Old 11-10-2012, 11:28 AM   #31
katego
katego's Avatar
Oddometer: 553
Originally Posted by Mike Ryder View Post
So was the ticking a bomb then?
yikes. yeah, must have been.
-k
Squaring off tires and tipping over bikes since 2005.
katego is offline   Reply With Quote
Old 11-10-2012, 11:51 AM   #32
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,180
Originally Posted by vintagerider View Post
Two suspected causes of cam follower damage are valve lash too tight and lubrication failure. By the looks of those heavy varnish deposits there was overheating and/or extended oil change interval. The engine calls for API SF/SG. Newer automotive oils are SL/SM with low levels of ZDP.
That's the righthand side of the engine in the pictures - The left hand side was in perfect condition
www.gsshop.co.uk
Steptoe is offline   Reply With Quote
Old 11-10-2012, 12:45 PM   #33
Gintaronas
hobbyist
Oddometer: 180
one more broken
Steptoe, sir. I am sure that you know that countless 1150 owners are now removing their valve covers in dreaded anticipation. Well done. Thank you.
I just ran out now to have a look at mine. Have you any thoughts as to what may have caused this damage? It looks to me as though that head was over heated a bit.
Great pictures.
Well, yes, I am one of those "countless 1150 owners".
I had a bad sound developing on the right side of the engine. Removed cam and - here you go, the same picture with the exception that only half of cam and one follower is broken - the exhaust side.
For the intake part all seems well. Maybe that's why the sound is not that loud compared to videos in this thread.
I wonder if it would be possible to fix the cam somehow (welding/grinding/hardening)?
Also would be interesting to find out the cause of this problem. I would rule out the wrong oil, lack of oil and prolonged change intervals. Normally I keep valve lash on "tappy-happy" side...
Abs + Tsc + Ebd + Cbc + Asc + Dsr + Esp + Eba + Bas + Ldw = No Fun
Gintaronas is offline   Reply With Quote
Old 11-10-2012, 04:47 PM   #34
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,125
Originally Posted by MikeO View Post
Well the good news is, I don't have to worry about the noise from the right hand valve gear...
That's not nice. I hope it is insured. Any idea what caused the fire?
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 11-10-2012, 05:34 PM   #35
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 1,384
ex X phile
Avoid the Gavel, travel by gravel
dirtsurfer is offline   Reply With Quote
Old 11-11-2012, 07:36 PM   #36
allonsye
("lets go!")
allonsye's Avatar
Oddometer: 851
Video recorded this morning when the engine was cold...
That's the sound of a worn TB shaft bushing. Been there had that. Put a finger against the the TB cam, pulley thingy and you'll be able to verify straightaway. Glad the problem was solved [sic] but hope you didn't get injured in the process.
"A good traveller has no fixed plans and is not intent on arriving" Lao Tzu (570-490 BC)
Current:
02' GS1150R
06' 650 Vstrom
allonsye is offline   Reply With Quote
Old 11-11-2012, 07:39 PM   #37
pcwirepro
Aspiring Adventurer
Oddometer: 281
You might want to read the ENTIRE thread.
pcwirepro is offline   Reply With Quote
Old 11-11-2012, 07:43 PM   #38
allonsye
("lets go!")
allonsye's Avatar
Oddometer: 851
I had. Other than the bike having been destroyed (in effect "solving the problem") what else did I miss
Current:
02' GS1150R
06' 650 Vstrom
Old 11-12-2012, 03:04 AM   #39
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,180
That is wasn't the throttle body causing the noise
www.gsshop.co.uk
Old 11-12-2012, 05:21 AM   #40
pcwirepro
Aspiring Adventurer
Oddometer: 281
My point exactly.
Old 11-12-2012, 05:26 AM   #41
allonsye
("lets go!")
allonsye's Avatar
Oddometer: 851
My point exactly.
Thanks for the clarification and enlightment
Current:
02' GS1150R
06' 650 Vstrom
Old 11-12-2012, 06:56 AM   #42
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,035
Holy Crap Mike !!!
Tbone is offline   Reply With Quote
Old 11-12-2012, 08:13 AM   #43
MikeO OP
Wage slave...
MikeO's Avatar
Oddometer: 6,339
All text & original photos © Mike Oughton 2004 - 2013
MikeO is offline   Reply With Quote
Old 11-12-2012, 09:33 AM   #44
SJSharkfan
SJSharkfan's Avatar
Oddometer: 505
So what happened? Don't leave us hanging!
GO SHARKS!
Dave
'02 R1150GS ADV "The Tank"
"I fire up the willing engine,responding with a roar.
Tires spitting gravel, I commit my weekly crime."
"Red Barchetta" By RUSH
SJSharkfan is offline   Reply With Quote
Old 11-12-2012, 02:32 PM   #45
mike54
You don't get me
mike54's Avatar
Oddometer: 12,434
Mike
Sad end to a wonderful bike. Sorry man.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Times are GMT -7.   It's 10:52 PM.
