Old 11-18-2012, 09:44 AM   #16
Bob_M
Bob_M's Avatar
Oddometer: 157
Careful with that Toluene. Its real nasty stuff, don't try to huff it out of a paper bag just to see what happens.
Can you just completely fill the pipe with epoxy? I'm thinking this would encapsulate the wiring and coat the back of the LEDs too. You can thin epoxy with isopropol alcohol rather then Toluene.
You should find something on McMaster Carr's web site, evenjust for some guidance they have everything. If it isn't on their web site, try Googling Loctite or Henkle or 3M for potting material compatible with PVC and water proof. I think you will find something that will work. This is not a difficult potting application. Does it have to withstand high pressure of thermal cycling?
Bob
1996 Gas Gas JTR270, 2001 Ducati ST4
1977 Honda 750F2, 1970 Honda QA50
Bob_M is offline   Reply With Quote
Old 03-23-2014, 07:24 PM   #17
Digger1 OP
Digger1's Avatar
Oddometer: 14
For anyone who is still interested, here is a link to the little project I was working on (see the group of posts starting with post #532):
http://www.klr650.net/forums/showthr...=69754&page=27
Thanks to all who helped with this little problem!
"Thelma" - 2007 KLR650; Aztec Red; 1K miles
"Louise" - 2007 KLR650; Ebony; 1K miles
www.astronautbiker.com
Digger1 is offline   Reply With Quote
Old 03-23-2014, 07:39 PM   #18
Beezer
Oddometer: 5,734
why not use the pvc cement made for the pipe? I have a friend that uses it to seal the floats on his seaplane & swears by it for that... he's been using it for years & it seems to work (I have other opinions as far as airplanes are concerned).
Beezer is online now   Reply With Quote
Times are GMT -7.   It's 12:33 AM.
