11-21-2012, 09:13 AM
#13636 | |
wandering the desert
Oddometer: 681
Did you already sell the carb stuff Greg?
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
11-21-2012, 09:40 AM
#13637 |
Oddometer: 581
I sure did, sorry. I try to keep that page updated with only what is available.
http://thisoldtractor.com/gtbender/f...arts_dr350.htm Regards, Gregory Bender |
11-21-2012, 09:44 AM
#13638 | |
Wishing I was riding RTW
Oddometer: 2,418
My screen name is kind of long. I am the "ME" part, my name is Cory. Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..." |
11-21-2012, 09:56 AM
#13639 | |
Oddometer: 581
The spare parts catalog shows the OEM optional oil cooler pretty well...and I have some photos of the original hoses and cooler. Basically, I'm selling a cooler, rock guard, and various hoses/banjo bolts that can be used as a starting point for a complete solution without needing to modify your original components. As I mention on the website, let me know if you want something but the price seems out of line. I'm trying to open up garage space! :> Regards, Gregory Bender |
11-21-2012, 12:28 PM
#13640 |
Oddometer: 681
Took the bike to the range today. It was nice riding it out to the targets instead of walking
11-21-2012, 02:58 PM
#13641 |
Oddometer: 94
I hate to be the stupid kid on the block but where is the carb fuel overflow on the 1999 DR-350SE? I see a line near the top of the carb that looks like it might run to the airbox but I thought that there should be an ovewrflow line routed near the bottom of the bike. There is also a small brass pipe running up the left hand side of the carb.
Canadian FJR Canadian FJR screwed with this post 11-21-2012 at 06:37 PM |
11-21-2012, 03:02 PM
#13642 | |
mc caregiver
Oddometer: 2,590
11-21-2012, 03:41 PM
#13643 | |
Sleep, Wrench, Ride
Oddometer: 4,448
First is the circlip issue that has already been discussed. Second is the shift drum bolt. ![]() I've owned two DRs and this bolt was so loose it was ready to pop out on both bikes. A friend of mine lost the bolt entirely and couldn't shift gears. Jesse prefers to remove the bolt and tap out the hole for a bigger one, but I've been able to secure it successfully with Locktite red. The clutch drag issue can be very annoying , but it's not something that will end a trip. This issue is caused by wear on the clutch collar and washers. Your bike might have this kind of wear but not experience clutch drag because the clutch nut has never been re-torqued. So here's the catch: in order to Locktite the shift drum bolt you have to remove the clutch which will then have to be re-torqued and may cause the clutch drag issue to start on your bike.
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
11-21-2012, 07:17 PM
#13644 |
Ken Dodd's dads dogs dead
Oddometer: 530
Need help im in death valley and my DR won't start . getting gas but no spark? any ideas! 97 350s. we were coasting down hill then would not start!
11-21-2012, 07:36 PM
#13645 |
Oddometer: 4
Well, the owner would not budge on the the $2500 price for his 1999 DR350 w/ 1500 miles, or I would have bought it already.
So I kept looking on CL and found a 2001 DR-Z400E w/ 4500 miles for sale for $2000. I've gone to look at & ride the 350, but not the 400 yet. The 350 was in great shape and ran good, but since the 13 yea-old original tires are still on the bike, I'd have to get a set of tires for it, and the valves have never been checked. I think the price is about $500 too high, but the owner is firm on the price. I don't know what kind of shape the 400 is in, because I'm going to look at it the day after Thanksgiving, but the owner says it's excellent, and the water pump was replaced this past summer. It has Perrelli 70/30 street tires on it, but since I'm planning on doing some serious dirt riding, I would want to put some knobbies on it. I'm thinking the DR might be a better pick because it's air-cooled and lighter, but the DR-Z is 2 years newer and at least $500 cheaper (I'm hoping the owner will sell it for $1700, but I'll offer $1500 when I ride it Friday). This being a 350 thread, I'm sure you're biased; but which one would you choose and why?.Would you spend the extra $500 bucks for the 350? (I'm gonna put this on the DR-Z400 thread and get their opinions too) Thanks for your input. |
11-21-2012, 08:17 PM
#13646 | |
Sleep, Wrench, Ride
Oddometer: 4,448
Other steps: Make sure all connectors in the wiring harness are properly connected. The ground cables to the coil sometimes come loose and cause this. Try replacing the spark plug.
11-21-2012, 11:00 PM
#13647 | |
Oddometer: 487
DRZ400... Water cooled, 5 speed. Newer, more complex. The deciding factor for me was the gear ratios on the DRZ. It really needs another/higher gear. If you are not going to do much pavement, it's probably not a factor. I'm a dirt rider, but it seems there is always a good bit of tarmac on every ride I do. |
11-22-2012, 03:45 AM
#13648 | |
Oddometer: 7
Thanks for the quick response fellas...
11-22-2012, 03:52 AM
#13649 |
Oddometer: 94
"Need help im in death valley and my DR won't start . getting gas but no spark? any ideas! 97 350s. we were coasting down hill then would not start"
Double check the connections at the battery posts and then see if there is any juice in the battery. Good luck and post up once cured. Canadian FJR |
11-22-2012, 04:13 AM
#13650 | |
Oddometer: 169
I could go on and on, and on....and on, BUT im not, everyone here will says "Put a sock in it wagz..lol" As i said, these are SOLELY my opinions as to why i love my DR and wouldnt trade it for a DRZ...not to mention...the DR seats are way more comfortable..i have problems with not getting comfy on seats..lol The Decision is yours sir, but if i had the money, and a 99 was sittin close by with low mileage at that price....itd be sittin next to my 93 that is currently nestled warmly into my garage! Either way, i hope you enjoy whichever bike you purchase!
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. |
