Old 11-12-2012, 12:55 PM   #1
Rockwell OP
Rockwell's Avatar
Oddometer: 663
Please confirm triple clamp bolt torques on '07 990
Looking in the manual, it says 20Nm for the top triple clamp bolts and 15Nm for the bottom.
Doesn't this seem a bit low?
I'm just trying to make sure that I am looking at the correct bolts on the torque list for what I am trying to tighten.
Can anyone confirm that I am reading the correct torque values?
not all those who wander are lost | two earthlings ride around the world
Home | Photo Blog | The Route | The Bike | About Us | Participate!
Rockwell is offline   Reply With Quote
Old 11-12-2012, 01:21 PM   #2
6732cash
6732cash's Avatar
Oddometer: 161
I did mine today after a spring and oil change.... and yes thats what is says in the book....you are dealng with ally....if the front falls out I will let you know
6732cash is offline   Reply With Quote
Old 11-12-2012, 01:26 PM   #3
Rockwell OP
Rockwell's Avatar
Oddometer: 663
Great. I'll let you ride first, and, if I don't hear back from you, I'll know to tighten some more. :p
Another question since you've been working on the bike: does the right brake cable go through the right plastic wire harness (that's mounted to the bottom of the top triple clamp)? I don't have pictures of that area.
Old 11-12-2012, 01:34 PM   #4
6732cash
6732cash's Avatar
Oddometer: 161
ther is only one cable clip on the left as you sit on the bike and every thing goes through it 950 no abs
Old 11-12-2012, 01:43 PM   #5
Rockwell OP
Rockwell's Avatar
Oddometer: 663
Yes. There is one cable clip on the left and one on the right.
My right side has my throttle cables, signal/lights controls and clutch cables.
On the left, I have start/kill harness, brake switch, and I am wondering about the brake cable. Mine will be different since I have ABS. My brake cable runs to the bottom of the seat where the ABS is.
Old 11-12-2012, 02:02 PM   #6
6732cash
6732cash's Avatar
Oddometer: 161
You need someone with a 990
Old 11-12-2012, 03:19 PM   #7
sledstorm1
CT RAMBLER'S MC CLUB
sledstorm1's Avatar
Oddometer: 866
That's what they use on the dirtbikes also... Any tighter and you'll be squashing the inerds! Make sure you clean the insides of the triple and the tube itself.. and you'll never see them move useless you hit something....
To those who understand, no explaination is necessary
Too those who don't, none is possible...
sledstorm1 is offline   Reply With Quote
Old 11-13-2012, 02:22 AM   #8
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,128
The torque mentioned in the manual is correct. Too tight and the springs inside of the thin walls of the fork leg will rub due to over tightening.
The 990 has two clips on the top triple. The front brake line goes through the smaller plastic clip (called "brake hose guide top") on the right side.
GO !!! Berglund brothers #148 #149
GO !!! CS Santosh #59
Vicks is offline   Reply With Quote
Old 11-13-2012, 06:33 AM   #9
Rockwell OP
Rockwell's Avatar
Oddometer: 663
Thanks. I just assumed it went in there, so that's where I put it.
One last thing (for now, at least): Looking at the wiring diagram, the front brake switch looks like it functions just like a regular mechanical switch in which the wires can be swapped and still function the same way. Is this correct, or is this, internally, some kind of directional switch in which the positive needs to be connected to a specific terminal?
Old 11-14-2012, 05:36 AM   #10
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,128
It will work even if you swap the wires. Its just a contact switch without polarity.
Times are GMT -7.   It's 12:44 AM.
