Old 07-09-2012, 07:53 PM   #16
sonoran
you already know
sonoran's Avatar
Oddometer: 25,626
Most of the couplings are valved on both ends so as soon as you disconnect the fuel stops flowing. They do make non-valved couplers and that's what you'd need if you wanted to drain fuel from your tank into your MSR bottle.
sonoran is online now   Reply With Quote
Old 11-19-2012, 08:11 AM   #17
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
Originally Posted by PowerCell View Post
Or... for one-third the price...
http://www.mcmaster.com/#catalog/118/202/=goe674
I'm gonna throw a coupler in with my Mcmasters order, but I'm confused about the size. The stamp on the hose and the the online coupler sizes are screwing with me. Some one chime in please?
My guess is 1/4" coupler with 7/16" OD for a 5/16" tube ID. Yes-no??
http://www.mcmaster.com/#catalog/118/202/=k8dr5o
Coupling
Size Plug
OD For
Tube ID Each
With Shut-Off Valve
1/8 5/16" 1/16" 5012K52 $11.04
1/8 5/16" 1/8" 5012K54 9.47
1/8 5/16" 3/16" 5012K56 9.95
1/8 5/16" 1/4" 5012K58 9.70
1/4 7/16" 1/4" 5012K94 9.58
1/4 7/16" 5/16" 5012K96 10.21
1/4 7/16" 3/8" 5012K98
viola-tor is offline   Reply With Quote
Old 11-19-2012, 10:51 AM   #18
Douf
Limey Bitch
Douf's Avatar
Oddometer: 772
Originally Posted by Uller View Post
Triumph has had reliability problems with the plastic disconnects on some of their bikes. They provide replacement parts that are metallic.
Douf
Douf is offline   Reply With Quote
Old 11-19-2012, 11:31 AM   #19
Uller
Uller's Avatar
Oddometer: 1,699
That is the size I am using. Works well.
Uller is offline   Reply With Quote
Old 11-19-2012, 11:50 AM   #20
Groundhog
Groundhog's Avatar
Oddometer: 188
Got mine from an online speed shop (Jegs, Summit, or one of those).
Groundhog
Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
Groundhog is offline   Reply With Quote
Old 11-20-2012, 06:17 AM   #21
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
Coupling
Size Plug
OD For
Tube ID Each
With Shut-Off Valve
Hmmm, call me a nervous-nelly, but in the description of these it doesn't mention fuel...
A little more digging yielded these, which say they are "automotive couplings":
http://www.mcmaster.com/#automotive-...plings/=k8uwz5
That push button one is pretty slick. what do ya think?
Old 11-21-2012, 01:18 PM   #22
Uller
Uller's Avatar
Oddometer: 1,699
It doesn't look like they have a "shutoff" feature like the other one you posted. That is pretty important so the float bowls and fuel in the tanks don't back drain once you disconnect it.
I can tell you this is a rather trick feature after having the shutoff part of my cheap plastic disconnect, on the 690, fail; causing my full gas tank to empty on my garage floor last weekend. I managed to catch about half of it though.
Old 11-21-2012, 02:06 PM   #23
ST4s
Oddometer: 50
Quick connect fuel line fittings.
To All, The OEM KTM fuel line quick connects are made by CPC, Colder Products Company and appear to be proprietary to KTM. Colder's industrial catalog does not list compatibility with gasoline or Ethanol for any of their fittings. Please be careful when replacing the stock quick connects with less expensive aftermarket units not specifically rated for gasoline and/or Ethanol. The Jiffy-tite units apparently have O-rings that are compatible with gasoline and race fuels and are of metal construction. The last thing I want is to have fuel spraying out of a failed coupling at 50PSI on me the bike and a smoking hot exhaust pipe!! (No connection with Jiffy-tite or Colder Products just have a couple of KTM's with OEM couplings).
ST4s is offline   Reply With Quote
Old 11-21-2012, 02:22 PM   #24
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,927
Here's a good source from my post in another section.........
http://www.advrider.com/forums/showp...postcount=6628
The place to look for the precise ones you're looking for.
http://quickcouplings.net/
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is online now   Reply With Quote
Old 11-22-2012, 11:42 AM   #25
MAXVERT OP
Rough Rider
MAXVERT's Avatar
Oddometer: 1,047
Assuming the couplings in question are valved, the gas shuts off when disconnected (yes unvalved quick connects are sold), then you could buy the male or female coupling needed and have an appropriate length
of fuel line attached for filling you stove/bottle.
IMHO, it seem easier to just carry a fuel bottle and avoid the potential
problems of misaligned , broken or dirt contaminated connectors.
Not to mention the gas dripped on you hands just before handling food.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 11-23-2012, 07:49 AM   #26
ktm950se
ktm950se's Avatar
Oddometer: 1,385
http://www.coyote-gear.com/quickdisconnects.html
ktm950se is offline   Reply With Quote
Times are GMT -7.   It's 10:45 PM.
