Old 11-09-2012, 07:26 AM   #406
MrBracket OP
MrBracket's Avatar
Oddometer: 261
Originally Posted by Apple Jam View Post
Looks like you had some FUN on the Santiam Wagon Rd,
out there by Mt Washington.
How'd the trailer handle those sandy whoops?
I did indeed enjoy the wagon road! And many of the trails and roads in that area. I was shocked how many trails where up there! The trailer handled very well. The silt was so deep in spots I couldn't see the trails, it was like riding through water almost... Only crashed once, deep silt and an off camber corner a little too fast..... slid out, nothing bad. I even pulled the trailer through a bunch of the OHV trails they have there next to Big Lake, it did great. I rode from the East end of the senic bypass route to Big Lake and out onto Hwy126 at Hoodoo, all on dirt trails and wagon roads. I will do more exploring up there, it was really fun!
MrBracket is offline   Reply With Quote
Old 11-24-2012, 02:40 PM   #407
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,792
Alright then, when will there be a model for the R1150GS. I need this Mule for my GS camping.
hummmmmmmmm, how can it be done on a single sided swingarm?
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 11-26-2012, 11:06 AM   #408
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,496
Back a few pages...check out Mr. Fisherman's setup on his 1150
http://www.advrider.com/forums/showpost.php?p=19333720&postcount=325
BTW, Mike, AKA, Mr. Bracket,....I PM'd a question a couple of days ago....
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 11-26-2012, 10:58 PM   #409
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,792
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
Old 12-18-2012, 11:53 PM   #410
GSA GIRL
2010 R1200GS Adv.
GSA GIRL's Avatar
Oddometer: 103
I'm very unhappy with my trailer. It just sets in the garage looking so Lonely. I walked by it the other day and I heard it whisper that it wanted to run away from home. My 08 KLR-650 is setting on the lift on a Battery Tender. My 2010 GSA needs a Valve Adjust and I'm sure Oil Changes are needed all around. Nothing has turned a wheel since late September. Yes, I'm an IBA Member and not a wheel has turned since Late September. With the Economy as it is, I've not been able to walk away from all of the available overtime at work. I sure do miss ridding. This Summer is going to be great!!!!!!!!!!!
Alicia from The Left Coast. IBA # 45858
2010 GSA, 2008 KLR650, 1995 GS (Sold), 2005 ST1300 (DEAD)
GSA GIRL is offline   Reply With Quote
Old 12-19-2012, 11:11 AM   #411
bete
Oddometer: 555
How much for these 08+ KLR brackets??
bete is offline   Reply With Quote
Old 12-20-2012, 02:15 PM   #412
MrBracket OP
MrBracket's Avatar
Oddometer: 261
What you using them for? Would you need the wing bolts too?
Old 12-20-2012, 04:29 PM   #413
bete
Oddometer: 555
no wing bolts, just the chain ajust thing a ma bobs.
Old 01-07-2013, 05:36 PM   #414
hatfirst
Oddometer: 31
this would work great to haul my federal tax booty to the bank Got to thank them politician's
hatfirst is offline   Reply With Quote
Old 01-18-2013, 05:30 PM   #415
bee-rad
Oddometer: 7
I figure I may as well post a picture of my set-up. I am still working on a wireless turn signal set-up which should be done soon. If I have a trail clearing expedition this spring I can carry a chainsaw where the rifle case is mounted which ultizes the same Kolpin mounting bracket.
I experienced a flat tire on the first outing, and have since installed a motorcross front tire and a 4mm thick tube. The wheel bearings were the next items to go. Not too shabby given they have seen over 10,000K now. Getting the bearings out was a chore, and I actually ended up destroying the original axles with the hydraulic press, so I machined a new set.
I bashed holes right through the original Action Packer in short order and have since replaced it with a pelican case. Its hard to see, but I have a bash bar protecting the leading edge of the Pelican case from boulders etc.
The Husaberg pulled this around for a good part of hunting season as my daily driver is a Jetta. I did manage to find 2 deer!
bee-rad is offline   Reply With Quote
Old 01-20-2013, 09:02 AM   #416
MrBracket OP
MrBracket's Avatar
Oddometer: 261
bee-rad, your set up looks great! Great to see. Glad to see it's getting so much use!
What model pelican case is that?
Old 01-20-2013, 04:34 PM   #417
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,441
Likewise, I think that's a really nice setup, bee-rad. If you don't mind the tangent, did you haul the deer out on the bike and/or moto mule?
Lutz is offline   Reply With Quote
Old 01-20-2013, 06:41 PM   #418
bee-rad
Oddometer: 7
Its a 1620 Pelican Case. It just fits. I removed the plastic luggage handle and wheel contraption and then welded up a mounting plate with integrated bash bar. The only gripe is the rear most latch hits the shock tower & its tricky to get your fingers in between the steel plates to snap it open, however I wanted the case as low as possible so the rifle would clear.
Old 01-20-2013, 06:48 PM   #419
bee-rad
Oddometer: 7
I didn't because I harvested 2 deer as a double header with 45 minutes of daylight left. I raced back to the campsite on the Berg and asked for some help from the neighbors using my car motorcycle trailer and their 4x4. I didn't hit the hay until 3am that evening by the time I had both deer processed, & it would have been hours more if I tried to haul them out with the moto-mule. Perhaps next year I may find the circumstances right where I can use the moto mule to haul a deer out. I have too say, I did many days of pure riding (while keenly watching the forest for animals) and then had days where I purely walked around in the bush hunting. I had more run-ins with wildlife while on the motorcycle then on foot, even with all of the racket a dirtbike makes.
Some of you may recognize the trailer from its prior life before I got my hands on it...
bee-rad screwed with this post 01-21-2013 at 12:10 AM
Old 01-21-2013, 04:29 PM   #420
GB
Mod Squad
GB's Avatar
Oddometer: 56,561
Nice setup
Times are GMT -7.   It's 05:34 AM.
