Thread Tools Rating: Thread Rating: 17 votes, 4.35 average. Display Modes
Old 11-11-2012, 10:06 AM   #1051
Wingfixer
Watch this...
Wingfixer's Avatar
Oddometer: 3,747
We had thought of leaving it on the big trailer but if we left it aligned, as in the picture, that first step was a bit tall, and the awning was un-usable. Turned side ways, the leveling jacks where swinging in the breeze. We did decide to roll it off, easy as gravity does most of the work. Getting it back on was an easy three man job but I do have a winch I will use in the future.
This is still a work in progress and ultimately we want to just extend the frame on the pop up to load the bikes on.
Thread jack off.
Just another DAMN rider
Wingfixer is offline   Reply With Quote
Old 11-11-2012, 10:09 AM   #1052
Wingfixer
Watch this...
Wingfixer's Avatar
Oddometer: 3,747
Originally Posted by natedog39 View Post
We had a great time though, remembered that friggen monster dog of yours from last year.
Ever do the Quarry Run in Hancock NY? That's a good one too.
He loves to camp, might have something to do with all the food he gets...
I have thought about that ride, several guys from the group I ride with have done it. I might have to make a trip north next year!
Old 11-12-2012, 07:59 AM   #1053
ADW
'tard bike restos
ADW's Avatar
Oddometer: 572
No, thanks
Originally Posted by Wingfixer View Post
Thread jack off.
It's a nice thread, but not enough to get me to do that.
08 KLR, 06 KLR w/Sputnik sidecar, 09 WR250R, 72 CB350F
ADW is online now   Reply With Quote
Old 11-22-2012, 05:34 AM   #1054
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,550
Game changer
It's funny how big an impact a little information can have.
I finally pulled the rear diff cover off to figure out for sure what ratio was in there.
The original ratio was 4.68, I figured the current gearset couldn't be lower than 4.10 given the tire size and the current top speed.
I was wrong.
3.73 is what's in it now, this led to the calculator coming out.
Supposedly there is a 3.23 ratio available but the lowest I've seen listed is 3.31.
Things being as they are now this would increase the top speed by 8mph to 75 mph.
But when factoring in the 600 rpm I'd give up with the 8.3 i'm back down into the 60's.
This is unacceptable and based on my calculations, without an overdrive transmission I'm fucked.
Allison doesn't make an overdrive transmission that isn't electronicly controlled to my knowledge.
As of right now the engine swap is on hold while I brainstorm a solution.
If nothing else happens I will install a 3.54 gearset and run it with the 5.9
this will lower my rpm at 65 by 5 or 6% and shouldn't negatively effect towing.
I don't think she could pull 3.31 gears with the camper in tow.
On a positive note she gets 13.5 mpg when not towing, not bad for a 12,000+ lb vehicle.
That's it for now.
2014 FE 501
2012 990Adv
Team Ghetto does a hot lap of America
natedog39 is offline   Reply With Quote
Old 11-22-2012, 07:30 AM   #1055
Wingfixer
Watch this...
Wingfixer's Avatar
Oddometer: 3,747
Huh. Well, damn.
Old 11-22-2012, 08:21 AM   #1056
AKjeff
AKjeff's Avatar
Oddometer: 5,288
Have you considered installing a Brownie box?
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 11-22-2012, 03:37 PM   #1057
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,550
I did, and I may look into it a little further. Do you know offhand how much torque one can handle
2014 FE 501
2012 990Adv
Old 11-22-2012, 03:39 PM   #1058
Patrick46
visionary
Patrick46's Avatar
Oddometer: 2,831
WOW....no kidding!!
x 2 with the Brownie.
Not sure of the specs, but they sure ran alot of 'em in the old log trucks around here if that's any help! 4x4, and 5x4 were very common, and can still be found out working today...albiet rare.
"Good Times & Good Friends Make Life Better"
www.artworks-unlimited.com
Patrick46 is offline   Reply With Quote
Old 11-22-2012, 04:51 PM   #1059
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,550
Originally Posted by Patrick46 View Post
WOW....no kidding!!
It should be even better with 3.54 gears too.
2014 FE 501
2012 990Adv
Old 11-22-2012, 05:10 PM   #1060
AKjeff
AKjeff's Avatar
Oddometer: 5,288
From this web page: http://www.6066gmcguy.org/spicer-5831-b.htm
The 5831 three speed's were rated for 275 ft. lbs and 150 HP.
These were used in Chevy 5500 series trucks in the '60's.
I don't know what type of payload they were rated for, I'm thinking it would be hard to overload one in a typical pick-up.
I know heavier duty four speed's were built as well.
Try a search on Spicer auxiliary transmission.
Old 11-22-2012, 05:25 PM   #1061
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,550
That's what I thought about the torque.
I did a search last week and have been mulling things over since.
A solution will present itself.
2014 FE 501
2012 990Adv
Old 11-22-2012, 05:46 PM   #1062
KeithinSC
KeithinSC's Avatar
Oddometer: 1,557
Gearvendors overdrive?
They might have something to hang off the back of an Allison.
http://www.gearvendors.com/
KeithinSC is offline   Reply With Quote
Old 11-22-2012, 06:28 PM   #1063
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,550
They don't, would be nice if they did though.
2014 FE 501
2012 990Adv
Old 11-23-2012, 03:37 AM   #1064
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,550
Here's the figures.
With the 8.3 and 3.31 ratio my top speed would be 59 mph.
Brownie box .82 overdrive raises speed to 70.
Not too bad but not worth the effort IMO.
I don't need to do 80 mph but that's the top speed I'm shooting for making cruising at 65 possible without the engine being wound out.
An Allison 3000 series transmission has 6 speeds with both 5th and 6th being OD. The problem is controlling it and $$$$$ to buy one.
I do recall looking at a truck once that had a mechanicaly controlled DT466 and I believe an Allison 3000. I may look into this.
2014 FE 501
2012 990Adv
Old 12-25-2012, 05:15 PM   #1065
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,550
Time for an update.
Now I'm not ready to call this the Ghetto bus's replacement as there are still things to do to that.
I got a real good deal on this and couldn't pass it up.
Not bad for $5K
2014 FE 501
2012 990Adv
Thread Tools
Times are GMT -7.   It's 04:34 AM.
