Old 11-11-2012, 03:22 AM   #27
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,748
Originally Posted by SiouxsieCat View Post
In the top image, it appears there is a line going up front with an in-line fuse coming out of the fuzeblock.
I'm not an electrician, but that is redundant and not really needed, right?
Cheers
That is correct. The lower value fuse will fail first, the higher value fuse doesn't *do* anything. Setting up two fuses in series doesn't offer any more protection than a single fuse.
Using two fuses in parallel allows you to pull more current, much in the same way twinning a water line will give you more output at the end of the pipe. IMO, if you've got an accessory pulling 30A (two 15A fuses), and it isn't a clothes dryer or electric stove, you're doing something wrong.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Times are GMT -7.   It's 05:34 PM.
