11-08-2012, 01:29 PM
#76 |
beat up ex flat tracker
Oddometer: 6,757
Same here,if those are issues with these bikes its new to me,had lots of KTM's. Butter soft wheel spacers? What kind of butter? Ive had em last years and still be good.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
11-08-2012, 05:40 PM
#77 |
Oddometer: 290
the wheel spacers on my 09 530 had the chrome plating all peel up which toasted the wheel seals
once the plating peeled they corroded fast - only 50 hrs on bike - they looked like 10 years old ------------------------------------------------------------------------------------------------------------------- I went with some spacers from all balls -they have a hardened steel sleeve where the seal runs the aluminum spacers were soft on my xr650r also - wore deep groves where seal ran we ride a lot of mud here - so that may make a difference
'11 Dakar 990 |
11-09-2012, 10:52 AM
#78 | |
Oddometer: 6,757
11-09-2012, 02:53 PM
#79 |
Oddometer: 5,050
11-09-2012, 07:00 PM
#80 | |
Oddometer: 290
Stock bearings only lasted 2900 km and were toast - seals failing was a factor here ? all balls fit was perfect and the wheel spacers were awesome - even have an o-ring inside to seal to axle which should help stop water getting in. the hardened seal surface will last long and only adds a tiny bit of weight ! see them here 2009 KTM 530EXC All Balls Front Wheel Spacer Kit | MotoSport kind of like a speedy- sleeve on the old small block chev harmonic balancers ---------------------------------------------------------------------------------------------------- as to stuff that didn't fit ? - thought KTM used same bearings for all dirt bike wheels 125- 530 ? maybe someone packaged wrong stuff ? --------------------------------------------------------------- might not have been "chrome" but there was a plating that peeled up and was nasty sharp on my stock spacers - maybe it was a hard surfacing or something ? still have them laying in a box somewhere - not serviceable at all. --------------------------------------------------------------------------------------- later........
'11 Dakar 990 |
11-10-2012, 06:06 AM
#81 |
Chris
Oddometer: 1,683
I used to fight poor sealing performance like this nearly every ride. On my XRR I found the solution was to replace the spacers with hardened ones and replace everything at the same time and fill every nook and cranny with waterproof grease. Then replace everything altogether.
On my 04 EXC I got the best results from regular maintenance. Cleaning out the old grease and getting new stuff in there. The spacers I had weren't hardened but keeping good grease in there helped alot. Now on my 08 EXC the spacers were updated along the production line between 04 and 08 and have a much better sealing surface and I haven't had a hard time yet but I still take the axle out and clean and grease it after every couple of rides and after EVERY muddy ride. Throughout this I had some premature bearings that let go way too early but my biggest incentive was stuck axles. Its no fun working on stuff when you can't even get the wheel off
11-10-2012, 07:35 AM
#82 | |
Oddometer: 6,757
Then without much thought I put the same brand of bearings in the ft wheel on a 200 KTM,had the same slop the DRZe had. I can only wonder what the use is of bearings that have play right out of the box? Some one in China knows.
11-10-2012, 07:44 AM
#83 | |
Oddometer: 6,757
It can wreck the dust seals over the bearings like grinding paste,then the spacers rubbing against the dust seals are subject to the same paste at pretty high speed,cleaning and greasing of course helps,maybe having extra dust seals and popping them in from time to time. Ive submerged bikes/wheels in nasty waterholes with river silt in them and had the wheel bearings die the next ride,they're dirt bikes,its just what happens.
11-10-2012, 03:14 PM
#84 |
Chris
Oddometer: 1,683
I agree, mudd is bad when it gets packed behind things and starts pushing on stuff but otherwise its the water in the mudd that wears stuff out. Thats why I think having the new spacers and regular cleaning did the best.
11-10-2012, 03:16 PM
#85 | |
Chris
Oddometer: 1,683
11-10-2012, 11:38 PM
#86 |
Cape Town Wanderer
Oddometer: 178
Wouldn't it be best to fill the hub with grease?
I wonder if one could just remove the dust seals completely and put a grease nipple in the middle of the hub?
A few pumps of grease after a muddy ride would force new grease into the bearings and get rid of the water. This used to work back in the day on bicycles. |
11-11-2012, 07:49 AM
#87 |
Around
Oddometer: 3,355
Ned, Great thread as usual! Thanks for all the useful info and well thought out accessory plan.
Question...Since you're using this bike as a single track - woods scalpel, was wondering if you looked at the 350 XCF-W when you considered new bikes? If you rode a 350, would be interested in hearing your thoughts when comparing it to the 500 XC-W. Again, thanks for all the great info.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden "Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE |
11-11-2012, 11:09 AM
#88 | |
Tuareg 2013
Oddometer: 11,341
First, the 350 rips. It lacks torque, but even at 8k feet, it would usefully accelerate above 70mph, which I was amazed by. But, you have to really spin for it- not much torque down low, and while it's darn fast up top, you better be on your game and tap dancing on the shifter. In the woods, it handles great, but it took a higher level of commitment than I enjoy. I've always been a big-bore guy, meaning I ride best when I'm not shifting all the time and rely on the torque of the engine. The 350 doesn't do that, it has plenty of go, but you will shift 3x more than on the 450 or 500 to go the same speed down the trail. Finally, the bike felt physically small to me- I dragged the pegs in places I didn't expect to, and the length of the cockpit seems a bit shorter than the 450/500. What that boils down to is 100% personal preference. I prefer the bigger bore/ bigger bike, and that isn't really a knock on the 350 at all. I think the only place it came up short is for real dualsporting- gearing and revs would be an issue if you were doing lots of pavement/ boring dirt.
For Sale: FJ60, Defender 90, Superduke Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible. Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills. |
11-12-2012, 10:36 AM
#89 |
Oddometer: 6,757
If the bearings were wobbling in the hub it would be pretty obvious and wouldnt last long. It was bearing play on both bikes.
11-12-2012, 10:40 AM
#90 | |
Oddometer: 6,757
I had an 06 400EXC and even it was a little weak off the bottom for cliff climbs with no run at them,it would also get hot and stall at the damndest of times. My 530 takes no notice of most climbs,just a matter of pointing it the right way.
