Old 11-06-2012, 03:49 PM   #16
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,226
I like your Airhead, congratulations. Great job on the headers. I'll try to keep that in mind.
And yes, the Lens!!! We've got to find some more.
---Albert Einstein
Old 11-07-2012, 11:56 AM   #17
Rightshiftrick
Rightshiftrick's Avatar
Oddometer: 109
Originally Posted by US_Marshall View Post
Just a crappy cell pic, but it shows the direction I am going. ......
The tank fits OK, I plan on modifying the front are to clear the master cylinder, the back looks like it need little work to fit securely.
Are you getting rid of the stock tank? If so, I'm interested. I've got a '74 R90/6 that I brought back from a similar condition. The 90/6 series makes for a great machine.
Erich
1970 Norton Commando
1974 BMW R90/6
1980 Moto Guzzi v50
1970 BMW R50/5 (project)
Rightshiftrick is offline   Reply With Quote
Old 11-07-2012, 12:03 PM   #18
US_Marshall OP
Oddometer: 44
Erich
Not any time soon, I need to keep it so if the K bike tank fails I still have the stock one to go back to.
US_Marshall is offline   Reply With Quote
Old 11-21-2012, 07:06 PM   #19
US_Marshall OP
Oddometer: 44
Installed my new top brace and clip on's. started trimming the tank to fit down over the frame, still needs to be modified to get lock to clock steering. Rebuilt the carbs and installed some velocity stacks. probably run the stock tank though.
US_Marshall screwed with this post 01-23-2013 at 08:05 PM
Old 11-21-2012, 07:43 PM   #20
Kai Ju
Kai Ju's Avatar
Oddometer: 1,068
Promising start
I've thought about a K bike tank before but had not considered using the front fender on the rear.
I'll be watching this one, so hurry up would you ?
Kai Ju is online now   Reply With Quote
Old 11-21-2012, 09:16 PM   #21
Big Bamboo
Big Bamboo's Avatar
Oddometer: 909
Just a thought, if you turn that fender around and moved the brace, wouldn't the gap fit the shock? I've been thinking about doing that on a Rennsport replica.
"No hour of life is wasted that is spent in the saddle." =Winston Churchill=
Big Bamboo is offline   Reply With Quote
Old 11-21-2012, 10:27 PM   #22
US_Marshall OP
Oddometer: 44
It probably would, it is too narrow for the rear tire though. I had to remove the center brace just so it would sit on top of the tire.
Old 11-21-2012, 11:27 PM   #23
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 362
Digging this. Excited to see where you go with it.
Kt-88 is offline   Reply With Quote
Old 01-23-2013, 08:09 PM   #24
US_Marshall OP
Oddometer: 44
I laced up a wider rim, not to bad but it is just a test fit. I need to order new spokes about 8mm shorter. It looks like the swing arm brace is going to have to be bolted together at the center so I can spread the swing arm to get the tire in.
Old 02-10-2013, 08:14 PM   #25
US_Marshall OP
Oddometer: 44
Head light
I want to install a /5 head light bucket/speedo but the price that people are asking is a tad on the high side. Since my stock bucket is beat I decided to modify it.
I started by beating out the dent and the 2 spots that are for cluster clearance.
I then welded on some tabs to hold a HID projector, it has a shutter inside for High/Lowe beam function.
I used an old ford (1935?) head light bucket to extend it out.
I have a speedo that has an electronic tach inside that I will be mounting on top. I need the big sheers at the shop to trim the ring so that is as far as I made it tonight.
Old 02-10-2013, 08:41 PM   #26
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 362
This is cool.
Old 03-05-2013, 11:37 AM   #27
US_Marshall OP
Oddometer: 44
I screwed up, I didn't account for the cable it'self. The speedo fits in and clears the back of the projector but the cable will not fit. I have started searching for an all electric gauge, looks like harleys have some nice ones that will do the job.
Old 03-05-2013, 03:13 PM   #28
Captdan
Oddometer: 125
I like the look of the speedo inside the headlight... ( could use a/5 set up too?)
Btw, I located a lens like you have. In fact located a pair on eBay and grabbed them both...
1965 Cushman super silver eagle, 1968 BMW R-60/2, 1974 R-90/6 cafe, 2008 R-1200 GSA.
Captdan is offline   Reply With Quote
Old 03-05-2013, 03:24 PM   #29
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,226
CD,
He did want a /5 but didn't like the prices people want for them these days. Understandable, I guess. So far the later model looks good but now there's a problem with the speedo cable or something.
US_Marshall seems to be a very talented builder. So everybody thinks. Maybe he's just lucky? Wish I had one half this sort of talent.
Charlie
---Albert Einstein
Old 03-05-2013, 08:10 PM   #30
US_Marshall OP
Oddometer: 44
Thank you.
Yes I would like a /5 bucket and speedo but they go for more then I have in the whole bike.
I am also looking at getting a head light bucket from a late 30's chevy. They are a long tear droop head light and would give me lots of room on the inside to work with.
Times are GMT -7.   It's 11:54 AM.
