Old 11-20-2012, 03:13 PM   #24631
tunp
tunp's Avatar
Oddometer: 208
Max Battery flashing
Ok first post in here, and yes i tried to search but my patiance of looking thru multiple pages is not there.
So i went to an LED headlight, and i get the max and battery symbol both flashing on dash, i guess the lite does not draw enough. Anything to worry about? can something be added inline to help ?
thanks
Oh and by the way an 07 TE i bought about 7 months ago, love it.
Ridin w/ a smile
Tony A
02 FLHT, 11 990 adv, 07 TE610
tunp is offline   Reply With Quote
Old 11-20-2012, 03:22 PM   #24632
shootis
shootis's Avatar
Oddometer: 102
thanks
That's strange,, I just installed my new LED headlight today but everything is fine with mine.
Maybe something got dislodged in the process?
shootis is online now   Reply With Quote
Old 11-20-2012, 03:28 PM   #24633
reimorei
Brazillian Adventure
Oddometer: 7
My new to me TE 610
Pulled the trigger on a 2007 TE 610 with 3.000km (2.000 miles). Just ordered a LV complete exhaust system and may will try a JD jet kit as it's a carbed model. So far just changed rear tire as it came with a DS tire. Will check cam chain tensioner when it's around 6.000 miles. So far loving the bike in some 4x4 roads and light trails, but found the suspension to be on the stiff side.
I'm 5'6" tall and 165 lbs w/o gear, but the bike height isn't an issue as I've ridden enduro bikes since when I was a kid.
reimorei screwed with this post 11-20-2012 at 03:34 PM
reimorei is offline   Reply With Quote
Old 11-20-2012, 03:41 PM   #24634
CA Stu
CA Stu's Avatar
Oddometer: 42,601
Originally Posted by Schelbi View Post
It's good to keep an eye on download links but not every download is illegal!
The parts list of some Husqvarna bikes for example can be downloaded from the Husqvarna Germany homepage:
http://husqvarna-motorrad.de/index.php?id=738
This is definitely legal!
Originally Posted by Taranis View Post
Indeed. Both of those links go to the parts manuals.
The service manuals are copyrighted.
CA Stu is offline   Reply With Quote
Old 11-20-2012, 03:48 PM   #24635
motopreserve
Oddometer: 109
iBeat help
Wondering if anyone has a link to an iBeat primer. I've searched and searched and can't find any basic how-to type info (or troubleshooting). I just got the rig, and wondering how to take advantage of it for my 2009 te610.
My primary goal was to reset my blinking neutral light - but the program shows no faults of any kind. Not sure where that leaves me. I also can't adjust FB values (they show 98,100,100).
A few other of the options said "not for this model" when I chose the icon in the tool bar. Really lost here.
Thanks.
Kawasaki Versys**Honda CL360 Project**Honda CB 550**Husky TE610
MotoPreserve -- a blog about wrenching on bikes in Brooklyn...
motopreserve is offline   Reply With Quote
Old 11-20-2012, 06:37 PM   #24636
K7MDL
TE450, TE610
Oddometer: 1,487
No matter what they tell you around here, the 2007 carb'd 610 was the best year. Great score! :-) I might be a bit biased also.
I am 185# and have a 5 gallon tank - my shock and forks were tuned and I had to install lighter springs to achieve nirvana. I really do love the tuned suspension on this bike. Just soaks up the rocks and roots. I tend to glide over them versus drive around them. My TE450 is untuned and constantly reminds me of why I tuned the 610 suspension. The best part is I did it early so I do not end up saying "I should have done it long ago" :-). The 5 gallon IMS tank is low cost and keeps the weight down low and gets you 200 miles easy. Like a KLR supertanker, someone has to refuel all the KTMs out there. I often think about the 17.5K miles on mine and wonder when and if I will ever find another 2007 with 2K miles as a replacement. I am tempted to get one and store it for the day I eventually retire my current one.
K7MDL is offline   Reply With Quote
Old 11-21-2012, 01:01 AM   #24637
reimorei
Oddometer: 7
I'm thinking of revalving my susp also and go to softer springs. My biggest concerns are the cam chain. With 17.5K miles have you already changed yours? With how many miles, if so?
Luckily here in Brazil we can found a lot of 610s from 2007 to 2009 with less then 3k miles, so I'll have an option to replace mine when needed.
