Old 11-14-2012, 09:58 AM   #91
Scampi6000
Scampi6000's Avatar
Oddometer: 24
Thanks man
The twin is a mile eating machine. About 60k on her now and just a fuel pump and reg/rec to replace around 20k ago.
Quick question I asked over on the Call all XR600 thread there a few days back. Have you had any experience using a small lead acid battery on the XR6 as opposed to those 6 cell NiMh ones you see installed thrown in above the airbox when adding DC? The lead acid just have a better lifespan and dont mind the constant charging.
______________________
'96 XR600
'98 Africa Twin RD07
Scampi6000 is offline   Reply With Quote
Old 11-14-2012, 10:46 AM   #92
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,151
I use 12v 1.2Ah lead acid batterys on all my XRs and they fit perfectly under the seat of the 600. They are the same type that are used in alarm systems so they're pretty easy to find, just about any electronics store will have them. And you are correct, they are much better than the NiCad packs that come with most DSKs because being topped up all the time kills the NiCads.
I'm still going to post that schematic for you, I've just been short of free time lately.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
"If it's hard to do, you're probably doing it wrong."
XRider is offline   Reply With Quote
Old 11-14-2012, 12:22 PM   #93
Scampi6000
Scampi6000's Avatar
Oddometer: 24
Perfect.
Thanks XRider. Just what I was hoping to use! Don't stress on the schematic. When ever suits. I'm up to my ears with work as it is anyway so shed time is at a premium these days!
'96 XR600
Old 01-11-2013, 02:11 AM   #94
Scampi6000
Scampi6000's Avatar
Oddometer: 24
Hey XRider,
Had any luck over the festive period to look at that schematic? After getting a renewed urge to get the XR6 finished after buying a few more final bits and pieces! Best purchase was an Arrow Dakar Replica can I found on ebay from Italy for a nice price
'96 XR600
Old 01-11-2013, 11:43 PM   #95
Off the grid
Needs to STFU
Off the grid's Avatar
Oddometer: 7,778
Nice build. I admire your dedication.
Wedding = $25,000
Divorce = $500
Brazilian 2nd wife = Priceless
2007 Triumph Tiger 1050 ABS
Off the grid is offline   Reply With Quote
Old 01-12-2013, 04:19 AM   #96
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 309
Originally Posted by Dr LC8 View Post
Hi,
So which ratio of compression you would go for?
Would I need a different carburettor?
Nic
My 2 sense:
I have a 86 XR250R. The motor is stock except for a 280 kit, ported head, jetting, K&N filter & a Supertrap muller. Cam is stock. I got great power & reliability out of this combo. Motor would rev forever.
I always wondered how much of this power came from the head porting and just letting the thing breathe. If one element in the flow process is resticted all the displacement, exhaust, cam mods will be handcuffed. Gotta look at the total flow throughout intake/cylinder/exhaust cycle.
I had the head ported instead of going with a cam because I looked at the porting as "free horsepower" instead of going with a cam/springs that tend to stress the valvetrain and risk losing reliability.
If I were to change anything now it would be the carb for the same reasons noted above.
Not saying it works on the 250s big brother but if reliability is a major goal...
wfopete is offline   Reply With Quote
Times are GMT -7.   It's 11:03 AM.
