11-12-2012, 04:54 PM
#1 |
Oddometer: 476
Running through canbus without fuse
I just bought a used 550 and the canbus cable (BMW) didn't have a fuse inline. How power stable are GPS as a whole? I know there is no blanket answer but best guess if I should cut and place a fuse in this cable?
Everything's better in retrospect. |
11-13-2012, 05:16 PM
#2 |
Unregistered
Oddometer: 4,445
I think you can put away your worry beads. I have no issues with my Zumo 450 powered through CANbus. 5 years maybe
Oh Yeah, when I was making a power cord for my Zumo 220, the guys at GPScity confirmed I did not need a fuse when going through CANbus, well, from the GPS plug or an accessory outlet
I've got to be cool Relax Take a long long ride on my motor bike Untill I'm ready Mudcat screwed with this post 11-13-2012 at 05:33 PM |
11-13-2012, 06:29 PM
#3 | |
Oddometer: 79
Try to keep the Zumo 550 mount dry. There is a seam that allows water to enter the mount, which eventually can cause corrosion and failure of the mount. I never experienced that problem, but you will see online accounts of this. |
11-13-2012, 06:31 PM
#4 | |
Oddometer: 476
Thanks again
11-14-2012, 06:24 AM
#5 | |
Unregistered
Oddometer: 4,445
The GPS plug and accessory ports shut down if the draw exceeds 5 amps. I have my GPS powered from an accessory port on the left hand beak. I have a short power cable from the GPS unit which I can unplug easily, so, when I am parked in wonky areas, I just remove the GPS from the bike. It takes about 30 seconds.
I've got to be cool Relax Take a long long ride on my motor bike Untill I'm ready |
