11-08-2012, 07:48 PM
#16 |
Oddometer: 396
11-08-2012, 07:54 PM
#17 |
Oddometer: 45
So, I guess with that response 5k isn't that bad even if the engine needs going through. Right now it starts with one or two kicks and the right cylinder has the lowest compression but runs okay. If you've read the above posts I'm sure you'll agree on the rebuild as I do. Having said that, I'm going to sort it out and just ride it after the rebuild.
By the way, the Alfas aren't mine. Thanks for the comments! Steve |
11-08-2012, 08:27 PM
#18 | |
Have you been watching ebay for prices? POS rust bucket /2s are going for 4.5k This is a good deal if that is the bike. That bike is a day of white diamond, steel wool, and wax away from being a really nice rider. If I didn't have 3 /2s and a /3 i would be trying to get it if you didn't.
Shane Bikes in the garage: '09 BMW 1200 GSA "Blü Oni" '03 Honda VTX Bored, chopped, raked, and fat "Hassen " '02 BMW 1150 GSA "Red Wooster" '85 Honda CBR 900 Cafe'd For Sale '83 Suzuki GS450 Bobber "HydroStream" '70 BMW 75/5 Cafe'd "She Devil" '38 BMW R71 Hack Jackie Chan Edition "Slow Boat" |
11-08-2012, 08:38 PM
#19 |
Oddometer: 2,509
note taking compression on airheads requires taking off carb or raising carb slide to up position. better to remove carb. your compression reading will be low if carb is not removed.
that /2 has ADV sticker on it... who did it belong to?
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
11-09-2012, 05:08 AM
#20 |
Horizontally Opposed
Oddometer: 5,287
The ADV sticker is my bike. Just for comparison. I'd not heard that compression should be measured with the carbs off. What's up with that?
11-09-2012, 05:42 AM
#21 |
Oddometer: 5,287
The other side
Another shot of Weeman's new? bike...
![]() Much can be determined by your first fluid change. Inspect the motor oil carefully for shiny bits. Do the same for the tranny. Take a small stick and measure the level of the gear oil in the driveshaft. Drop the rear drive oil and check again for "the brassy sheen". Order the magnetic drain bolts from Benchmark Works. They are very helpful in keeping track of wear and tear. To post pics on this website you need to have them preposted on a photo sharing/storing service like Flickr or something. Better yet, instead of blowing $40 on MOA, blow it on joining SmugMug. The owner of ADV, keeps ADV free for our use, by running the SmugMug operation. You'll then be able to post all the pictures we want to see...
11-09-2012, 05:08 PM
#22 |
Oddometer: 45
Thank you for all your wisdom and info regarding my decision whether or not to bite the bullet to get this bike. I know that there are things to replace but can say that from your reactions it will be a solid purchase.
Steve |
11-10-2012, 04:42 AM
#23 | |
Oddometer: 2,509
if you are new to airheads .. take extra care torquing down bolts that thread into aluminum. which is pretty much all over airheads. when spec's say 7ft lb ... it means it. a 1/4in drive in lb torque wrench is a handy tool to have around. spec's list compression at a low 7.5-1 ... so engine could be just fine if your /2 starts and runs good. pretty safe to say several inmates, including me would be happy to take that /2 home.
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 11-10-2012 at 05:25 AM |
11-10-2012, 07:14 AM
#24 | |
Oddometer: 45
Steve |
11-10-2012, 08:12 AM
#25 |
Wacky Bongo Boy
Man, that looks like a good find. Certainly cleaner than my /2's.. and it runs! Nice.
1974 BMW R75/6, 1974 BMW R90/6, 1969 BMW R60/2 hack, 1929 Ford Model A, Metal casting, Part 2/Part 1 among others.. |
11-10-2012, 08:25 AM
#26 |
Oddometer: 5,287
Tell us about yourself!
Are you mechanically inclined?
What attracts you to that bike? Do you want to ride it or just own it? Have you ever heard of "slingers"?
11-10-2012, 09:04 AM
#27 | |
Oddometer: 45
Steve weeman screwed with this post 11-10-2012 at 09:45 AM |
11-10-2012, 09:11 AM
#28 | |
Oddometer: 45
11-10-2012, 09:32 AM
#29 | |
Oddometer: 5,287
That is such the RIGHT answer!
Nice bike. You'll have fun with that! Keep us posted. Feel free to ask questions. You'll have more answers than Carter has Little Liver Pills...
11-10-2012, 09:49 AM
#30 |
Oddometer: 45