2007 Husqvarna TE610
Sold: 2010 Honda XRE 300 - 2010 Yamaha WR 450 -2010 Honda CBF 600 Hornet - 2007 Yamaha XT 660R - 2002 Yamaha XT 600E - 2002 Suzuki GS 500
1995 KTM 250EXC - 1994 Suzuki RMX 250 - 1992 Huskvarna WR 250
1992 Honda CR 125 - 1991 Kawasaki KDX 200 - 1989 Kawasaki KDX 200
Old 11-21-2012, 01:38 AM   #24638
xymotic
xymotic's Avatar
Oddometer: 7,755
Huh? You're replacing it with a used chain or replacing the motor?
A new chain is a $100 part. And my first went out @ about 10k the second has lasted longer, I don't actually know but i'd guess it's 17 or 20 and it's done.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 11-21-2012, 08:36 AM   #24639
begeberg
That'll leave a mark..
Oddometer: 2,185
Are you sure you reset it?
I just replaced my water temperature sensor (again) and the flashing neutral stopped immediately. Does your fan run all the time and is it hard to start cold with the choke lever pulled? If so, you likely need a new sensor. I'm on my third in 8,000 miles. A faulty sensor is only time my neutral has ever flashed on my 2008 TE610.
Thanks.
Life is like riding a bicycle, where balance is a good thing.
begeberg is offline   Reply With Quote
Old 11-21-2012, 08:52 AM   #24640
motopreserve
Oddometer: 109
Begeberg,
Not sure what you meant by "are you sure you reset it" but I just plugged it in and took a look at the read outs. No fault or error showed up in either current or historic fault window.
I tried again today, and let it warm up longer. Someone over at cafe husky thought maybe I wasn't getting a reading due to low temps. Still had no way of adjusting CO - the icon remained GRAYED out.
Ironically, with no indication of any faults, of any kind, my neutral light seems to NOT be blinking any longer. Too weird. I had purchased a new temp sensor before getting the iBeat, but hasn't installed it yet. With iBeat, I figured I'd see if I could recognize the issue with that temp sensor - and then I'd replace it. But now my original seems fine. I never had really hard starting - and as far as I've seen, the fan NEVER goes on. Not sure if I should swap the sensor anyway.
In regards to the iBeat issue: Another thought was that my bike might not be a 2009. But vin/DMV and a search online shows it as that. Not sure what to do with this program from here. Doesn't let me do anything but state at the pretty lights :)
Old 11-21-2012, 10:49 AM   #24641
K7MDL
TE450, TE610
Oddometer: 1,487
Aaron, I think you read that wrong. I have 17K miles on the clock now total, I replaced my cam chain at about 6 or 7K (miles). Been fine ever since. He only has 2K on his clock, he wants to verify when he should get serious about looking at it.
So when I need to replace my '07 with another low miles '07 I guess I need to ship it in from Brazil :-)
Old 11-21-2012, 11:01 AM   #24642
K7MDL
TE450, TE610
Oddometer: 1,487
thanks
I have looked into this and as a result I have 2 good VRs here. Both behave the same. I believe they can not (internally) shut off low enough to keep the voltage down. Inside the VR are essentially switches that chop the voltage at high speed resulting in an average voltage filtered by the battery. There is a minimum on duration that limits how fast they can switch. I went to a 35W HID and had to put 10W load back on to keep the voltage in check. I did that with dual filament front turn signals. 8W on each side always on. Varied tolerances can result in some VRs doing better than others. Also FI bikes are slightly different then carb'd power consumption wise. Carb'd takes less power. I also noted that peak voltage is around 2200 RPM. So idle is worse than running down the road.
I also believe that the TE610 speedos are not tolerant of that high voltage (not enough margin designed in) and that high voltage is behind most TE610 stock speedo failures. There are no physically broken parts inside, the failures are internal component failure and in particular the CPU or circuit inputs to the CPU as far as I can tell after inspection and observation (resets tend to work every once in a while for some time at least).
Old 11-21-2012, 11:20 AM   #24643
motopreserve
Oddometer: 109
I'm flip-flopping like a politician! Just took another ride, and the damn blinking light is BACK!!! The new temp sensor goes in immediately. Good grief!
Old 11-21-2012, 02:33 PM   #24644
xymotic
xymotic's Avatar
Oddometer: 7,755
Thanks I definitely didn't grok what was going on there :)
Albert Einstein
6:10 to Yuma
Old 11-22-2012, 12:54 PM   #24645
bensl
bensl's Avatar
Oddometer: 113
has anyone come across an aftermarket gas cap for the 610? i found this old thread http://www.advrider.com/forums/showthread.php?t=506643
looks pretty cool.
bensl is offline   Reply With Quote
Times are GMT -7.   It's 05:13 AM.
