11-13-2012, 06:43 AM
#106 |
Oddometer: 293
^Forgive ignorance here...
...but any reason to use the hole saw in the handheld drill? It looks like the pilot was created with a drill press.
Otherwise: HOLY COW THIS IS AWESOME!
11-13-2012, 08:04 AM
#107 |
Racing Like a Noob
Oddometer: 4,280
Looking great. I hope I get to come up there one of these weekend's to break stuff...I mean, help out the build too!
Racing a Subaru in the 2013 Mexican 1000 |
11-13-2012, 08:09 AM
#108 | |
On Any Sunday
Oddometer: 581
"Nothing can stop us but fear and common sense” |
11-13-2012, 08:38 AM
#109 |
Semi-Adventurer
Oddometer: 9,833
Sooner, or later, this is bound to wind up being a caption for different picture.
I miss round headlights. "When I was a young man, I liked to race my horse...." - G.H.W.S. 1878-1962 |
11-13-2012, 08:53 AM
#110 | |
On Any Sunday
Oddometer: 581
11-13-2012, 12:36 PM
#111 | |
GPoET&P
Oddometer: 3,749
The cordless drill can turn much slower than the drill press, which is good for the hole saw bit. Here's the post: http://advrider.com/forums/showpost....postcount=1695 Jdrocks wasn't kidding about the binding either, I've got a tender spot on my ribs where the drill's battery pack smacked me a few times. |
11-16-2012, 11:48 AM
#112 |
Oddometer: 293
^Luke^
Ahhh...added to my vast knowledge base...
11-19-2012, 08:24 AM
#113 |
On Any Sunday
Oddometer: 581
Swing Arm
Luke came over Saturday and started fabricating the swing arm, as you can tell from the photos, he made pretty good progress. I'll post the pics and let Luke weigh in later with the commentary.
Swing arm pics; ![]() ![]() ![]() ![]() And Luke's new toy; ![]() ![]()
11-19-2012, 11:47 AM
#114 |
fishing with dynamite
Oddometer: 2,031
Why are you making the swingarm out of multiple pieces of box tubing? Doesn't look like it would be and harder to drill offset holes for the swingarm pivot that would give you the angle/clearance you need? Luke, if you want to send me some dimensions I can help you figure that out?
11-19-2012, 02:04 PM
#115 |
GPoET&P
Oddometer: 3,749
A straight tube won't work because the shock mounts are going to be under the center of the swingarm. Here's the cross section of the parts to be avoided at the centerline of the swingarm.
11-27-2012, 11:45 PM
#116 |
Befuddled Adventurer
Oddometer: 256
Very nice TIG torch Luke! Is the little knob towards the upper end of the torch handle a shielding gas control valve?The swingarm is coming along nice as well.
Only problem is we need more updates! I'm sure I'm not the only one having CBZR-650 withdrawals... ![]()
"Remember, you may have to grow old, but you don't have to mature." - Red Green |
11-28-2012, 10:19 PM
#117 |
GPoET&P
Oddometer: 3,749
Yeah, I'm having withdrawal too. I got a little work in last week but have been busy since then.
From last week, a little more swingarm work: Start with making a tube to simulate the hub with extra spacers. ![]() This'll be a lot faster when I get the parting tool working. ![]() ![]() Then tack some parts together. ![]() More stick welding. I like. ![]() The welds turned out as flat as the tube stock. ![]() It turned out pretty well, with the axle and swingarm legs clamped together they were within 1/2mm at the swingarm pivot tube. Cutting the cross brace. ![]() The legs needed a bevel cut into them, and that was the last thing to do. These cuts were tricky, and I had to learn a few things about chop saws and metal tube. Chop saws need pressure to cut. Long flat cuts don't work. Metal tube has internal stress. Slit it long ways and it will spring out. Not the end of the world, but that'll be something to fix next time.
11-28-2012, 11:11 PM
#118 |
Oddometer: 2,031
Understand what you're doing with that swingarm now. Thanks for clarifying. For any precision cuts, you might want to try scribing lines on all four sides and then using a 4-4.5" angle grinder with a cutoff wheel. It's almost impossible to hit perfect angles on a chopsaw.
11-29-2012, 12:17 AM
#119 |
GPoET&P
Oddometer: 3,749
You must have a much steadier hand than I do. I always do way better with the chop saw. Start with a decent one and take the time to square it up. It's a moot point anyway because the accuracy of the swingarm doesn't depend on the accuracy of the cuts. It just makes the fit better for welding. The half mm was the difference in width between each end of the swingarm with the axle end bolted up and the pivot end free. A 0.05 degree error. |
11-29-2012, 12:59 AM
#120 |
Oddometer: 120
Like your build up so far ..Thanks Have a question on the front end .. which tripple trees did you use for the forks ? did you have to modify the neck bearings to fit ?
