Old 11-13-2012, 07:40 PM   #16
RTCHIEF
Oddometer: 289
brakes
New brake pads resurface the rotors to a degree. Has anyone ever tried making an abrasive pad that would take the place of the current rotor pad and resurface the disc when ever you used the brakes? Jon
RTCHIEF is offline   Reply With Quote
Old 11-14-2012, 07:28 AM   #17
Rick Lee
Rick Lee's Avatar
Oddometer: 1,222
Originally Posted by lkchris View Post
Taking the lip off is pretty funny. This is the place the pads never contact.
That's true, but it makes visual inspections a lot easier. I just feel the lip on car rotors. If you can take it down to even with the rest of the surface, it's a lot easier to watch for a lip to develop than to mic it out.
'08 R1200GS
'96 993 C2
Rick Lee is offline   Reply With Quote
Old 11-14-2012, 07:42 AM   #18
dualsportride
Oddometer: 211
I wouldn't chance it unless you just can't find a rotor for your bike. I would try to save a few bucks somewhere else breaking is just to important on any object in motion.
dualsportride is offline   Reply With Quote
Old 11-14-2012, 08:43 AM   #19
SloDon
SloDon's Avatar
Oddometer: 488
Me thinks you have way too much time on your hands..........apparently I do to.........
Sent from my iPad using Tapatalk HD
SloDon
'09 R 1200 GS Adv, '05 DRZ 400, '08 RE Bullet 500
http://www.youtube.com/user/SlooDon#p/u
Don't grow up.......it's a trap!!
SloDon is offline   Reply With Quote
Old 11-14-2012, 08:43 AM   #20
def
I have little to say
def's Avatar
Oddometer: 6,323
Send a message via Skype™ to def
Yes it is.
def is offline   Reply With Quote
Old 11-14-2012, 08:58 AM   #21
def
def's Avatar
Oddometer: 6,323
Brake pulsing is usually the result of pad residue on the rotor which causes uneven friction on the swept area of the rotor. This residue is deposited when you hot brake to a stop and keep/retain the front brakes clamped on the hot rotors.
This practice transfers some of the material in the pad to the rotor resulting in pulsing brakes (especially true for front brakes).
The rear can also develop this phenomena but not as frequently. The typical fix is to sand the brake rotors to restore a fresh metal surface and remove the offending pad residue.
When hot stopping, one you are nearly stopped, release the hot front brake and use the cool rear brake to hold your position.
Motorcycle brake rotors should not be resurfaced. There is not enough material to allow resurfacing.
New rotors are the safe way to restore reliable braking along with quality pads.
Old 11-14-2012, 09:17 AM   #22
Iron Rey
Oh shit, not him!
Iron Rey's Avatar
Oddometer: 731
DO NOT resurface your rotors, if they have either groves or are less than the minimum thickness, replace them, come on guys, they are not that expensive and if you are looking to save a few bucks this is the WRONG place to do it. For years none of the major manufacturers have recommended resurfacing, break systems have become one of the most technically advanced areas of most bikes, this time, do the right thing.
Iron Rey is offline   Reply With Quote
Old 11-14-2012, 09:36 AM   #23
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 11,254
$650 + shipping to replace the rotors on an 1100gs with oem parts.
that is pretty damn expensive to me, given what they are ( a steel disk with some holes in it)
"A little inaccuracy sometimes saves a ton of explanation."
- H. H. Munro (Saki) (1870-1916)
mouthfulloflake is offline   Reply With Quote
Old 11-14-2012, 10:04 AM   #24
def
def's Avatar
Oddometer: 6,323
I would not use OE brake parts due to expense.
I use EBC rotors and pads. Excellent quality and less than 1/2 the price of OE.
Old 11-15-2012, 11:09 AM   #25
Iron Rey
Oh shit, not him!
Iron Rey's Avatar
Oddometer: 731
What def said.
Old 11-15-2012, 01:51 PM   #26
solohvs
somewhere around the bend
solohvs's Avatar
Oddometer: 156
Brembo Rotors
Bike Torque Racing in the UK - extensive selection of Brembo pads and rotors IN STOCK.
www.biketorqueracing.co.uk.
My order was shipped almost immediately and arrived in DAYS - shipping from Britain must not be all that difficult any more. And they have the Brembo logo stamped into the metal.
About $500 plus $50 shipping.
Cutting corners on the BRAKES??? Maybe not.
solohvs is offline   Reply With Quote
Old 11-16-2012, 06:41 PM   #27
def
def's Avatar
Oddometer: 6,323
I don't understand ordering brake parts from the UK. There are several reliable dealers here in the US that sell and support excellent aftermarket brake parts such as brake lines, pads and rotors. I have replaced both lines and rotors with aftermarket from these folks...
http://www.cyclebrakes.com/html/our_products.html
There are others, as well.
My rear replacement EBC rotor was about $130.00.
Old 11-16-2012, 10:11 PM   #28
johnjen
Mod-U-Later
johnjen's Avatar
Oddometer: 13,515
One technique to resurface rotors is to use new pads, as in 2 or 3 sets in a row to wear down the high ridges.
This is of course if you are really in need of using up spare time.
JJ
QUOTE from vermin
I lie to myself because I am the only one who continues to believe me.
johnjen is online now   Reply With Quote
Times are GMT -7.   It's 01:10 AM.
