Old 10-30-2012, 01:08 PM   #1
norschweger OP
norschweger's Avatar
Oddometer: 242
Vibrations/grinding 950 in Vegas
Hi!
I feel some vibrations via my pegs that I do not like. When I accelerate it gets more, when I hold the speed it gets more constant, when I am in neutral or pull the clutch, there is nothing...
Could there be a connection between this and that the chain flew off some weeks ago? Any other possible reasons?
I am worried...
Does anyone know if the dealers in Las Vegas are ok or which one I should attend?
norschweger is offline   Reply With Quote
Old 10-30-2012, 03:34 PM   #2
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,431
I moved away from Las Vegas in 2004 so my info wouldn't be current. dad2bike is a Vegas guy.
Might send him a pm for suggestions.
Bgunn is offline   Reply With Quote
Old 11-11-2012, 09:58 PM   #3
norschweger OP
Oddometer: 242
Thank you for the answer. I cannot recommend the dealer in Vegas, nuff said.
The news are that the vibrations disappear when I take the luggage off. Even with a passenger (about 95kg) I could not feel it any more. Should I have it examined more closely before I head to South America?
Thank you
Old 11-11-2012, 10:26 PM   #4
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,585
double check:
the chain and sprockets, perhaps over tight? or old?
engine mount bolts, the lower aft bolt tends to get loose
check all rear frame mount bolts.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 11-11-2012, 10:44 PM   #5
norschweger OP
Oddometer: 242
The chain and sprockets are pretty new, I ride it on the loose side as I have a heavy load. But the bolts are no bad idea. I will check it tomorrow.
Old 11-11-2012, 11:23 PM   #6
vegastele
vegastele's Avatar
Oddometer: 384
Here is the new KTM dealer in town.
http://www.carterpowersports.com/ 702-795-2000
Here is the old one.
Sportsman Cycle (702) 641-6401
dad2bike may have better advice. Send him a PM. Try posting on my2wheels.com too. Lots of Vegas boys there. Good luck.
vegastele is offline   Reply With Quote
Old 11-12-2012, 08:34 AM   #7
norschweger OP
Oddometer: 242
in Colorado now
Thanks. I am no longer in Vegas. Was at Carter´s. Did not feel that they knew what they were doing...
Cheers, Toby
Old 11-12-2012, 09:21 AM   #8
bajadog
Running around knees bent
bajadog's Avatar
Oddometer: 85
The pre-2003 LC4 (620,625,640) had the main transmission bearing failure (ball bearings) that
some reported a vibration in the left peg before failure. Prolly not your issue, but just mentioning it.
bajadog is offline   Reply With Quote
Old 11-12-2012, 09:32 AM   #9
Dustodust
Dustodust's Avatar
Oddometer: 1,013
If you put on an aftermarket sprocket of a different Rockwell Hardness it could cause rapid wear of the countershaft causing the splines to disentegrate
Inside Line Moto in Orange County California is a bit west of Vegas but they have fast reliable service and extensive experience having been with a top KTM dealer for 15 years
they are closed today
Its near Disneyland and the beach so you can check out the awesome California blondes and Mickey Mouse while youre there
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 11-12-2012, 09:00 PM   #10
wreckinshop
super enduro
Oddometer: 53
Lvmr
Go to Las Vegas motorcycle rentals and service in Henderson they currently have some of the baddest ktm twins on the planet from 950s to 990s there also certified Ducati, BMW, and everything else European. 702 856-2100 ask for fabian.
wreckinshop is offline   Reply With Quote
Old 11-13-2012, 09:15 PM   #11
norschweger OP
Oddometer: 242
Thanks, but i am in Colorado now. I guess it is nothing major. I just try to get rid of as much stuff as possible to lower the weight and then it will all be good! : )
Times are GMT -7.   It's 05:28 AM.
