Old 11-03-2012, 08:49 AM   #1
ShoelessJoe OP
DefromisSedSupendium
ShoelessJoe's Avatar
Oddometer: 131
New clutch slave, now clutch does not work..help
-New Sigutech clutch slave installed, system bled throughly, clutch does not engage
-Checked installation and everything seemed good
-Bled system one more time thoroughly (should have mentioned that I am using 5W fork oil), still not working
-Removed sigutech slave and re-installed OEM with no results
-No leaks visible
Fairly confident that it is not a slave or a bleeding issue at this point. The fork oil is different from what I used prior, but there are plenty of threads on here about using it with no issues.
So what have I screwed up? Where do I go from here? Pull the pressure plate off and look around? Not sure how I could screw something up this easily.
ShoelessJoe is offline   Reply With Quote
Old 11-03-2012, 09:00 AM   #2
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,742
I just replaced the slave piston on my Husky. Does your lever feel good, like it is pressurized and moving the piston? Did you bleed the system by forcing the fluid up from the slave to the master cylinder?
I am using Acura ATF and mine works perfectly, so I don't doubt your fluid choice at all.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 11-03-2012, 09:06 AM   #3
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Wink Ball Bearing
I'm gonna take an educated guess & suggest the ball bearing is missing.
It goes between the clutch push rod and the slave cylinder piston.
Part of #37 in the KTM parts book. it may be (usually is) stuck in the grease of the slave piston, or perhaps on the ground now. Most bikes have them, it's a common thing to overlook.
If not, it's bleeding. SO many customers have brought me bikes "Oh, it's bled perfectly, no air, etc..." when it fact it isn't.
good luck
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 11-03-2012, 09:12 AM   #4
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,374
When I installed the Oberon, the ball, unknowingly fell out. Found it the next day, problem solved.
"The BSC was strong in that one, had to get out !"
dlrides is offline   Reply With Quote
Old 11-03-2012, 09:12 AM   #5
ShoelessJoe OP
Oddometer: 131
Looks like there is a bearing in both slaves. I'll try pushing the fluid up from the bottom and see if that helps.
Old 11-03-2012, 09:13 AM   #6
baloneyskin daddy
bikaholic
Oddometer: 2,085
Not sure I understand what you;re saying. I think you mean the clutch won't disengage as in when the lever is squeezed the bike will stall out when put in gear. Try putting a c-clamp on the slave when pump bleeding and the lever should get rock solid.
baloneyskin daddy is offline   Reply With Quote
Old 11-03-2012, 09:26 AM   #7
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,742
I spent an hour trying to do it my lazy way, just pump the lever and watch the bubbles, finally got a cheap vet syringe from Tractor Supply, and some 1/4" clear tubing (very tight fit on the slave and the syringe, but a tight fit is needed), emptied the master, and pumped the entire system full from the bottom up, still had a few bubbles to deal with.
Old 11-03-2012, 10:41 AM   #8
ShoelessJoe OP
Oddometer: 131
problem solved....kind of
Not sure what is going on, but after repeatedly bleeding the system thoroughly (pushing up from the bottom with a syringe) I had no luck with the Sigutech. Put the OEM back on, bleeding in the same method and the clutch works properly again.
Both slaves had a ball bearing visible in the piston, so I am fairly confident I did not lose it any where. Measured the depth of the piston and found the Sigutech one was slight deeper (1-2mm). No idea if this makes any difference, but it seems like it would. There was never any good resistance in the clutch action with the Sigutech on it.
Got the slave from KTM twins, so I guess I'll call Ron up and see what he can do.
Thanks for all the help.
Old 11-03-2012, 04:56 PM   #9
Buscapé
Buscapé's Avatar
Oddometer: 21
Sigutech, that's the Hosi-stuff, isn't it ? They're a pain to bleed properly, so I'm pretty sure it's a bleeding problem. I tried to install my Hosi from my 2006 to my 2012 Adv, and I spent almost 2 days fooling around trying to get it working. Finally I was able to bleed it properly by holding the slave on its side, plunger faced down, and tapping it gently. Thus we were able to get out a very persistant bubble of air, located on the outward end of the plunger shaft. It's a construction hickup, once properly bled these slaves are very reliable...
Nil volentibus arduum
Buscapé is offline   Reply With Quote
Old 11-03-2012, 07:50 PM   #10
ShoelessJoe OP
Oddometer: 131
That's probably it. Never thought of pulling the thing off and bleeding it that way. Wasted enough time on it this weekend, I'll give a shot again later in the week.
Old 11-07-2012, 02:57 PM   #11
kingoftwins
kingoftwins's Avatar
Oddometer: 98
Sigutech Master Bleed Issues
Hey guys.
Thought I would chime in here and see what I could do to help with this situation. Pulling it off and getting it to burp is a good idea. In the past you would be surprised at the crazy things we had to do in order ot get brakes bled. Sometimes there is a bubble of air that is stuck for some reason when bleeding new systems that takes exactly that. Pulling it off and putting the unit in a different configuration then what it is normally supposed to be in for that bubble to get past the blockage. We've used every word in the book trying to figure things like that out. We haven't had any issues with the Sigutech but definitely not going to be the one who says that hasn't happened to other customers who didn't let us know about the situation. Please keep me in the loop and let me know how it goes. With regards to the ball bearing that will need to be in place for the clutch to work correctly and Sigutech does require you to re-install your stock unit in their clutch slaves. I hope that helps.
kingoftwins is offline   Reply With Quote
Old 11-07-2012, 03:16 PM   #12
KTMADV
Hammer Down
KTMADV's Avatar
Oddometer: 167
I took me about 8 times bleeding it to get the air out.
Ceasar Vasquez
KTMADV is offline   Reply With Quote
Old 11-07-2012, 03:29 PM   #13
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,780
A trick I use is to secure your clutch or brake lever against the handlebar with a rubber band or clamp and just leave it over night with the cover off the master cylinder. The air will eventually bleed off while you're having a nice restful sleep.
I'm not lost for I know where I am. But however, where I am may be lost.
-- Winnie the Pooh
Deuce is offline   Reply With Quote
Old 11-08-2012, 11:42 PM   #14
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Clutch slaves can be a major PITA to get bled. You might try unbolting it from the engine to allow access to the piston to compress it with pump pliers or a C clamp to force any air out of the piston well. Several strokes of the slave piston should clear any air out.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 11-09-2012, 05:23 AM   #15
ShoelessJoe OP
Oddometer: 131
Cry
I finally got it done. Pulling the slave off and clamping the piston seemed to be the key. That and having about five hands. Had to recruit the kids to help.
Ron, thanks for the follow up via post and emails.
Now it just have to sort out the other problem that appeared during the test ride. I'll post that one under the tuneEcu thread.
Edit: I have to say that there is a big improvement in the clutch. What I thought was an already smooth shifting bike is even better now.
ShoelessJoe screwed with this post 11-09-2012 at 11:15 AM
Times are GMT -7.   It's 04:10 AM.
