Old 11-15-2012, 01:04 PM   #1
8jest OP
Oddometer: 18
Hagon Shock Bottom out
Hey,
I have 1981 R80G/S with a Hagon Monoshock. Seems to bottom out pretty easily on potholes and what not. It is a new shock. I was looking for adjustment recommendations. I am 200lb rider. The shock preload is set pretty soft at the moment. I ride solo most of the time with light loads.
8jest is offline   Reply With Quote
Old 11-15-2012, 08:46 PM   #2
mykill
odd
mykill's Avatar
Oddometer: 1,166
It is possible the spring is simply too soft for your weight.
Did you buy the shock new? Did they ask your weight?
If not PO might have been a little guy.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 11-15-2012, 10:33 PM   #3
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
That or crank up the preload and make do with watcha got and steer around the potholes.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-15-2012, 10:53 PM   #4
Mark Manley
On my way
Mark Manley's Avatar
Oddometer: 754
I have a Hagon on my '91 GS and think the standard spring is a little soft and I only weigh 140 pounds, I will see Hagon at the motorcycle show next week and plan to order a stiffer spring.
If it's in the Touratech catalogue then you don't need it
"You've got to think for yourselves! You're all individuals!"-Brian of Nazareth
Mark Manley is online now   Reply With Quote
Old 11-16-2012, 12:03 AM   #5
pommie john
pommie john's Avatar
Oddometer: 1,474
Before you buy new springs or shock try to get this one set up properly.
Set first set the sag. That's the amount of suspension movement that is taken up with you sitting on the bike.
A reasonable starting point is to have the bike move through 1/4 to 1/3 of total suspension travel with the rider sitting ( feet up so you may need help balancing the bike). This is adjusted with the pre load.
If you can't get this sag correct with the pre-load adjuster you may need a stronger spring.
If it still bottoms out with the sag correct try dialling in some compression damping ( if the shock has it adjustable). If not try increasing the rebound damping because some Hagon shocks have the compression and rebound damping increase together.
Let us know how you get on.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 11-16-2012, 01:08 AM   #6
8jest OP
Oddometer: 18
Thanks, that is all really good info. It is a new shock but the previous owner had spec'd it out. I have the receipt and it was purchased this year from Capital Cycle. When I first noticed it, I did increase the preload. It was a stiffer ride but I do think it helped a bit. I noticed it again, so I backed it off again. Perhaps the previous owner was a lighter guy and I might need a stiffer spring down the road. I am first going to adjust the damping because, as mentioned, it the damping controls the compression as well, that could help a lot. If not, I will play with the preload again getting the appropriate sag and then adjust the damping again. If no dice, avoid potholes until I can "spring" the cash. Eh oh!! I feel like it is promising though as I checked capital cycle and they only two gain shocks listed for the r80g/s. and looking at the details those two listings have the same item number HA-6002. It seems like if there were different springs based on your weight, then that should be an option on the checkout. I emailed hagon sales as well and hoping to get some feedback there. Ill keep you posted.
Old 11-16-2012, 10:43 AM   #7
8jest OP
Oddometer: 18
So, I got an email from Hagon sales and he said that their shocks were capable of carrying rider/pillion combinations of up to 28 stone. That is 392 lbs! He asked me to send the part number and he will send the stock settings and further instructions on damping control, so I will forward that info back here. Also, I am going to start using stone instead of pounds.
Times are GMT -7.   It's 01:11 PM.
