Old 11-07-2012, 10:08 PM   #1
Roughseas OP
Roughseas's Avatar
Oddometer: 63
Help! Just bought a crashed R1200GSA
Just picked up a crashed 2011 R1200GSA for a friend. Bike has done 500kms on the odo and barring the accident damage seems to be in pretty good shape.
The right magnesium cover has disintegrated and the cam holder has slight damage at the edges but does not seem stressed. The front bodywork is totally smashed but that is not my immediate concern as I want to see if the bike cranks first. I've tried turning the engine by rotating the real wheel and the bike in gear and it rotates freely (i think :) ).
Since the lcd has cracked I don't see the error messages showing up when I try to crank the engine with the starter. I had to scavenge the ignition kill and the starter switch from the switch housing in order to try this.
On switching the ignition key on I get the yellow caution sign for a few seconds followed by the red caution sign and then the steady ABS warning sign which stays on. If I press the ignition kill microswitch, all warnings disappear but nothing happens if I press the starter button. Without depressing the kill switch, if I press the starter button, I get a loud knock from the starter motor. I've tried a fully charged battery but same results. BTW side stand switch looks ok and I get a Neutral indication on the dash but after a few tries the neutral light goes away.
The clutch and brake master cylinders are cracked and the brake lever microswitch is missing. Can the lack of oil in the clutch or brake system inhibit the starter motor from engaging?
I've tried cranking the motor with the crankshaft at different positions but all I get is a loud knock from the starter and no movement.
Any pointers anyone? I've ordered a replacement brake master cylinder with the right side switches and a new meter so should at-least get some insight into the alarm messages. Will try purging the clutch today and see if it helps.. What oil goes in there, mineral or brake fluid?
Roughseas screwed with this post 11-09-2012 at 01:59 AM
Roughseas is offline   Reply With Quote
Old 11-07-2012, 10:22 PM   #2
Stinkyb
GS"eh" rider
Stinkyb's Avatar
Oddometer: 355
As far as starting it goes, sounds like the battery is dead.
Starting due to lack of brake/clutch fluid shouldnt have any effect, so long as your in neutral...dont expect to get far
Clutch has microswitch so you cant start engine clutch engaged/ in gear...
Clutch takes magura blood mineral oil NO DOT FLUID
"Dear MCGuyver enclosed is a paperclip an elastic band and a toothpick, please save my dog"
Stinkyb is offline   Reply With Quote
Old 11-07-2012, 10:48 PM   #3
Roughseas OP
Roughseas's Avatar
Oddometer: 63
I have tried it with a fully charged car battery but the starter still doesn't turn. Will give it another shot with proper jump cables, i've been using makeshift cables made out of house wiring since I didn't have anything at hand.
My first guess was the ring antenna but then the starter should not even give the loud knocking sound if that was defective. What about the anti theft alarm (wherever that is)? I am sure that is almost dead as the bike has been standing for about two months.
Old 11-08-2012, 03:08 AM   #4
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Something don't sound right - you say you can rotate the engine via the rear wheel - how easily and in what gear?? Realistically I would expect it to be almost impossible to turn the engine over due to the very high compression.
The knock you hear when the starter button is pressed would I expect be the starter motor teeth engaging the flywheel - but for some reason the starter motor may not be turning over. This would be something in the starter mechanism, maybe wiring within the starter motor, earthing, or corroded contacts or similar. If that is proven to be the problem you would need a r&r of the starter motor.
Or a thoroughly jammed engine, though unlikely if you can turn it over via the rear wheel.
Check that the engine *can* be turned over (best to remove the plugs to do this), otherwise check the starter motor is functioning correctly - to do this properly would it would need to be removed and bench tested
viz
Pig In The City - 2010 BMW R1200 GSA Adventure
Webmaster BMW Touring Club of NSW
viz is offline   Reply With Quote
Old 11-08-2012, 03:28 AM   #5
semaja2
semaja2's Avatar
Oddometer: 241
If you end up scrapping it ill take the rear ESA shock if its still good ;) however seems like you got a handful of fun for the next coming months :)
semaja2 is offline   Reply With Quote
Old 11-08-2012, 09:32 AM   #6
Roughseas OP
Roughseas's Avatar
Oddometer: 63
Bad news for you!
It started! Problem was the bad battery and my home made jump cables. Thanks Stinkyb.
Could not run it for long as the oil was spraying all over but the engine sounds silent and good.
@viz.. it was difficult to turn it over with the rear wheel, I also have a 2001 R1150GS and this was harder to turn compared to that as the engine has hardly been run in.
Old 11-08-2012, 04:12 PM   #7
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Originally Posted by Roughseas View Post
Bad news for you!
OK good. Problem with those "fully charged" batteries - sometimes they're not That loud clunk you heard was prolly the starter motor engagement but did not have enough berries to do the rest. What threw me was that usually you get a chatter from the starter motor and no turn-over with a battery that is flat...
But good that it went
viz
Old 11-08-2012, 04:18 PM   #8
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,533
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 11-08-2012, 04:37 PM   #9
Kingsized
Kingsized Adventurer
Kingsized's Avatar
Oddometer: 773
Originally Posted by Dan Alexander View Post
WURD! I'd like to see this!
Everything's better in retrospect.
My ride through Bourbon county http://advrider.com/forums/showthrea...7#post22154447
Two Wheels Good, a journey out west http://twowheelsgood3.blogspot.com/
Kingsized is offline   Reply With Quote
Old 11-08-2012, 10:42 PM   #10
Roughseas OP
Roughseas's Avatar
Oddometer: 63
Here we go
Enjoy!
Old 11-09-2012, 03:32 AM   #11
jdbalt
Oddometer: 194
Ouch
How about pictures of your friend in the hospital? It all looks repairable.
jdbalt is offline   Reply With Quote
Old 11-09-2012, 03:33 AM   #12
jdbalt
Oddometer: 194
What is the next to last picture?
Looks like instrument cluster and half of the windscreen mount.
Old 11-09-2012, 03:57 AM   #13
GB
Mod Squad
GB's Avatar
Oddometer: 56,561
Can you buy bmw motorcycle parts in India?
Old 11-09-2012, 04:38 AM   #14
Dan Alexander
Oddometer: 7,533
Looks in good shape besides the front ... worth the go I think .. depending of course on how much you've got into it.
Old 11-09-2012, 05:31 AM   #15
Roughseas OP
Roughseas's Avatar
Oddometer: 63
Getting them from motorworks in the UK, they do have dealerships here but they end up taking a couple of months to source the parts.
jdbalt - those are all the bits I took off..beyond repair types
Looks worth the effort as they sell for USD 50k brand new here.
Times are GMT -7.   It's 08:52 PM.
