09-23-2012, 10:34 PM
#61 |
Yankee
Oddometer: 4,460
I've no idea how many miles I have on mine Electrosport stator now, but I ride it frequently and it hasn't given me any trouble.
09-24-2012, 09:24 AM
#62 | |
Oddometer: 329
Cool hand Luke.
Nice to hear from you. I bought a 05 525 EXC for use here in Baja. Im stuck in Mexico for a year or so - needed to get a proper bike Would love to talk more bit im on the owners V Sat ...... Quote:
"Did you see that?" "Yea I saw that. I did it" Bruce Willis ------------------------ ’07 950SE for sale in Holland ![]() ’08 950SE being prepped for a ride through MX ’09 FE570 patiently waiting.. D K screwed with this post 09-24-2012 at 09:32 AM Reason: Because I wanted to |
09-24-2012, 01:59 PM
#63 | |
Oddometer: 95
As my bike sits right now it has a 10w led lowbeam, 35W heated grips, and 65W highbeam. If I change out the highbeam to a 40W led or 35W HID I would have more than enough watts to run full lights and grips indefinitely. Even as is I would be fine as I don't do any cold weather night riding where I would need everything turned on all the time. I am looking forward to getting the Trailtech unit installed and getting my bike running again! Cheers |
11-14-2012, 12:17 PM
#64 |
Oddometer: 95
I got the Trailtech stator a couple weeks ago and installed it. The install was way easier than the electrosport. Truly plug and play. The only thing that took me a while was reversing all the crap I had to do to get the electrosport stator to work.
I have only managed one commute into work on the bike (30 mins each way) and the stator seemed to work just fine. It also seems to start a little easier than before. I guess time will tell but I will probably feel better with the Trailtech in the bike. Hopefully it proves to be reliable. Winter has set in here so torture testing will have to wait until next year. I wish I went this route to begin with. Cheers |
01-05-2013, 09:41 PM
#65 |
Weekend Warrior
Oddometer: 812
Subaru -
Quick one for you from a mechanical engineer. What this means is that when people start talking about sparky stuff, I generally glaze over and pass out. But I can follow directions. With that said, I just installed a TT stator in my 2008 450 EXC. Easy peasy. What I don't understand is if I need to install their regulator/rectifier they supply - I guess I wasn't clear if I could just leave it alone with an AC system or if I'm forced to go DC. Thanks! Justin K_N_Fodder screwed with this post 04-22-2013 at 08:52 PM |
04-22-2013, 07:17 AM
#66 |
Oddometer: 95
Hi Justin,
Sorry I didn't respond earlier. I haven't looked at this thread in a long time. Hopefully you got this figured out already but yes I think you do need to install a DC reg as well if you installed the stator. Cheers |
04-22-2013, 12:48 PM
#67 |
beat up ex flat tracker
Oddometer: 6,766
Several friends have had the Trail Tech Stator quit dead during long rides,kind of an all at once load you bike in a truck and go home sort of thing.
Must both be flukes. I just keep it stock and run the bare minimum of electrical stuff,tiny LED taillight,Dirt Tricks Low draw fan,sometime a good LED headlight will be installed.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
04-22-2013, 01:07 PM
#68 | |
Oddometer: 4,923
Solution is a 3 phase series regulator, but the few ones that are available are too big for use on an EXC.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
04-22-2013, 09:05 PM
#69 | |
Weekend Warrior
Oddometer: 812
For us no-knowledge direction-following types, the Trail Tech directions could use some serious work. The directions themselves are pretty good, it's making clear what set of directions actually apply to your installation that aren't wonderful. Hear that TT? :) J |
05-09-2013, 12:47 PM
#70 |
Oddometer: 7
Wow... very nice thread!
Subaru, thanks for the diligent updates, including your results with the TT stator install. This kinda answers my question since I’m in the market to upgrade my Stator and ironically came across these Electrosport stators just this week. Here’s why I think I need the upgrade. Last couple times I got caught in the dark still on the low rpm single track with my highbeams on I got out of the trail, shut the bike off to cool down and had no battery left to e-start. Once kick started and h/b turned off bike ran and charged normally. I also just picked up a TT X2 Halogen headlight which claims 70w (still in shipping so I haven’t plugged it in yet). It sounds to me like the stock stator wont keep up the highbeam at idle or low idle. However this issue will just compound if I drop in the 70w headlight. Later down the road I plan on installing heated grips and a fan override switch so I don’t have to wait till the engine gets to critical temps before the fans kick in. My question still is the TT stator. They claim 100-110w and the 70w light + 12w fan + 20ish-w grips doesn’t leave much room for anything else (led tail light, blinkers, optional gps/phone charger, heated vest etc…). Can anyone share results with the TT stator running lots of accessories? |
05-09-2013, 02:51 PM
#71 |
Oddometer: 95
Basically with the stock system you have three circuits off of the stator.
1. Small amount of capacity dedicated to charging the battery. 30W 2. Majority of the capacity is AC current and this runs the lights. 70-100W 3. Ignition circuit. Separate coil that runs the bike (spark, cdi) I am not sure on the actual numbers anymore as I am going by memory. So no matter what you do with your headlight it won't change anything with your battery drain or charging ability. Your headlight will just be very dim at lower idle speeds and will brighten as your engine increases rpm if you increase its draw significantly. If you want better lighting you should look into getting some LED lights. These put out an amazing amount of light and don't draw much power. I think LED lights prefer DC power though. This is where the Trail Tech stator comes in. It gives you the regulator, stator and directions to convert the system over to all DC current. Now you would have two circuits. 1. Ignition circuit, same as before. 2. 100W charging circuit. You now have 100W going to the battery and any of your load gets pulled from the battery. So you can draw more than 100W as long as it is not consistently or for a long period as the battery will deplete. My current system; Low beam 10W LED High beam 65W halogen (soon to be replaced with 24W highbeam) Heated grips 30W Rad Fan 30-40W while running (??? guessing) GPS 5W Turn signals, brake lights, etc... If everything was running full blast I would kill my battery quickly drawing around 140W but that likely won't happen...ie. my rad fan and heated grips shouldn't be running at the same time. Nor do I ride at night a lot (high beam). But if I was ice racing, at night, in the cold...then maybe. I also have a LED voltmeter sitting on my dash so I always know my battery voltage. If it starts to drop or go too high I know something is wrong and I can fix it hopefully or turn something off. Another aspect of the TT stator is that is produces its full 100w right off idle. (So I was told by TT tech support!) this would be a good benefit for slow single track. The electrosport and the stock one need to get the rpm up a bit to generate peak power. I think you would be fine with all the accessories you want to have installed as long as you keep in mind the draw at any one time. Maybe you have to slow down and ride with your low beam while you have your heated vest cranked or something. Or go with LED lights.... Low beam 10W High beam 24W Heated vest 30W Heated grips 25W 89watts. Keeping in mind you will need some room to charge your battery but I think it is all manageable. Hope that helps and thanks for the thread compliments. I found little bits and pieces of info here and there but it was hard to find a good answer all in one spot. Cheers |
05-09-2013, 04:36 PM
#72 |
Oddometer: 667
Led
Correct, i added led lights to stock 530 charging system, with a new battery the led lights on and riding for hour the battery was dead. Upgraded to the TT
My favorite philosopher is Cha Ching ! |
