Old 11-17-2012, 04:49 PM   #1
mrbindc OP
Oddometer: 75
Oak Okleshen bean can rebuild
Has anyone had their bean can rebuilt by Oak? Apparently he services them, there was a decent write up in the last issue of Airmail about it.
According to AirMail:
With Oak Okleshen as our technical editor, it is also the definitive source on airhead technical matters. Oak is both an engineer and a former BMW service shop manager who has been consulted by BMW on several sticky technical issues (which he unravelled.) There is no better source for uncompromised technical advice.
I'm looking for a cheaper option than a new one or the Alpha unit.
mrbindc is offline   Reply With Quote
Old 11-18-2012, 08:56 AM   #2
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,524
How about an after market. This looks like an up grade to the stock system;
http://www.advrider.com/forums/showthread.php?t=660613
---Albert Einstein
disston is online now   Reply With Quote
Old 11-18-2012, 01:48 PM   #3
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 544
If Oak does it, you can be sure that is done right.
We call that "Skookum" out here in the PNW.
Cheers, Jon-Lars Sorenson
Beverly, WA
http://www.facebook.com/BMWR90S
Jon-Lars is offline   Reply With Quote
Old 11-19-2012, 02:15 PM   #4
supershaft
because I can
Oddometer: 9,116
Oak is definative? Well, I am glad he has come around to the other side of the fence on some issues. The question now I guess would be which side of that fence was definative?
Oak rebuilds them, I rebuild them, lots of people rebuild them from what I can tell.
Old 11-20-2012, 05:31 PM   #5
mrbindc OP
Oddometer: 75
Thanks Supershaft
I believe my '81 R65 has a faulty Hall sensor. It seems to die in the hot summer while I'm in stop and go traffic and run fine in the cooler Fall/Spring. Also idles very high (2-2.5K rpm) once the engine is hot. My usual fix is to pull over and wait for it to cool down and then drive it home once the traffic has cleared. It has a newer ignition module and a brand new Dyna brown coil.
Do you have a ballpark figure for servicing bean cans? Some suggest just buying a new one or the Alpha unit rather than go for a "rebuild" on the OEM unit.
Old 11-20-2012, 05:36 PM   #6
weeman
weeman's Avatar
Oddometer: 59
We're really "Skookum" up here!
weeman is offline   Reply With Quote
Old 11-20-2012, 06:01 PM   #7
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 544
You are revealing much about yourself, FH/SS.
Later,
Beverly, WA
Jon-Lars screwed with this post 11-20-2012 at 06:11 PM
Old 11-22-2012, 02:15 AM   #8
chasbmw
Oddometer: 2,256
There are a number of cheapish after market alternatives to the bean can, this has the advantage that you get replace all the 30 year old BMW components in one shot AND that you end up with the proper electronic ignition rather than the half arsed part mechanical/part electronic gnition that BMW bought in from Bosch because that was the design that Bosch was fitting to VW rabbits.
I would fit a Sachse alternator mounted ignition, lots of ignition curves ready for when you decide to dual plug your bike.
Charles
1971 Commando Fastback
Times are GMT -7.   It's 04:01 PM.
