Old 11-07-2012, 07:24 PM   #6796
Bonsai Elephant
Bonsai Elephant's Avatar
Oddometer: 18,756
Came one step closer to a 2006 950 today...
Bonsai Elephant is offline   Reply With Quote
Old 11-07-2012, 07:51 PM   #6797
Skyclad
Original Bastard
Skyclad's Avatar
Oddometer: 5,699
Put new tires on this evening in preparation for the nor'easter.
I am very happy with the Pirelli MT-21's.
4000 miles, including trips to New Jersey and Vermont, and the front tire is severely cupped. I could probably get a few hundred more out of the rear tire, but didn't see any reason to push it. I will be keeping that tire as a back-up. I am going to try running higher pressure in the new front tire to see if that will help with the cupping.
Great off road performance, surprisingly good on pavement and 4000 miles on a big, powerful bike? What's not to like? I do believe I will stick with the MT-21's for awhile.
Ignorance breeds Fear. Fear breeds Hatred. Hatred breeds Ignorance. Break the chain.
cancer
For some, a glue stick would be a better option than Chapstick
Skyclad's Wanderings - Bald Eagle Bastards - The Mountains are Calling, and I Must Go
KCCO
Skyclad is offline   Reply With Quote
Old 11-07-2012, 09:28 PM   #6798
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,812
New Renthal 608 bar in an unfortunate color.
Progrip 714s.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 11-07-2012, 11:12 PM   #6799
Joeman68
Tanker
Joeman68's Avatar
Oddometer: 29
Done with clutch work, Oberon clutch kit assembled.
/ Joeman
2004.5 KTM 950 ADV
Husqvarna MC 258 Army
Joeman68 is offline   Reply With Quote
Old 11-08-2012, 09:21 AM   #6800
Masa
Masa's Avatar
Oddometer: 300
This should provide adequate grip during the winter time. 4,40 tire looks narrowish on the stock rim but should be ok.
Masa is offline   Reply With Quote
Old 11-08-2012, 02:37 PM   #6801
Splisken
I'm not dead yet...
Splisken's Avatar
Oddometer: 127
Installed Fastway Evo2 pegs and a set of black shrouds over the tank. I got the pegs for the LoBoy position on them. At first glance and even when holding them in place they didn't look any lower but they are! Lower and a bit more rearward, plus about a 1/4" wider. There is no extra length to them however.
FastwayEvo2-LoBoy
BlkShroud
Splisken is offline   Reply With Quote
Old 11-08-2012, 11:09 PM   #6802
Joeman68
Tanker
Joeman68's Avatar
Oddometer: 29
Looks great, what kind of spikes do you use??
/ Joeman
2004.5 KTM 950 ADV
Old 11-09-2012, 07:45 AM   #6803
Masa
Masa's Avatar
Oddometer: 300
I think those are 25mm enduro spikes.
Old 11-09-2012, 11:27 AM   #6804
veriest1
Grand NOOBlet
veriest1's Avatar
Oddometer: 2,550
I added a second set of rubber compression nuts to my headlight surround so I can move the fairing to a high and low position.
Before:
After:
veriest1 is offline   Reply With Quote
Old 11-09-2012, 10:54 PM   #6805
R&R4adv
R&R4adv's Avatar
Oddometer: 339
Carbon end caps
I have wings exhaust but only standard ends so i ordered two Carbon end caps which arrived so after drilling out old rivits and sliding on the caps drilling more holes and re riviting this is what i ended up with.
R&R4adv aka Reon
04 950 Adventure
past bikes
04 950 Adventure 03 640 Adventure 99 XR400
R&R4adv is offline   Reply With Quote
Old 11-10-2012, 06:43 AM   #6806
JTS1
Dirt Enthusiast
Oddometer: 67
Scotts Damper
Mounted up a Scotts steering damper on my 950se using the stock triple and pre existing holes on the triple and frame. Seems to work great and doesn't look bad in my opinion. If anyone is interested and can uploads photos fire me an email address and I'll send them to you.
JTS1 is offline   Reply With Quote
Old 11-10-2012, 07:33 AM   #6807
skipman
skipman's Avatar
Oddometer: 176
I highsided yesterday and bent the hell outta my crashbar and scratched everything else up pretty good..LOL...but i'm fine...
Not responsable for broken windshields.Please stay back 300ft.
'10 KTM 990r
skipman is offline   Reply With Quote
Old 11-10-2012, 03:07 PM   #6808
biggus
biggus's Avatar
Oddometer: 378
Looks great.
I have the old Wings and had wanted to do this as well.
Did the carbon end caps come with new rivets?
biggus is offline   Reply With Quote
Old 11-10-2012, 07:07 PM   #6809
R&R4adv
R&R4adv's Avatar
Oddometer: 339
Biggus the rivits were $2 each and the caps were $48 each in oz if you get them make sure you get the cover strap i didn't and the strap does not meet up at rhe bottom but easy install otherwise even came with rubber bungs to seal the hole to undo the silincer inserts int he carbon cap.
R&R4adv aka Reon
04 950 Adventure
past bikes
Old 11-10-2012, 10:54 PM   #6810
biggus
biggus's Avatar
Oddometer: 378
Thanks for the tips and pricing.
Times are GMT -7.   It's 06:53 PM.
