apologize and hope that you will try again.
Old 01-19-2013, 07:37 AM   #600
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,929
WTB: USA "high" bars for R75/5
Mine are pitted and rusty but solid. I just can't bring myself to reuse them so I need to replace them. Let me know if you have a set, thanks!
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Times are GMT -7.   It's 12:55 AM.
