Old 11-06-2012, 07:47 PM   #1816
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 850
Akra Map
'07 990A 22,000+ mi. Remus 2 to 1 CPR air filter O2 sensors on.
Akra map for 07/08 thanks Nils KM601AK0702S01
Throttle bodies balanced, TPS spot on.
So far 42-45 mpg. All rides with long stretches over 80mph and some 100+.
It's been in the mid 50's and colder up on the pass.
The bike runs better than it ever has, with beautiful smooth throttle action.
Now if I could only get my 690 to run this smooth.
Keep After It, Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 11-06-2012, 07:49 PM   #1817
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 850
Originally Posted by kenhaw View Post
Hi Everyone
Been reading most of the posts here, wauv. A lot of work has gone into this.
Have been fidling with a power commander 3 USB but without much luck.
Bought my bike used with the cans but no idea what map is inside the ECU. Have already ordered my cable and cant wait for it to arrive.
Have the same problem as others, stalling and twitchy throttle. The throttle I can live with but the stalling makes me very uncomfortable when riding my bike.
Looking forward to using the TuneEcu and getting in to the discussion
I am in Cannes,France.
Kenneth
Welcome to the OC and good luck with your tuning.
Max
Da oggi la strada
é senza limiti
Old 11-06-2012, 08:24 PM   #1818
Dusty
Dusty's Avatar
Oddometer: 1,036
Keep After It, Max
Hey Max, did you make any changes to the F/L switch or the second throttle plates on that map?
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 11-06-2012, 08:27 PM   #1819
DeepSea
electronically challenged
DeepSea's Avatar
Oddometer: 94
Offroad mileage?
Max, I'm curious what kind of mileage your averaging offroad.
I'm also running the Akra map, with a 2:1 but with O2 off and getting Low 40's.
But that's only while on the highway. Offroad I'm getting closer to high 20's and more typically low 30's.
It's not me. My bike is Narcoleptic.
CDR 2012 ------ Too Lazy/Illiterate to write my own
El burro trabaja doble
DeepSea is offline   Reply With Quote
Old 11-06-2012, 08:31 PM   #1820
Dusty
Dusty's Avatar
Oddometer: 1,036
Hi Everyone
Kenneth
Getting the TPS and throttle cables adjusted properly is important, also a reflash of the map and reset the adaptive values and do the 15 min idle... I bet will do wonders for your bike.
All very easy with TuneECU.
Old 11-07-2012, 12:21 PM   #1821
kenhaw
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 13
Took the bike apart today to remove the pc 3usb.
While I was at it, I removed the airfilter and saw that my sec throttleblades are not there
Sas has been removed too, so the previous owner did a lot of things, wonder if he messed with the mapping too? Time will tell. Still waiting for my cable
Kenneth
kenhaw is offline   Reply With Quote
Old 11-07-2012, 06:20 PM   #1822
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 850
No, I'm not that tech savy. I just used the stock akro map
and tried to get the balance and TPS correct.
Which seems to work well, the bike is headed South for the Winter.
Riding to Tierra Del Fuego.
Max
Da oggi la strada
é senza limiti
Old 11-07-2012, 06:23 PM   #1823
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 850
Kenneth
You'll know what tune is installed when you hook it up to TuneEcu.
Might want to reinstall the 2nd butterflies and start from a known base.
Max
Da oggi la strada
é senza limiti
Old 11-07-2012, 07:52 PM   #1824
Dusty
Dusty's Avatar
Oddometer: 1,036
Max
Right....funny guy.
Safe travels... i bet your getting to know your way around down there on the otherside of the equator.... have fun and don't forget to twist it!
Scott
Old 11-09-2012, 03:18 PM   #1825
nunzo
nunzo
nunzo's Avatar
Oddometer: 260
Oops
Sorry for the note, but please understand that I am computer illiterate.
