Old 11-20-2012, 07:42 PM   #91
LandsVW OP
LandsVW's Avatar
Oddometer: 296
Originally Posted by elsalvadorklr View Post
pics and a vid of it running! sorry its required
congrats!!!!!!!!!!!!!!!!!!!!!!!!!
LOL I'll get'r done ASAP
LandsVW is offline   Reply With Quote
Old 11-20-2012, 08:10 PM   #92
LandsVW OP
LandsVW's Avatar
Oddometer: 296
http://www.youtube.com/watch?v=zbz_2...ature=youtu.be
Old 11-20-2012, 10:55 PM   #93
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 239
Yo-ho!
Accept my congratulations!!
Sounds just great!!
Ivanych is online now   Reply With Quote
Old 11-21-2012, 12:14 AM   #94
LandsVW OP
LandsVW's Avatar
Oddometer: 296
Originally Posted by Ivanych View Post
Yo-ho!
Sounds just great!!
Thanks! Now I can work on the details, make it look better, get seat covered, etc. But I think I have a solid engine/bike!
Old 11-21-2012, 09:50 AM   #95
elsalvadorklr
southern xr rider
Oddometer: 4,154
big congrats!!!!!!!!!!!!!!!!!!!!!!!1 awesome
you asked about that engine whine, a couple of posts back and all I can say is that Ive heard a bunch of xl600r and dual carb xr600 do them more than single carb or later year model xrs dont know what it is...maybe its the fatter cam chain or something like that...
its just something that I have noticed
to me it sounds great!
elsalvadorklr is offline   Reply With Quote
Old 11-21-2012, 10:17 AM   #96
mcma111
mcma111's Avatar
Oddometer: 11,872
The whine is most likely the single gear counter balancer. The later bikes came with a split gear, spring loaded gear to keep constant pressure on the drive/crank gear.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-21-2012, 02:00 PM   #97
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
I had a 1998 XR engine in my XL and though it had the single-gear balancer, once I changed the top end back to the old style with the wider cam chain, I noticed much more whine. It's a combination of the two. A lot of it does come from that balancer gear though, so it's a combination. I thought I would get the full-on whine I used to get from the '83 XL engine (which I love!) but not quite.
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 11-21-2012, 02:01 PM   #98
Zombie_Stomp
Aspiring human
Oddometer: 2,231
P.S. look at my sig line. I can recover your seat or make a new one if you send me the old one by mail. Foam looks like it could use a new layer on top at least.
Old 11-21-2012, 02:40 PM   #99
LandsVW OP
LandsVW's Avatar
Oddometer: 296
thank you! I will consider that - have a few things on Craigslist to repopulate the $$ in the wallet! I also want to clean the paint off the tank (how?) and that side cover. The headlight cover and the left cover came out very clean using WD-40, but the other two items are a different kind of paint. A few more things like that and the bike will look pretty good.
as far as engine whine goes, it caught me by surprise. I don't remember that on my DR350 at all... But yeah, sounds like they are sort of prone to that... I almost think mine has the split gear in it? But I don't remember... It did have the extra wide timing chain tho.
So, away we go to Thanksgiving! Tomorrow will be eating Turkey dinner and will certainly be thanking God for all of our blessings (the least of them being a running XR600, LOL).
Old 11-21-2012, 02:55 PM   #100
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Carburetor cleaner is a good spraypaint stripper.
Old 11-21-2012, 03:04 PM   #101
LandsVW OP
LandsVW's Avatar
Oddometer: 296
doesn't melt the plastic?
Old 11-21-2012, 03:42 PM   #102
elsalvadorklr
southern xr rider
Oddometer: 4,154
OK in know 88-90 have the spring loaded balancer as thats what I opted to use on mine...you sent me a single gear one from a 96 along with the crank...
so 87 and down are single and only 88-90 and xrls have the spring loaded gear balancer? aka split gear?
that makes sense
Old 11-24-2012, 08:29 PM   #103
LandsVW OP
LandsVW's Avatar
Oddometer: 296
bought a bulb and fixed headlight today... (some kind of fog light halogen, 55w, but Oreilly Auto had it for 6$)
Old 12-01-2012, 07:18 PM   #104
LandsVW OP
LandsVW's Avatar
Oddometer: 296
So, I haven't advanced much on the bike. Waiting for some money to get the next item - which will be an exhaust baffle/diffuser. However, I noticed that after the first start using starting fluid, that day while it was hot, it ran fine. However, when it cooled down that evening I haven't been able to start it since.
Today I took the bowl off the left side carb and cleaned everything. I didn't see anything really horrible, a few little drops of liquidy red goo in the bottom cup, but I couldn't see through pilot jet (which I assume is the idle jet. my XR100 used to clog up and not idle). I cleaned this, sprayed WD through all the ports, reassembled and she fired!
Has a 125 jet in the left carb. the idle mixture screw is in 1 1/2 ( I left it alone not knowing the actual setting).
I pulled the 17mm plug out of the other carb too. It looked clean too.
Has anyone replaced the phillips screws with little bolts? The inside screw was damaged by a PO and I had a heck of a time getting it out. resorted to a thin chisel to knock it loose.
That's it for now. Once I get that baffle in I can drive it around a little more. At this point it is a obnoxious police magnet.
Old 12-02-2012, 12:16 PM   #105
LandsVW OP
LandsVW's Avatar
Oddometer: 296
Also, anyone have an opinion or source on tank covers? This bikes tank is ugly, looks like PO painted white, over the original stickers, etc.
Times are GMT -7.   It's 04:29 AM.
