Old 11-14-2012, 02:46 PM   #1
woopwoop OP
will think for food
woopwoop's Avatar
Oddometer: 5,484
What's the difference between 700 & 800 engines?
What's the difference between the engine in the F700GS and the F800GS? I was told recently that the only difference is the "chip". Is that correct?
woopwoop is offline   Reply With Quote
Old 11-14-2012, 03:06 PM   #2
GH41
Oddometer: 822
It is probably more than the map. Some will argue but the performance difference is very small. GH
GH41 is offline   Reply With Quote
Old 11-14-2012, 03:20 PM   #3
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 389
Quite the opposite
I looked up the parts fiche (Max Motorcycles)
The engine control units are identical. (Same part number)
The difference is in the engine itself and the map loaded on the control unit.
Some of the parts that are the same:
Valves
pistons
Some of the parts that are not the same part number:
Cam shafts
engine
throttle bodies
So, perhaps change the throttle bodies and cam shafts would help.
However, the control unit may be keyed to 650/700 and only load that map.
Kiwi Tinkerer screwed with this post 11-14-2012 at 03:22 PM Reason: add info
Kiwi Tinkerer is offline   Reply With Quote
Old 11-14-2012, 03:45 PM   #4
ebrabaek
Oddometer: 4,757
Interesting about the Throttle body's. I knew that cams were diff...... I would suspect that the preforming part of the Throttle body's are the same... perhaps just cosmetic....
Erling
Old 11-14-2012, 04:11 PM   #5
LukasM
Oddometer: 5,424
Kiwi has it right, throttle bodies and cams are different, and the map that's loaded in the ECU. Everything else is the same, so upgrading to the same HP won't be difficult once somebody figures out how to crack the ECU. A German company has done it but I haven't been able to reach them. I also think that you will be able to get most of the power with an aftermarket fuel controller, probably even more than a stock F800GS because those run pretty lean. Ignition timing won't make as much of a difference.
I've got both F800GS and F650GS throttle bodies here, will have to see what the difference really is when I find some time in the shop.
Old 11-14-2012, 05:15 PM   #6
ebrabaek
Oddometer: 4,757
I for one is interested in that.......
Erling
Old 11-14-2012, 07:57 PM   #7
woopwoop OP
will think for food
woopwoop's Avatar
Oddometer: 5,484
Valves
pistons
Cam shafts
engine
throttle bodies
Thanks gents. A friend and prospective F700GS buyer was told the other (IE "chip only") by a salesman. I'm no expert but it didn't sound right...... The same salesman also told my mate the F700GS puts out 90 horsepower!
Old 11-15-2012, 05:25 AM   #8
JRWooden
Oddometer: 4,259
Interestingly the F800GT does crank out 90HP so there is yet another bits-and-pieces-ECU map set variation...
JRWooden screwed with this post 11-15-2012 at 05:35 AM
Old 11-15-2012, 10:31 AM   #9
pkbinder
Kissing Moose
pkbinder's Avatar
Oddometer: 279
Some things I know and some things I have only heard. My engine is the "de-tuned" 71hp engine. I have heard the the 85hp engine only generates 74hp at the wheel. I have no idea what my engine generated at the wheel before I did my modifications (Remus headers, Akropovic exhaust and PC-V controller), but the dyno tells me that now I get 74hp at the wheel. pk
Life is suffering until you realize that life is suffering.
pkbinder is offline   Reply With Quote
Old 11-15-2012, 02:08 PM   #10
JRWooden
Oddometer: 4,259
Comparing the F658GS to the F800GS
The F658GS has less lift on the cams,
more conservative ignition timing (and burns regular gas),
does not need the "secondary air" system that is provisioned into the valve cover but unused on the F658GS
there may be other things also ....
A nice table of the F650GS / F700GS / F800GS / F800GT would be nice reading material .......
Old 11-15-2012, 03:35 PM   #11
GH41
Oddometer: 822
Did you gear the 658 like the 800? If not there may be a little to gain at the wheel. 14 HP sounds like a lot for pipes and a PC. $100 per HP is cheap power! Almost to good to be true. GH
Old 11-15-2012, 06:49 PM   #12
LukasM
Oddometer: 5,424
74 at the wheel is good! Of course it totally depends on the dyno and the parameters the operator used. Was it a Dynojet or another brand?
Are you saying that gearing influences power?
Old 11-16-2012, 09:42 AM   #13
grandru
Oddometer: 15
The radiator is also smaller.
regards
grandru is offline   Reply With Quote
Old 11-16-2012, 02:29 PM   #14
itsatdm
itsatdm's Avatar
Oddometer: 4,902
That reminds me, what happened to the poster who stuck the F800 cams into his 650? The last post sounded like a call for help.
I do agree you can get more power by running a richer mixture and a fuel controller can do that. No free lunch, you will burn more gas.
All 3 versions have the same 12:1 compression ration, so ignition timing, duration of the cams and and overlap between intake and exhaust determine the difference between absolute power and an exploded engine.
I do not understand the quest for power. All versions give more than you need for dirt and just how fast do you need to go?
Times are GMT -7.   It's 12:15 AM.
