Old 11-18-2012, 01:49 PM   #6376
amf4399
amf4399's Avatar
Oddometer: 63
Originally Posted by Moparmanpete View Post
Chapter 6 page 2 of the manual shows the cam specs
Here is a link to an online manual website is in Italian but the manual is in english (inglese)
http://www.hondaxl.it/manuali.htm
Pete
Hey Thanks. I had a manual but having an one in a pdf makes my life a little easier. If you know where I can find one for a 85 Yamaha tt600 that would make my day. Can't find a free version.
amf4399 is offline   Reply With Quote
Old 11-19-2012, 05:29 AM   #6377
Stretchah
Oddometer: 123
My XL600
Hi Guys, Finally got my new to me 84 XL600 to run again and here are some pics....
It's a little shabby at the mo, but, love it all the same, not sure what the fenders are off of though, anyone know ?
As far as I'm aware it's a standard 84 PD03 apart from the fenders and the FMF pipe. I have a few plans for it.
Managed to pick up a Dakar twin round headlight unit and fairing, it's been painted badly though, so, need to strip the paint off, any suggestions for something that'll strip the paint without damaging the plastic - happy to put elbow grease in :)
I also just bought a standard rear rack from Germany, so, from what I've read on the forum, I seem to have been pretty lucky with parts so far
Stretchah is offline   Reply With Quote
Old 11-20-2012, 03:14 AM   #6378
God of Speed
brrraaaaAAAAAAAP
God of Speed's Avatar
Oddometer: 1,105
hi all
for those looking for a genuine safari tank for the xl600, there is currently one on ebay in australia.
search for item number 251182922856
its not mine, my xl600 with dakar tank was stolen a few years ago.
- Charlie
125cc Salt Racer - God of Speed Thread
'Overall happiness is directly proportional to the increasing distance between the front wheel and the ground.'
'85 XL600R-L-M-PDGSAZ
God of Speed is offline   Reply With Quote
Old 11-20-2012, 04:48 AM   #6379
amf4399
amf4399's Avatar
Oddometer: 63
On my 83 Xl600r. The specs for my Camshaft lobe height reads
Specification 31.023mm
and the wear limit is 31.85mm.
How can the wear limit be larger should it be smaller?
Old 11-20-2012, 05:02 AM   #6380
amf4399
amf4399's Avatar
Oddometer: 63
If it is being read correctly the cam shaft is out of specification (worn out)
Doesn't me you can't use it, just means it will not run as strong a new.
It depends on what you want to do
Hi Moparmanpete, Actually in the Italian version that you sent me it says something different. It says 30.85mm not 31.85mm which makes more sense. I think its a typo in the American manual.
Old 11-20-2012, 05:37 AM   #6381
Stretchah
Oddometer: 123
Originally Posted by God of Speed View Post
hi all
Thanks for the heads up Charlie, definitely after one, but, the shippings going to be a bit rich for me this time :) I have been wondering if you had to modify the front mounts at all to get it to fit on yours? I'm guessing the back had to be modified slightly as I think the Dakar tanks have 2 fixings rather than the one centre one on the standard style tank.
Cheers,
Old 11-20-2012, 12:03 PM   #6382
Billtr96sn
Flange Furtler
Oddometer: 393
The Dakar tanks do have 2 fixings at the rear and the nose of the seat is different as well.
If you see me coming, better step aside. A lot of men didn't, a lot of men died, all because of my shit brakes.
Billtr96sn is offline   Reply With Quote
Old 11-20-2012, 02:39 PM   #6383
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,096
Leaking oil like a harley over here. from the stator cover. no time to fix it, and no time to ride either Don't want to drive my car either. Two wheels or I ain't
happy
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 11-20-2012, 04:13 PM   #6384
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,096
Should I buy a gasket kit? or will that cut yourself stuff work? I got some cork gasket lying around.
Old 11-20-2012, 08:59 PM   #6385
terrordaktyl rexxx
Oddometer: 18
Been shopping around for some tires. Anyone ever run a wider tire up front, if so what size? can always use a bit more cushioning on the bike.
terrordaktyl rexxx is offline   Reply With Quote
Old 11-20-2012, 10:03 PM   #6386
12120
Indenturedx5
12120's Avatar
Oddometer: 487
I'm riding riding riding POP I'm pushing pushing
Hate when old reliable becomes old damn thing. Cruising down the I-5 almost to the La Center exit and pop cough pop coasting. Haven't really had a chance to dig into it yet. I am sure I have a ignition problem, but have to get a better multi meter to really check stuff. Got a new coil on the way already just cause I found a deal on one, and the plug wire was arcing to the tank. Woke me up a couple times before I wrapped some old tube around it. Gotta love the old girl. I was gonna replace the stator down the road a bit anyway. Just wanted to get through the Christmas season first. Hope that is not the problem. Would hate to have to spend the kids present money on moto parts.
Chris
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
12120 is offline   Reply With Quote
Old 11-21-2012, 02:01 AM   #6387
lookfar
from the land of OZ
Oddometer: 679
Chris
G'day Chris,
That is similar t what happened to me.
Turned out to be the cdi died. Replaced it using swapnostics
And all was good again.
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 11-21-2012, 06:46 PM   #6388
12120
Indenturedx5
12120's Avatar
Oddometer: 487
Check me please
Before I say the stator is bad. Can someone tell me I did this right? Black and red(?) wire from stator. Not in the 4 pin plug, but right next to it and from the stator harness. I should have 40-50v ac when kicking over? Test that wire and I get almost nothing. I think 13 something was the best I got. Do I need a better meter to do this test? I have just a napa special multi meter. Don't know how fast it reacts? I get no voltage at the primary coil wire either. Checked wire from harness to coil and the ground wire for coil and got nothing. I am pretty sold on the stator went south, just double check me would someone please.
Chris
'83 XL 600r
Old 11-21-2012, 07:02 PM   #6389
12120
Indenturedx5
12120's Avatar
Oddometer: 487
How many OHMS are you getting from the Black and Red between ground?
I did not check ohms. I figured if I have the right amount of ac voltage then it working and I don't care how many ohms I see at that point. Kinda a simple way of looking at it I suppose, but make since in my simple head!! Where am I again? To bad you aren't right near by I have most all the stuff you need in a box somewhere.
'83 XL 600r
Old 11-21-2012, 07:14 PM   #6390
12120
Indenturedx5
12120's Avatar
Oddometer: 487
Ohms would be easier since you don't have to kick it over and try to read the meter at the same time. JMO
Suppose that would be true. I think that I tried to get ohms reading on it and had no luck. I can't rightly remember. Guess I could check real quick.
'83 XL 600r
Times are GMT -7.   It's 02:41 AM.
