Old 11-07-2012, 02:06 PM   #1
MikeO OP
Wage slave...
MikeO's Avatar
Oddometer: 7,098
Question New noise from RH Head area - high mileage 1150 ADV...
Hi all,
For the last few days I've noticed a new noise from the RH head area on my 2002 1150 Adv - 160k miles.
I've embedded a couple of videos - simply because I don't have a facility just to record sound. The noise is a high pitched clicking - I'm wondering if it's arcing from the HT lead - although there's no visible sign of that.
Plus the whole thing clanks like a Victorian central heating system, but frankly, I'm used to that...
Any ideas?
Mike :cool:
All text & original photos Mike Oughton 2004 - 2015
MikeO is offline   Reply With Quote
Old 11-07-2012, 02:15 PM   #2
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 5,002
Originally Posted by MikeO View Post
Any ideas?
locknut fallen off valve adjuster? (or just a loose valve)
I'm amazed you can put up with all that racket - Certainly seems like self destruction is imminent but if it's been doing that for a long time already, perhaps not. At 160K miles, it doesn't owe you much anyway.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 11-07-2012, 02:19 PM   #3
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,856
Cam chain tensioner? Sounds like it's flopping around pretty good.
"Experience alone is not the great teacher; Experience has to be multiplied by intelligence to yield sustained progress." Phil Schilling
Deuce is offline   Reply With Quote
Old 11-07-2012, 02:28 PM   #4
MikeO OP
Wage slave...
MikeO's Avatar
Oddometer: 7,098
Sorry - should have mentioned that there has been no roughness, drop in performance or change in fuel consumption. The video was taken at the end of a 250 mile day and the engine was hot, for what it's worth.
It doesn't sound as rough as a nut floating about, it's quite a delicate sound - plus I would expect the tappet in question to adjust itself without a locknut and produce some other symptom - typically performance.
I did the left hand cam chain tensioner mod about three years ago.
Mike
Old 11-07-2012, 04:05 PM   #5
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 1,024
Did you check throttle shaft bushing on that side? Small thing but can be noisy.
Could also be a breaking up cam chain guide. Look in the oil for black plastic crumbs.
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Old 11-07-2012, 05:28 PM   #6
pcwirepro
Aspiring Adventurer
Oddometer: 282
He'll of a coincidence.
I just took video of the same thing. Same problem, same sound, same side. I hear a " delicate" chain type sound like you describe. 2004 1150GS. I figured I would crack it open this weekend and do the valve check and rocker arm end play first. After that I guess it's cam chain tensioner or chain guide. I will be watching your thread and will report anything I find.
pcwirepro is offline   Reply With Quote
Old 11-08-2012, 02:56 AM   #7
beemerboxer
Oddometer: 20
Any chance to share the bikes history? At that mileage it's hard to guess.
However, also due to a clonking noise, I recently pulled apart my 1150 with 70k miles, 1 out of 4 cam chain guides were left. The rest broke off and ended in pieces. Even the tensioner piston, right hand side, was badly worn due to direct contact with the chain.
Mind you the bike was running fine if not for the noise.
I changed the set, as well as he chains but held back on valves, to keep costs down.
Now an inlet valve is bent, discernible by trying to spin it in place but it won't.
I am still waiting for the parts to come and provide an update.
beemerboxer is offline   Reply With Quote
Old 11-08-2012, 07:48 AM   #8
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,198
Sounds like it may be a loose pushrod head. It has shown up on higher mileage engines.
There is a thread on this site that deals with that subject.
http://www.advrider.com/forums/showthread.php?t=215134
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 11-08-2012, 08:33 AM   #9
MikeO OP
Wage slave...
MikeO's Avatar
Oddometer: 7,098
Thanks for all replies.
History:
I have owned the bike from new (Mar 2002). Main dealer serviced for the first two years (up to 42k miles IIRC) - by me thereafter. The heads have not been off the bike. 6k oil changes using dino oil. Cam chain tensioner mod fitted about three years ago.
Mike
Old 11-08-2012, 09:27 AM   #10
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,345
Pull the valve cover and look for debris from a tensioner....hopefully it's not more than that.
If it is tensioner debris, remove what you can and ride on.
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is offline   Reply With Quote
Old 11-08-2012, 09:30 AM   #11
MikeO OP
Wage slave...
MikeO's Avatar
Oddometer: 7,098
Video recorded this morning when the engine was cold...
Old 11-08-2012, 10:08 AM   #12
pcwirepro
Aspiring Adventurer
Oddometer: 282
More vids
So is the knocking normal?
pcwirepro screwed with this post 11-09-2012 at 05:41 AM
Old 11-08-2012, 12:15 PM   #13
slartidbartfast
Oddometer: 5,002
There's a tapping throttle butterfly (worn shaft) but I don't think that's the noise we heard when it was hot
Old 11-08-2012, 12:46 PM   #14
MikeO OP
Wage slave...
MikeO's Avatar
Oddometer: 7,098
Yes, I only noticed how bad that was when I played the video back - you can hardly hear it
I have my original TBs in a drawer - I think I'll have them refurbed over the winter.
It's a lot quieter when it's cold, isn't it?
I'm still thinking in terms of HT arcing, from the type of sound it is...
Old 11-08-2012, 01:46 PM   #15
vagueout
vagueout's Avatar
Oddometer: 1,782
Id be looking for the simple things first up. Suggest a hands on inspection of your crash bars to rule out a crack or break. If a stethoscope is not available improvise with a large and long screwdriver to try and locate where the noise is emanating from. Next , off with the valve cover to see if anything obvious as other posters have suggested, ie missing or loose locknut etc. You mention suspect arcing, makes me think a loose spark plug rocking around in it's hole. Good luck and good hunting.
i just seek clarity
vagueout is offline   Reply With Quote
Times are GMT -7.   It's 05:25 PM.
