11-18-2012, 05:43 PM
#226 | |
XRated
Oddometer: 810
Kubiak, What tires are you running? I may try some knobies for my sumo tires... Cheers, Cumbacheech |
11-18-2012, 07:48 PM
#227 |
Oddometer: 4,246
hey Cumbacheech hows it going! right now im running a 4.60x18 front tire in a shinko 244 model. this thing has over 5,000 miles on it and still works like new. the rear is a 180x80x14 stock tw200 bridgstone tire with about 4,500 miles.they passed the test and im going to run this combo for awhile.
11-18-2012, 07:51 PM
#228 | |
Oddometer: 4,246
11-20-2012, 11:01 AM
#229 |
The DingDandKid
Just under 9,000 on mine. They will last a long time, I'm doing about 50/50 riding on mine.
2006 TW200 85mpg 1981 Honda CM400T How about some camping in Pennsylvania? How am I supposed to think out of the box; if they don't let me out of the box? |
11-20-2012, 07:52 PM
#230 |
Oddometer: 4,246
11-20-2012, 07:54 PM
#231 |
Oddometer: 4,246
more impressive is the front shinko 244 tire. its got about 5,400 miles in the pic and has a ton of tread left.
11-22-2012, 09:44 AM
#232 |
Iron toocus
Oddometer: 956
Was it not an option to lace the tw rims to factory hubs for the conversion?
2009 Aprilia SR50 R Factory 2012 Bont Vaypor Custom 2pt My drivel \/ http://chillislives.blogspot.com/ |
11-22-2012, 11:28 AM
#233 |
Oddometer: 4,246
11-22-2012, 12:55 PM
#234 |
Iron toocus
Oddometer: 956
I would like to do this mod to another bike but using a factory hub laced to tw rims to maintain disc brakes and factory function.
Which swing arm would take such a chubby tire...
11-22-2012, 09:50 PM
#235 |
Oddometer: 4,246
im not sure what other bike has a wide swingarm, the dakar was one of the wide ones and made of steel so very easy to modify. time to get the tape measure out and checking bikes!
12-01-2012, 11:36 AM
#236 |
Oddometer: 4,246
i also narrowed the tw hub by taking off the outer seal and bearing sleeve end. i left enough sleeve for 1 bearing on each side where originally the hub has 1 bearing on one side and two bearings on the sprocket drive side.this narrowed the tw hub by about 3/4 of and inch to help squeeze it into the gs swingarm even after widening the gs swingarm about a half inch or so.
12-13-2012, 11:54 AM
#237 |
Oddometer: 4,246
![]() got my gps ready to go. |
12-20-2012, 12:50 PM
#238 |
Oddometer: 4,246
![]() painted ktm front fender white and changed black fork gaurds for white. easier to keep clean.cant believe the front tire has 6,000 miles on it now and all kinds of tread left! |
12-20-2012, 12:53 PM
#239 |
Oddometer: 4,246
rear tire not doing as well. it has 5,400 miles but see if i can get 6,500 out of it.
12-20-2012, 12:56 PM
#240 |
Oddometer: 4,246
![]() front view of white parts. |
