Old 11-16-2012, 01:29 AM   #1
Wildman OP
Man of Kent
Wildman's Avatar
Oddometer: 16,084
Heavy-duty inner tubes
Got a trip to Iceland in the planning so lots of gravel. Went to purchase some heavy-duty, Continental MX inner tubes yesterday and saw it stated that they were, "not for road use". Continental covering their ass or a genuine problem at road speeds? What inner tube do you use?
"Every county of England, every country of Europe and every (part of every other inhabited) continent of the Earth" ... 80% complete!
Counties: 39 of 39 - done!
Countries: 36 of 42; last up, Portugal, next up, Iceland
Continents: 5 of 19; last up, North America (USA), next up, Central America (Cuba)
Wildman is online now   Reply With Quote
Old 11-16-2012, 02:34 AM   #2
Wargasm
Oddometer: 57
probably something to do with highway speeds and balancing with the inner tubes installed. The ones I installed said the same thing, no problems at highway speeds yet.
By the way have you ever thought of adding Kevlar in between the tire and tube to guard against puctures? I head about desert race bikes having done this, couple layers of ballistic kevlar between tuba nd tire supposed to add a lot of punture resistance.
Wargasm is offline   Reply With Quote
Old 11-16-2012, 02:35 AM   #3
freetors
Oddometer: 346
Don't worry about it. You should be fine but I always cover the tube and inside of tire with talcum powder to keep the friction and heat down.
freetors is offline   Reply With Quote
Old 11-16-2012, 02:55 AM   #4
cristi-mic
cristi-mic's Avatar
Oddometer: 94
Send a message via Yahoo to cristi-mic
I'm using Continental Ultra Heavy Duty tube on front tire (5mm thickness) and there are absolutely no problems.
On the rear tire I just transformed the rim into tubeless, more than 25.000km without problems.
http://cristi-mic.blogspot.com/
cristi-mic is offline   Reply With Quote
Old 11-16-2012, 05:06 AM   #5
sTE610vE
sTE610vE's Avatar
Oddometer: 1,665
If you're worried about pinch flats I can see HD tubes, otherwise I would just go with standard tubes, much easier to mount without pinching and if it's a puncture flat the thicker tube might last longer with just a tiny thorn or rock in the tire, not sticking thru very far, but anything that sticks thru the tire much at all will get thru a hd tube too, my 2 cents worth
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com
Husqvarna TE630
Husqvarna TE610E (for sale)
Cagiva Gran Canyon
sTE610vE is offline   Reply With Quote
Old 11-16-2012, 05:57 AM   #6
Wolfgang55
Wolfgang55's Avatar
Oddometer: 2,958
thicker is better
Have been using the 5mm super duty w/ ''Ride-On'' inside each for 6 tire changes.
They do make the turning of the wheel/rims heavier than the stock thin tubes but I will always add the super duty tubes at the first tire change on all of my scoots.
I don't care as much about the speed decrease but I do like the "keep going'' factor that both 5 mm tubes & ''Ride-On'' afford me.
Wolfgang55 is offline   Reply With Quote
Old 11-16-2012, 07:17 AM   #7
Ride-a-lot
Oddometer: 141
This past summer before riding the Oregon BackCountry Discovery route I ordered Michelin heavy duty tubes to put in the tires on my Husky. When the tubes arrived I was shocked at the size of the box they came in. The box was barely smaller than the box a new pair of boots came in. I weighed the tubes and together they were just under 8 pounds. I don't think I will be using heavy duty tubes again because of how much they weigh and how much harder they are to put in. The suckers were a bitch to install.
I guess they worked because after 6 days of solid offroad riding I had no flats. Of course neither did the other 2 guys I was riding with that had normal tubes in their tires.
Tom M.
Salem Or.
'93 K1100LT '09 F650GS '08 TE-610
Ride-a-lot is offline   Reply With Quote
Old 11-18-2012, 01:49 AM   #8
Wildman OP
Man of Kent
Wildman's Avatar
Oddometer: 16,084
Cheers guys.
Old 11-18-2012, 06:54 AM   #9
AZcacti
Dope on a Rope
AZcacti's Avatar
Oddometer: 1,316
I gave up on the HD tubes since nails and screws are my main causes of flats.
AZcacti is offline   Reply With Quote
Old 11-18-2012, 10:16 AM   #10
DaymienRules
Traffic target
DaymienRules's Avatar
Oddometer: 120
I find the HD tubes are generally just as easy if not easier to install than regular tubes. My technique is to put a few psi into them before installation, so they're inflated to shape first. I run the ultra heavy duty's whenever possible, and keep the std thin front tube on the bike as a spare.
DaymienRules is offline   Reply With Quote
Old 11-19-2012, 12:13 AM   #11
BigToad
The Bone Destroyer
BigToad's Avatar
Oddometer: 189
In my experience the hd tubes heat up to much at hwy speeds and cause excess tire wear, therefore not my first choice for road trips. However you say its gravel road so if you don't rip ie keep the speed down its hard to beat an HD tube. I generally add air for paved or higher speeds to avoid heat.
On my xr650r I use the tubliss system and have had exceptional results. That would be my choice for a smaller bike, being able to stick a plug in a nail hole and ride on is awesome. I have yet to test the tubliss system on a long trip and of course it's not DOT approved...but I will be using them on the TAT or CDR trips planned.....
R1200 GSA
XR650R dualsport/Rally Trainer
We should come home from adventures, and perils, and discoveries every day with new experience and character
BigToad is offline   Reply With Quote
Times are GMT -7.   It's 01:47 AM.