After loading the drivers and setting things in motion for my 08 990 adv, I read the stock map, saved to my c drive successfully. Here is where I got freaked out...I was watching the Akra map load and right about 96% complete, the headlight turned on and the fuel pump reset? or turned on. I disconnected the cable and then tried to fire up the bike to finish off the loaded map with the 15 minute idle trick.
The bike would not turn over almost sounding like it was a bad battery? Incidentally, I keep the bike on a trickle charge at all times and kept the battery charger on during this session.
Did I mess something up with the map download??
Any help would be appreciated since I sure would like to ride this weekend.
Thank
nunzo is offline   Reply With Quote
Old 11-09-2012, 03:48 PM   #1826
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,545
Thank
Oh man I've never had of that happening.
When downloading a new map I see 100%. I don't remember the ECU resetting. Did you select disconnect from the TuneECU menu before disconnecting the cables and turning off the ignition?
Other than asking the experts here for advice I'd
1) Check my battery to insure it's in good condition and fully changed. How old is it?
2) If battery is good; Pull the fuse on the headlight.
3) Connect TuneECU to the bike
4) Read the map to see what was installed.
5) If map is the one you want then disconnect TuneECU.
6) Turn off ignition
7) Wait for a few seconds and try to restart.
However, it sounds like your battery may have a problem if it doesn't turn the bike over normally.
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 11-09-2012, 08:19 PM   #1827
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,593
Thank
Any error codes thrown up ?
'07 KTM Adv990S
No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire..
950Rally picture thread
Vicks is offline   Reply With Quote
Old 11-10-2012, 05:13 PM   #1828
Imachimper
Newer than Noob
Imachimper's Avatar
Oddometer: 82
Got my cable today from DSW After backing up my current (stock ) setup, I plan on replacing it with a newer R map. Any advice out there for this switch? 2011 2012 ???
2010 990 ADV with stock cans.
Imachimper is offline   Reply With Quote
Old 11-10-2012, 05:19 PM   #1829
nunzo
nunzo
nunzo's Avatar
Oddometer: 260
No error codes after I downloaded the map. I ended up letting the bike charge all night and it fired up this AM. Ran the 15 minute idle trick and then took for it's first ride with the Akro map. All I can say is that I am amazed that I rode by bike for so long with the stock map. YES I AM AN IDIOT!!
The snatchy throttle has been almost eliminated compared to previous map. Definitley a rich mixture that I can smell in the exhaust...no more popping on decel. The 4K RPM rollon has been dramatically improved..no more stumbling. At small throttle openings (2k rpm) there is now a small hesitation, unless you accelerate hard and then you blow through it.
One new thing I noticed after my 65 mile inaugural ride...the bike stalled twice when decelerating (slowing to a stop light)...almost like the rpm's fell off to nil?
I defintiely have to ride the bike differntly with the new map. Overall I am happy it went OK. Next step fine tuning the low rpm hesitation. Any ideas? Throttle Bodies needing synched?
Thanks for the help.
Old 11-10-2012, 06:02 PM   #1830
Sirwrexalot
Sirwrexalot's Avatar
Oddometer: 97
Finally
Just another new guy with a cable BUT Shootis sent me his file which seems to be a hybrid of sorts between the 2011 and the 2007 Stock maps with the butterflies set at no less than 25 and HOLEEE SHEEIT !!!! I love my new bike ...
The new map made my KTM seems like a different machine.. Smoooth., Not as twitchy. My wife even noticed the difference..
Doesnt seem as fast but like I said I would be glad to give up a few ponies for smooth and this is pretty dang nice.
I was at the point of possibly selling the KTM because I really didnt like the way it rode. but NOT NOW. this is how they should all run in my opinion. I only put about 60 miles on it but so far so good.
Thanks to James and everyone else that has been kind enough to share a map and inspire a newbie like me to dig a little deeper to make the 990 even better,
Sirwrexalot is offline   Reply With Quote
Times are GMT -7.   It's 01:57 PM.
