Old 11-08-2012, 11:42 PM   #16
_cy_
Oddometer: 6,171
Originally Posted by Giggity View Post
I always thought those were called tombstones. Shows I don't know much
How big are these ovens? I've seen the tube containers in which to store rods. Are they acceptable?
sealed tubes work good, so long as rods were dry to begin with.
tombstone welders are Lincoln Idealarc rated at 250amp DC, 300amp AC. look at your label, it's probably rated for 225 amp AC and 150amp DC.
you will get your best results on steel with DC setting. rod ovens veri in size. mine holds about 15 lbs. some will use a light bulb inside an ice chest or old frig to store rods.
_cy_ is online now   Reply With Quote
Old 11-08-2012, 11:50 PM   #17
Giggity OP
Giggity's Avatar
Oddometer: 753
Good to know. Thanks. Before I buy any rods I'll need to set up a 220 outlet in my garage. It'll be too much of a pain in the ass to pull the stove out and run an extension cord from my kitchen all the time.
Giggity is offline   Reply With Quote
Times are GMT -7.   It's 07:06 AM.
