Old 11-15-2012, 01:07 AM   #31
brocktoon
brocktoon's Avatar
Oddometer: 257
So I got the big tube swingarm and the NTN 32203 bearings. Only problem is I'm missing the seals. The parts fiches (which, as mentioned before, have been known to suck) don't seem to show the grease seals shown here:
Am I missing them in the fiche? Anyone know where I can get them?
brocktoon is offline   Reply With Quote
Old 11-15-2012, 07:13 AM   #32
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,498
I just got new swingarm bearings a couple months ago and the seals came as part of the bearing. They aren't listed separately as far as I know. I ordered the BMW part though, not an equivalant.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-15-2012, 11:19 AM   #33
brocktoon
brocktoon's Avatar
Oddometer: 257
I think you're right. Well, crap. So much for saving money with the equivalent non-OEM bearing.
Old 11-15-2012, 08:20 PM   #34
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,478
Re-use the old seals. They look straight and in good shape. If there is enough grease in the bearing you should be fine.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 11-15-2012, 09:39 PM   #35
brocktoon
brocktoon's Avatar
Oddometer: 257
Nah, those aren't mine. That was just an example pic from earlier in the thread. I tossed the old ones -- hopefully into the unused parts bin and NOT in the trash.
Old 11-16-2012, 04:28 AM   #36
ME 109
ME 109's Avatar
Oddometer: 2,727
Go look in that bin brocktoon, you'll want those old seals. They're not a perfect fit as such however they will assist in keeping the crap out.
From what I've found it will be easy to grease the bearings through the 6mm allen key hole in the centre of the swing arm pivot pin, then just push the seal back into place. I reckon the grease will hold the seal in place quite well.
I only used the larger outer seal.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 12-24-2012, 09:59 PM   #37
brocktoon
brocktoon's Avatar
Oddometer: 257
So, those who've made the switch to a big tube swingarm: did you also switch to the later driveshaft boot and clamps? Having trouble getting mine to fit.
Old 12-24-2012, 10:43 PM   #38
Boxer Metal
Mad Scientist
Oddometer: 3,478
All of the driveshaft boots are the same. There is no early or late. make sure you have it installed ib the proper direction.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 12-25-2012, 12:17 PM   #39
brocktoon
brocktoon's Avatar
Oddometer: 257
So they are. I assumed since the /5 swingarm had a rectangular-ish driveshaft opening, whereas the big tube swingarm has a completely circular driveshaft opening, that they would've modified the boot to fit. Looks like the tension clasps were the only parts that changed -- probably lengthened. I'll get some longer clasps.
Times are GMT -7.   It's 08:05 AM.
