Old 11-12-2012, 04:53 PM   #16
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,415
Originally Posted by acousticrawk View Post
.... im def going with a 100 (1000) because i want the extra umph for long loaded highway runs. a large bore carb and head 1000, and i have a few to choose from at work ...
Don't get fixated on the 'big bore' heads and carbs. Not worth it in my opinion ... Get the standard bore 980cc pistons and cylinders the smaller bore heads and VM32 Mikuni carbs ... It will have more more power through all of the range than the 'big bore' stuff.
But it sounds like you should be looking for a naked R100 from 81 to 84. They are out there. These are the dual shocks with no flywheel, just clutch carrier.
PS - My youngest daughter sends you this:
Fred * '85 R80RT G/Sified * '73 R75/5 LWB
Need a pre-80 Airhead Part? I May Have It!
Beater is offline   Reply With Quote
Old 11-13-2012, 07:08 AM   #17
W7AMF OP
Yeah Raft'n!
W7AMF's Avatar
Oddometer: 102
why dual shock over monoshock? i dont think the final drive gear ratio availability is that big of a deal to me. i just want something decent for the highway. doesnt have to be great even. as long as it will do 80mph fairly easily while being loaded down.
2009 Suzuki DR650
W7AMF is offline   Reply With Quote
Old 11-13-2012, 07:36 AM   #18
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,543
Monolever final drives are getting tough to find. Monolever spoked hubs with remaining brake lining are approaching "hens teeth" status. You can get a 4 lug monolever and mill a later paralever GS hub to fit, but then ideally you'd have to redrill the spoke holes in the hub for a conventional rim instead of BMW's tubeless cross spoke rim.
The dual shock parts are easier to source and you have a greater variety of final drive ratios available to you. Sustained comfortable actual 80mph (not indicated) is a bit high for the 37:11 ratio, especially for 1000cc engine. 32:10 would be about right in my mind.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-13-2012, 11:24 AM   #19
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,415
What he said.
Old 11-13-2012, 01:40 PM   #20
W7AMF OP
Yeah Raft'n!
W7AMF's Avatar
Oddometer: 102
Not sure i quite understand? I know I want a spoked rear wheel at least i think, and I know I want a 17' wheel right? and a 20 or a 21" front right? spoked in the front for sure. I have about 20 mono lever final drives to choose from at work ;) my question is, can i get a spoked 17 inch wheel for the rear thats 4 lug? the G/S and r80's are 3 lug right? id also preferable like to run a disc rear, but not absolutely necessary.
thanks!!
2009 Suzuki DR650
Old 11-13-2012, 02:16 PM   #21
Airhead Wrangler
Adios Mexico
Oddometer: 6,543
thanks!!
Yes, I'd want a spoke rear. They handle abuse much better. 17" or 18" would both work. Depends on what kind of tires you want. For serious offroad work there's a much better selection of 18" tires. Problem is that none of the 4 lug monolever bikes had spoked wheels and therefore there is no such thing as a 4 lug monolever spoked hub, so you'd have to make one by milling down a R100GS hub to fit. You definitely want a 21" front rim, probably 1.85" wide. Forget about a disc rear on a monolever, unless you want to do a LOT of work.
Old 11-13-2012, 02:43 PM   #22
W7AMF OP
Yeah Raft'n!
W7AMF's Avatar
Oddometer: 102
great info. so, then, did they make a spoke rear for dual shock bikes? also, switching to an 18 rear, and a 21 front, do i need to worry about rake and trail being changed to much? I dont fully understand rake and trail.
2009 Suzuki DR650
Old 11-13-2012, 02:51 PM   #23
Airhead Wrangler
Adios Mexico
Oddometer: 6,543
Yes, all /6 and some later dual shock wheels are spoked. Yes, you're frame geometry will be changing, but wheel size will probably be affecting this quite a bit less than suspension changes. I'm assuming you'll be using longer travel forks at a minimum and maybe a lengthened swingarm, so those will have a much bigger effect on your geometry than your wheel sizes.
Here's some reading for you:
http://www.tonyfoale.com/Articles/RakeEx/RakeEx.htm
Old 11-13-2012, 03:07 PM   #24
W7AMF OP
Yeah Raft'n!
W7AMF's Avatar
Oddometer: 102
got it! ill be doing some reading!ill probaby run a GS for if i can dig one up. we have a few of the lower halfs (yellow), but i havent found any springs or upper tubes, but i havent looked that hard. were slim on GS stuff. if not, ill go with a suz dr or DRZ front end. not sure on the rear, that will depend on which rear set up I go with. will a dual shock or mono shock swing arm be easier to lengther? does any bike use an already longer swingarm? what about a g/s swing arm? basically is there a longer swing arm i can bolt in? or do they all require making?
2009 Suzuki DR650
Old 11-13-2012, 03:17 PM   #25
Airhead Wrangler
Adios Mexico
Oddometer: 6,543
Nope, there's no off-the-shelf solution there. Gonna need to cut and weld for a longer swingarm.
Just curious, where do you work that has 20 monolever final drives on the shelf? Got a 3 lug 32:10 you want to sell?
Old 11-13-2012, 03:30 PM   #26
W7AMF OP
Yeah Raft'n!
W7AMF's Avatar
Oddometer: 102
RePsycle BMW Parts. Ill check. shoot me a PM so we dont get too off topic.
BTW, I found a 4 lug, spoke rear wheel. its a factory 17. its an edge spoke, so itd be hard to have it relaced for 18". I took a pic. ill upload it when I can.
2009 Suzuki DR650
W7AMF screwed with this post 11-13-2012 at 03:44 PM
Old 11-13-2012, 05:44 PM   #27
Airhead Wrangler
Adios Mexico
Oddometer: 6,543
That'd be off a R100GS or R - for a paralever final drive.
Old 11-13-2012, 08:23 PM   #28
W7AMF OP
Yeah Raft'n!
W7AMF's Avatar
Oddometer: 102
I think your right. Our BMW master mechanic pulled the wheel and final drive to put on his r80st. He says it should all bolt right up. It looks like a mono lever drive on his bench, ill get a pic Thursday of the drive and upload them both.
2009 Suzuki DR650
Old 11-13-2012, 09:20 PM   #29
Airhead Wrangler
Adios Mexico
Oddometer: 6,543
Don't think so. You need to machine down the center of the hub to fit on a monolever final drive. Doable, but not a quick and easy bolt-up.
Go look at part 4 here:
http://www.stephenbottcher.net/BMW/paraconv.htm
Old 11-13-2012, 10:15 PM   #30
bikecat
bikecat's Avatar
Oddometer: 1,117
For me the biggest advantage of the Paralever is the cross-spoked wheels which run tubeless tires.
Reason enough to want a Paralever over a Monolever.
Anyone has a link to a R1100/R1150 Paralever swap onto a Paralever R100X?
bikecat is offline   Reply With Quote
Times are GMT -7.   It's 07:15 AM.
