11-03-2012, 03:44 PM
#1 |
Oddometer: 27
Optimal / required fuel range
Hi There,
I m proud owner of Big Bird ( a yellow new ish stock DR650 ) the plan is to set it up for mostly day trips,but spend money on petrol instead on unnecessary flakes. As I m new to adventure riding I m looking for input as how many km one can expect between fuel stops in NZ. I know it depend on where and how one rides so all input is appreciated regardless of make of bike or location. Thanks |
11-03-2012, 04:31 PM
#2 | |
Oddometer: 1,169
11-04-2012, 01:56 AM
#3 |
Oddometer: 493
IMS seems popular. I like mine. 300km is plenty between pie, piss, and petrol stop. Your arse won't handle more than that anyway, particularly with the stock seat.
11-04-2012, 08:14 PM
#4 |
Uber Cyber Loafer
Oddometer: 2,919
Hi and welcome to ADVrider.
![]() Questions I would ask are: where about's are you (you might like to fill in your profile) and what sort of riding do you want/plan to do? A DR has a pretty reliable 200k until reserve, plus 60k's on reserve. In my opinion: If you're sticking to the main roads a stock tank is ok 90% of the time. But for example if you wanted to head around the east cape on a weekend that's 326 k's and fuel can be patchy if you miss a station or they've run out. An IMS tank will see you all the way around without any problems. For some of the longer cross country adv riders like clints MMM ride a stock DR tank is a bit on the small side. You can carry a small back-up tank if you need an extra few k's but for piece of mind it's nice to have the extra range. IMO: The 32 Litre safari tanks are overkill for NZ, and they're bloody cumbersome.
Kiwipeet and Kiwirob on the South Island Tractor Trek for Cancer Kids!! | Mike & Simon: London to Capetown! | M1K3Y | http://www.ecmot.org.nz |
11-05-2012, 12:38 AM
#5 | |
Oddometer: 27
Hi Thanks for the welcome! and for the replies. I m kind of new to forums and (hate computers with a passion) and this is why my profile not well filed out. I will get to it soon ish. I been commuting on Big Bird for about a year. and found I get very constantly 160 km until reserve. have not run the tank dry yet to find out reserve. Done a few bigger rides also ( only on eval SHs )like the TT2000. and fuel consumption was about the same. The reason I started this tread as I m staring to set her up for dirt. nothing serious at the beginning but keep adding as needed. (well as $$$$$ allows ). I have been lurking in DR forums and seems a lot of conversions to safari tanks. which is an extra 19 lt !! I was really interested if this is no a bit of overkill for the South Island? or 18 tl which will give me about 250 km + reserve be enough? And based on the replies it be ok. Thanks for inputs so far! |
11-05-2012, 11:10 AM
#6 |
Trans-Global Chook Chaser
Oddometer: 2,690
Yep, 18-20L is about right for NZ on a DR.
Cheers Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
11-05-2012, 11:44 AM
#7 |
Fair Weather Faggot
Oddometer: 1,283
I personally think you need at least a good 300k range.
My klr has a 300k to empty range and I start thinking about filling up at 200-230km if I come across a gas station unless I know for a fact that there is another one on my intended route comfortably within my range. Its not how far you can go on a tank of gas but how far you can go before your concern over where you next need to fill up starts to influence your rides route. I hate not being able to suddenly decide to go a different route because I'm already 200k into my range and I don't know exactly how many k's the new route is. more range is gooder unless the petrol weight compromises handling
These are the best days |
11-05-2012, 01:06 PM
#8 | |
Oddometer: 758
I consider 300km a minimum also.
02 & 05 DR650's 67 Ducati 250 Mark 3 Narrow Case 94 Beta Techno 250 Facebook Adventure Riding NZ Group Facebook Adventure Riding NZ News |
11-05-2012, 09:16 PM
#9 |
AKA Woodman
Oddometer: 461
What the old fella said is spot on.
11-07-2012, 12:31 AM
#10 | |
Oddometer: 2,203
aka BMWST?
11-07-2012, 12:40 AM
#11 |
Guzton
Oddometer: 124
as above
+1.
nothing worst than backtracking to Oturehua in the snow! with my 40l tank and Amals, hell i can get like 450km.
"Generally speaking , you aren't learning much when your lips are moving". |
11-14-2012, 12:10 AM
#12 |
Armature speller
Oddometer: 6,763
18L will get you 320-360km to reserve with the stock carb.
With a pumper, it changes to 320-360km to reserve. |
11-14-2012, 12:57 AM
#13 |
Oddometer: 758
Best I've done with my FCR so far is 318.7km off 17.8litres. I'm thinking I might drop the needle 1 slot and see what happens.
11-14-2012, 01:10 AM
#14 | |
Tyre critic
Fixed, silly!
Cheers, Colin KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread Quote:
11-14-2012, 10:45 AM
#15 | |
Armature speller
Oddometer: 6,763
Best I've seen is 360 to reserve... |
