Old 11-09-2012, 05:21 AM   #14221
sallydog
no more Green KLR
sallydog's Avatar
Oddometer: 5,602
Originally Posted by GrahamD View Post
The bike works really well with or without ABS / UBS. It's just I don't ride enough to keep my skill levels up that high and haven't found a place where the ABS/UBS has caused me a problem. Not that I go looking for it.
might be a problem when racing a hare scramble
Its not who dies with the most toys.. Its who wears out the most toys
Just dip me in beer and toss me in the drunk chicks.
if you havent grown up by age 50 you dont have to
Heaven's the place where all the dogs you've ever loved come to greet you
sallydog screwed with this post 11-09-2012 at 05:28 AM
sallydog is offline   Reply With Quote
Old 11-09-2012, 06:05 AM   #14222
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,974
Why!
Would you race a Hare Scramble on an S10? Maybe you could do eastern Enduros on a Goldwing!
RED CAT is offline   Reply With Quote
Old 11-09-2012, 06:08 AM   #14223
sallydog
no more Green KLR
sallydog's Avatar
Oddometer: 5,602
Old 11-09-2012, 06:51 AM   #14224
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,949
SOmeone is trying in vain to OUT STUD Pluric...
Super Tenere..The models choice.
That's an insult to blue bike owners. Clearly he should be on a black one.
Hmmm, maybe he swings both ways. Yikes.
And those side lights are a little....
pluric is online now   Reply With Quote
Old 11-09-2012, 07:22 AM   #14225
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,446
1) They are not little...
2) Iv'e just broken one..........FFS ....how much to replace
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 11-09-2012, 07:29 AM   #14226
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,949
My condolances to your wife, I didn't know you could break them.
As long as you are replacing one you might as well do them both
and really get your moneys worth.
Old 11-09-2012, 08:05 AM   #14227
William42
William42's Avatar
Oddometer: 2,837
Sorry pluric, that is a typical blue bike owner. Video doesn't lie.
Mud is evil
William42 is offline   Reply With Quote
Old 11-09-2012, 09:27 AM   #14228
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,913
Originally Posted by Lerxstdawg View Post
These guys have a switch that turns the ABS off.
http://www.off-the-road.de/en/home/
Dunno how much in real money 64 Euros is but if it's more than $5, you can just build your own switch...
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 11-09-2012, 09:33 AM   #14229
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,949
Guess we are back to the KLR section now.
Old 11-09-2012, 09:33 AM   #14230
simmons1
simmons1's Avatar
Oddometer: 1,527
Don't be picking on me now!
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is online now   Reply With Quote
Old 11-09-2012, 09:44 AM   #14231
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,949
Dunno how much in real money 64 Euros is but if it's more than $5, you can just build your own bike...
If I was picking on you I would have done the above fix. I have a KLR so I've got to
be able to take a few punches too.
Old 11-09-2012, 09:31 PM   #14232
GrahamD
GrahamD's Avatar
Oddometer: 5,322
Fair Review
Cheers
Graham
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD screwed with this post 11-09-2012 at 09:53 PM
GrahamD is offline   Reply With Quote
Old 11-09-2012, 09:45 PM   #14233
markjenn
Oddometer: 10,442
Originally Posted by NicolasR View Post
Do you know whats the torque for the two nuts beneath the top triple clamp, the nut over the triple clamp the one with the rubber plug, and the bolts that tighten the suspension bars in both triple clamps????
For the two castle nuts below the top triple, the book process is to tighten lower nut to 38 ft-lb, back off completely, then tighten to 13 ft-lb. The upper nut is simply a lock nut so you just snug it finger tight against lower nut, then check for alignment of the slots so the lock washer will fit. If you need to tighten the upper against the lower to get the slots to align, you hold the lower so that it isn't overtorqued.
After installing the top triple, the big nut on the top is tightened to 94 ft-lb.
To use a torque wrench on the castle nuts, you either need a special socket or Yamaha's spanner. And if using the spanner, you need to pay attention to the geometry to get a proper torque reading.
The widely used shadetree method of tightening a loose steering head is simply to use a hammer/punch to snug the lower nut until any looseness or play is removed. On many bikes (not sure about the S10), you can do this without even removing the top triple. You can do a good job this way if you have a feel for these things. I'd bet most dealerships use this method.
If you're asking about the triple clamp fork pinch bolts, the lower bolts (2 on each side) are torqued to 14 ft-lb. The upper bolts (one on each side) are 19-ft lb. If you remove the fork tubes, to avoid mis-alignment, it is important to tighten these first before you do the final tightening of the top nut.
- Mark
Old 11-09-2012, 09:51 PM   #14234
crazyjeeper
crazyjeeper's Avatar
Oddometer: 394
Fair Review
Cheers
Graham
But I thought you couldn't do that sort of thing with a road bike.
2012 Yamaha Super Tenere, 1997 Honda XR650L, 1985 Honda XR350R, 1976 Honda GL1000 Goldwing
crazyjeeper is offline   Reply With Quote
Old 11-10-2012, 02:28 AM   #14235
NicolasR
NicolasR's Avatar
Oddometer: 41
- Mark
Thanks Mark!!! Clear as water!!!
NicolasR is offline   Reply With Quote
Times are GMT -7.   It's 07:42 AM.
