Old 11-14-2012, 07:44 PM   #1
alexgg OP
alexgg's Avatar
Oddometer: 189
vac leak?
Hi, I just installed new carby on bigger barrel. Tuned it up and everything seems to be fine within specs except - when I sharply close the throttle (two cables design) the revs gradually go to idle. I mean gradually: 3 -- 5 secs instead just comeback to 1.5k instantly. Cables are fine, carby jetted as most people do for my configuration. Anybody seen that weird behavior?
alexgg is offline   Reply With Quote
Old 11-14-2012, 08:56 PM   #2
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,171
Lean idle mixture.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 11-14-2012, 09:28 PM   #3
alexgg OP
alexgg's Avatar
Oddometer: 189
does it mean that pilot jet must go up size or two?
Old 11-14-2012, 09:46 PM   #4
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,171
Try the mixture screw first.
Old 11-14-2012, 09:59 PM   #5
alexgg OP
alexgg's Avatar
Oddometer: 189
Hmmm if I play with mixture screw it will increase or decrease revs. At the moment I have 1.5k rpm on idle very stable. Mixture screw is 2.3 out after tuning. Originally it was at 2.5.. I was using Mikuni man to tune up mixture and idle screws. Going in and out to extremes of mix screw was killing the engine. Could you tell me exactly how to try.
alexgg screwed with this post 11-14-2012 at 10:10 PM
Old 11-14-2012, 10:17 PM   #6
ParaMud
ParaMud's Avatar
Oddometer: 628
What bike?
Mainly posting so I can come back to this because my Girlfriend's klr is doing the same thing. I still need to drill out the idle screw to clean and check it.
08 wr250r
04 xt225
ParaMud is offline   Reply With Quote
Old 11-14-2012, 10:47 PM   #7
manic mechanic
manic mechanic's Avatar
Oddometer: 161
Raise the idle speed to ~2500 RPM. Adjust the idle mixture screw until the RPM achieves a maximum, then back out the screw maybe 1/8th turn. Restore the idle speed to the desired level. Go for a ride and see how it does.
'76 R90/6, '07 K1200GT
Rounder #6
MOA Ambassador
RA WI Regional Rep
manic mechanic is offline   Reply With Quote
Old 11-15-2012, 05:17 AM   #8
VStromTom
Oddometer: 1,579
Check the vac hoses, my KLR did the same thing after I was careless pushing on the vac hose behind the shutoff, not all the way over the bulge. Also, sure you didn't pinch the diaphram or that is doesn't have a small hole in it?
VStromTom is offline   Reply With Quote
Old 11-15-2012, 06:04 AM   #9
alexgg OP
alexgg's Avatar
Oddometer: 189
Carby is TM36-68 pumper flat-slide. Bike KLX350 big bore. There are no vac hoses on this kind of carby coz it is not CV. I will try to retune at 2500rpm and see what gonna happens...
Old 11-15-2012, 10:59 AM   #10
ttpete
Rectum Non Bustibus
Oddometer: 5,998
You might check that there's no split in the rubber adapter between the carb and head. To check for vacuum leaks, use an unlit propane torch and go around anywhere a leak might be. RPM will change if a leak is found.
15 BMW RnineT
09 Kaw Versys
ttpete is online now   Reply With Quote
Old 11-15-2012, 02:22 PM   #11
alexgg OP
alexgg's Avatar
Oddometer: 189
Thats smart idea... Something to have in mind for general knowledge!
Old 11-15-2012, 02:23 PM   #12
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,343
WD-40 works too but is messier.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Times are GMT -7.   It's 12:09 PM.
