Old 11-15-2012, 09:06 PM   #16
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,160
Originally Posted by mfp4073 View Post
Do rotors go out a bit at a time...meaning do they get LESS efficient and then finally stop working or are they one day they work and next day they fail?
Next, when I got my new brushes in, they didnt have any insulation on the leads. My old brushes did, so I put some shrink wrap on them because it looked like they needed to be insulation from the housing. Thoughts?
Think of the rotor as a chunk of steel with wire wound around it. The rotor accelerates and decelerates with the crankshaft and inertia wants to keep that mass either still or in motion. The steel of the rotor is solidly fixed to the crank so that's not a problem. But that coil of copper wire is epoxied in there and can work loose over time. Then it works back and forth and can either short to the steel or separate causing an open.
Another failure point is where the wire goes through a small opening to the inner sanctum where the coiled wire lives. It can chafe on the opening and ground out there.
Inertia is the enemy here. High temps don't help either.
As for the insulation, I don't recall if they have any or not. The housing is plastic, so there's no conductivity there. I'm sure some insulation wouldn't hurt, just make sure the heat shrink doesn't interfere with the brushes sinking deeper as they wear.
Old 11-16-2012, 05:23 AM   #17
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,748
Well put, Wirespokes.
Common sense and periodic maintenance will go a long way in ensuring a trouble-free charging system. No matter what system you have.
One thing to be careful about on stator removal is when you are nudging it out of the timing case is to very gently push only on the iron stator laminations. Not ever the copper stator wires, or on the aluminum housing. The stator can be compromised, and the damage can be subtle and not show up right away. And put a thin film of grease or anti-seize on the joint between the stator laminations and the timing case cover. This will minimize future corrosion between these dissimilar metals.
Carry a proper rotor removal bolt. You can piece together something from junk parts that may work, but you can also screw the pooch. Bigtime.
If you seriously travel, tour or ride frequently, pick up a spare rotor. Even if you have a half-kilobuck ultimaet system. Rotors can and do fail.
--Bill
'73 R60/5 Toaster
Old 11-18-2012, 01:38 AM   #18
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,519
Common point of damage to the winding.
boxerboy81 is offline   Reply With Quote
Times are GMT -7.   It's 11:05 PM.
