Old 11-10-2012, 07:08 PM   #1
sonoran OP
incognito
sonoran's Avatar
Oddometer: 15,974
Cracked Rear Header
Bike sounded kind of loud today, looked underneath and saw what I thought was a small crack along the seam where the pipe is joined. After getting it out things look considerably worse.
Is this possible to be repaired via welding or is it a total loss?
sonoran is offline   Reply With Quote
Old 11-10-2012, 10:43 PM   #2
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 267
It should TIG weld fine.
I'd just look for a welding shop....
Should be less than 40 bucks.
Dave
pdxmotorhead is offline   Reply With Quote
Old 11-11-2012, 12:56 AM   #3
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Yep..... A mig will blow through it. They are very thin.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 11-12-2012, 08:16 AM   #4
quicksandfab
Experienced n00b
quicksandfab's Avatar
Oddometer: 21
It's Weldable
Sonoran,
That is weldable the trick is using the correct filler material and TIG welding of course.
I have done several pipes in similar to even worse condition succesfully using "Silicon Bronze" filler it tends to be a bit softer and tends to deter further cracking. If you don't know a good welder close by I would be happy to help out. I am out in North Scottsdale.
quicksandfab is offline   Reply With Quote
Old 11-12-2012, 09:46 AM   #5
Dustodust
Dustodust's Avatar
Oddometer: 671
might also be covered by warranty , ?
if not caused by damage
probably easier to just weld it like they said
I torch weld 2 stroke pipes all the time and they are pretty thin too
04 KTM 950 S
04 KTM 525 EXC street plated
Old 11-12-2012, 09:04 PM   #6
ride-for-life
Oddometer: 248
like said above, tig with silicon bronze the bronze filler will flex and not re crack that's the way too go. Where you at I would weld that up for you, I will be on the tig for the next few days at the shop.
RIDE HARD LIFE IS SHORT.
ride-for-life is offline   Reply With Quote
Old 11-14-2012, 03:58 PM   #7
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 282
Mig Tig gas or even stick (if you know a good boilermaker with an inverter) no worries.
Lc8grrr is offline   Reply With Quote
Times are GMT -7.   It's 07:38 AM.
