11-11-2012, 11:34 AM
#46 | |
Oddometer: 505
Thanks Rucksta. That a great report !!
All the things you mention are the same as I notice on my bike(s). Using the bikes for the same sort of riding. I do have a long fork in my bike now.WP48mm with 300mm travel. The long straight center stand is changed for one with an angle in the middle. To be able to use some wheel travel before the thing is dragging through the sand. Next to my R80ST I do have a R65GS thats still original. The low center of gravity is the best for the handling IMO. But the wheel travel and ground clearance from the ST is great too. If I would have to choose between the 2 options it would be a real difficult choice. After riding Dmaster's bike a few times I think thats the way to go. (R65GS with original swing arm length using max travel with custom shock and a shortened DRZ fork.) (Now only some wing shaped custom triples with the proper off set) Quote:
BMW R100'91/R80'93/R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920 R100GS'91 (sold) |
11-13-2012, 01:59 AM
#47 |
Desert Lion
Oddometer: 256
Given that many are opting for DRZ forks as a cheap/easy way into upgrading the front but not changing the rear - there must be enough demand on ADV for a specific triple clamp........
11-13-2012, 10:11 AM
#48 |
Oddometer: 505
First I will ask a friend to make some drawings. When me and Dmaster are happy with them we will ask if there is anybody interested in the 49mm triples.
11-19-2012, 11:41 AM
#49 |
Oddometer: 67
Well i did
![]() ![]() This is with my old set up (Kawa KX 250 front end whit stroke limited to 200mm with really strong springs) Bottomed out hard front and back.(I still wonder why my frame didn't break )But still with my DRZ front end with 275mm travel (or 270mm sorry i forgot) it will bottom out if I do this kind of crap. Dmaster screwed with this post 11-23-2012 at 12:12 PM |
01-03-2013, 12:38 PM
#50 |
Desert Lion
Oddometer: 256
rake
01-03-2013, 12:54 PM
#51 | |
Scope Creep's Victim
Oddometer: 2,199
I want to get that 10 degrees back on either side. Thanks!!
Fred '85 R80RT G/Sified '91 R100GS Bumblebee Airhead Zen: Ride-Maintain-Repair-Ride On. |
01-03-2013, 01:26 PM
#52 | |
Oddometer: 505
![]() They will have more spread than the DRZ triples. 210mm. When I know more I'll let you know Beater.
01-04-2013, 06:01 PM
#53 | |
Oddometer: 1,169
What suspension travel are you looking to run with your new project. I guess its always going to be a compromise between low COG and easy handling in tight going and enough travel to be able to soak up bumps and holes at higher speed. What are the negative aspects of your current handling / suspension. Cheers Phil |
01-05-2013, 01:08 AM
#54 | |
Oddometer: 505
I would like to fit the triples in my girlfriend's Xcountry too. And that bike needs the wider triples. The off set should give more clearance to the tank and the frame. On my bike i'm going to use the full travel of the DRZ fork (285mm) The negative things about my WP48 mm is the friction those forks have. I have tested loads of upsd forks, and even after a lot of time and effort they don't run as smooth as the drz forks. With the WP 48 I tend to back up most of the re-bound and compression to get more comfort. But than there is no controle left ![]() I've re-valved the fork with all the settings you can think of but the friction of the two tubes causes the discomfort. The only thing that helped was shortening the fork so the the fork tubes had more overlap. But than the DRZ fork was still better, even without re-valving which I will do anyway.
01-06-2013, 05:19 PM
#55 | |
Oddometer: 3,460
Of course, you have the deepest sump installed. Not representative of a GS.
I also have concluded that 300mm front travel is not at all the holy grail of forks. Not for me, at least. Using that much travel would be far too uncomfortable for the riding I do which is more like rocky jeep trails than fast desert. And for rocky singletrack I ABSOLUTELY do not want the additional wheelbase. 225~250 travel is fine for me. Modern bikes are giving more rear suspension than front, which is very anti-GS. So I would like to improve my front forks without adding a lot of travel, but I'd like to add more travel at the rear. As for the appropriate amount of trail, I don't think the GS is perfect at all. Remember, trail is only accurate on flat ground. When you hit a rock with a glancing blow, the contact point is well forward of the point from which trail is measured and can easily give 'negative trail' for that condition. In my experience, the GS is not a very good performer in this way and has less trail than any similar bike that I have noted. Your basic KTM or HP2 has 20+ mm more trail, meaning that when your front wheel bounces off that rock you get that much less leverage fighting your handlebar. BTDT; the Airhead GS is a real workout in rocks. It's 25 year old geometry based on 40 year old street bikes. |
01-06-2013, 11:42 PM
#56 | |
Oddometer: 505
That part is not much lower than a GS sump.
01-07-2013, 05:27 AM
#57 |
Oddometer: 3,460
It's just over an inch lower in the back; that's a lot in my book. Less, though, once you add in a skid plate.
01-07-2013, 08:55 AM
#58 | |
Handy Schtroumpf
Oddometer: 230
Damn, every time I read about a solution to problems on these forks, I find another problem. Starting to question it again. |
01-07-2013, 02:44 PM
#59 | |
Oddometer: 67
Even now with the proper front springs and a rebuild rear shock its unstable as f... It scares me in soft sand .Its only the weight that makes me go faster on the XR (not even much faster). |
01-07-2013, 03:19 PM
#60 | |
Oddometer: 1,169
