Old 11-07-2012, 11:53 AM   #61
crofrog
Oddometer: 1,455
Originally Posted by snowhawk jockey View Post
The aerodynamics are always my excuse for why the back tire just spins up(on dirt) and the bike doesn't gain KPH on the speedo, above the "terminal velocity" of our coefficient of drag.
That's a fun feeling. When you just hit that wall where the tire spins up.
Also at those speeds that's a reasonable ammount of speedometer error. So 218 indicated is not 218 actual.
crofrog is offline   Reply With Quote
Old 11-20-2012, 11:22 PM   #62
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,326
Because the throttle pull was gettting a bit tedious, I put one of these in;
It has brought the pull back to what the standard carbs throttle feels like. Although it is a metal tube, what also contributes to an easier pull, apart from the different cam profiles, is that it looks like it has teflon inserts.
Pricey, but has fixed for me the one last thing that was pretty irritating, especially as I have a slight case of carpal tunnel coming on.
Interestingly I couldn't tell the difference in the amount of rotation the throttle needed. It's not like I have to wind the throttle on and only get half way before I have to grab another handful. It is about less than a 1/3rd of a rotation from 0 - 100%. So all in all, I think a great mod.
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 11-21-2012, 01:02 AM   #63
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,853
i'm been running the G2 quick-turn throttle for near 12mths now with the FCR's & is great.
also am now using just a pull cable.
http://www.g2ergo.com/dirt-bike-g2-e...e-tube-13.html
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 11-21-2012, 01:08 AM   #64
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,326
Yep, sorry, I too have the G2, here's the teflon bit;
Times are GMT -7.   It's 11:04 AM.
