Old 11-16-2012, 12:32 PM   #31
elron
Still Standing
Oddometer: 312
Why SAS removal on FI?
I understand the cannisterectomy, these bikes will get dumped and then then the can will flood. But other than very minor weight reduction and yes less stuff 'under the hood', I don't get why you'd want to do a SAS removal on a 990 FI. The ECU is set up for it, you have to 'fool' it into not knowing it's gone so nothing changes ECU wise. And as far as I know the SAS is not causal regarding hesitation and/or performance issues for an FI 990 (except sometimes after you do it). The Secondary Air System is an emission control system, yes...what's wrong with that? Seems a responsible thing to do in this day and age as those who enjoy recreating in the great outdoors.
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, totally worn out and screaming "WOO-HOO, what a ride!!"
elron is offline   Reply With Quote
Old 11-16-2012, 12:57 PM   #32
Masa
Masa's Avatar
Oddometer: 301
AFAIK the SAS system is only used during the warm up period. And if you have an after market exhaust it doesn't do any good to have on. I believe the main reason to get rid of SAS is to clean unnecessary plumbing.
Masa is offline   Reply With Quote
Old 11-16-2012, 07:47 PM   #33
Katoom119 OP
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
The hesitation on my bike was there when I bought it new from the dealer, so the SAS/Canisterectomy didn't have anything to do with it.
I did make it a bit better by installing the crossover hose between the rear cylinder/left side plug and the front cylinder/right side plug that I said to remove and replace with bolts.
That being said, the only way I found to get rid of the hesitation completely was to use TuneECU.
Yep. I put on a set of Wings and didn't need it so I figured I'd get rid of everything while I was at it. I put the Wings on it because the stock exhaust got so hot I honestly could forsee someone being burned on it very badly. You could feel it radiating off the exhaust cans.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 11-20-2012, 06:57 AM   #34
trickster
Greek n00b
trickster's Avatar
Oddometer: 24
Thanks for your answer. Since i'm running akra map there's little left to tune through tuneECU. Perhaps it's getting a little rich before revving to higher rpm. I believe when i replace my filter with a cpr like filter i would get more air. Best case would be getting it tuned by a professional but i suspect that there aren't many here in Greece to do such tunings.
trickster is offline   Reply With Quote
Old 11-20-2012, 07:05 AM   #35
trickster
Greek n00b
trickster's Avatar
Oddometer: 24
As others already mentioned it SAS is practically useless after replacing stock exhausts. Also by replacing stock exchausts you get rid of the catalytic converter which is also irresponsible. That makes half or more user of adv forum irresponsible and so on.. but that conversation would be trolling on this thread i'm waiting/getting information
Old 11-20-2012, 11:01 AM   #36
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
I had an Akra map in mine and with TuneECU my tuner went in and just made the Akra map better. I actually got a lot more MPG out of mine.
Old 11-20-2012, 11:36 PM   #37
trickster
Greek n00b
trickster's Avatar
Oddometer: 24
If i'm not going a bridge too far would you be an open source fan or windows 8 user??
Old 11-21-2012, 08:14 AM   #38
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
Don't know what own source is and after many years of Windows I converted to a Mac and haven't looked back.
Old 11-21-2012, 11:47 PM   #39
trickster
Greek n00b
trickster's Avatar
Oddometer: 24
I was just querying you if you would be kind to share your tuned map with the rest of us.
As the story goes open source code (meaning linux, unix etc) are made of people sharing code with each other and have made it to be technologicaly on par with windows without paying for expensive licenses and patterns owned by collosal companies. On the other side windows you still have to pay everything. Same goes to apple and macs.
Perhaps you've already gave me an answer by pointing out you're an apple user. In that case cheers to you again, no hard feelings whatsoever
Old 11-22-2012, 03:26 AM   #40
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
I actually don't have the map file but I'll see I I can get it and put it up.
Old 11-22-2012, 05:17 AM   #41
trickster
Greek n00b
trickster's Avatar
Oddometer: 24
Thanks a lot katoom! You are the man
Old 03-22-2013, 12:48 AM   #42
orange spy
diddly squat
Oddometer: 33
I don’t want to start yet another thread for SAS removal problems so here I am
after I did the removal I had some idle problems which I fixed with the 15min reset. However now that the idle problem is out of the way, I noticed another strange thing. At idle, I smell some unburned fuel. It happens in the morning at start up or even at stopping lights. I don’t have any leak from somewhere.
any thoughts?
orange spy screwed with this post 03-22-2013 at 02:58 AM
orange spy is offline   Reply With Quote
Old 03-22-2013, 01:51 AM   #43
Masa
Masa's Avatar
Oddometer: 301
Did you forget to plug the hole in the rear of the air filter box, where the SAS hose was connected?
Old 09-04-2014, 05:29 PM   #44
Surfdog
Surfdog's Avatar
Oddometer: 436
FI blinking
Katoom119
excellent write up & pics. I thought I followed it pretty good.
This is my second canisteretomy & sas removal.
But the FI will not stop blinking... any trouble shooting ideas would be greatly appreciated....
Noli nothis permittere te terere !
Surfdog is offline   Reply With Quote
Old 09-04-2014, 08:18 PM   #45
deeve
DumbA$$
deeve's Avatar
Oddometer: 1,259
Did you put the resistors in the SAI and canister pumps?
2010 KTM 990 Adventure-Nuclear Fusion Powered
deeve is offline   Reply With Quote
Times are GMT -7.   It's 01:35 AM.
