Old 11-22-2012, 11:31 AM   #61
ME 109 OP
ME 109's Avatar
Oddometer: 605
I think plastigauge would suffer from the high temp required for fitting the cover plate?
I've thought of calling the local bmw dealer who apparently have an airhead knowledgeable head mechanic, and asking if I can pay to get the shims measured.
Apologies for dragging this thread out and perhaps making mountains of molehills, but I'm learning heaps.
Lord of the Bings
ME 109 is offline   Reply With Quote
Old 11-22-2012, 11:42 AM   #62
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,007
I once suggested Plastigauge on another forum and was told it does not work. It's not made for this application. It is made for crank pins and rod bearings and it works there. This may not make a lot of sense but people who supposedly know say it won't work.
---Albert Einstein
disston is online now   Reply With Quote
Old 11-22-2012, 12:53 PM   #63
ontic
Oddometer: 921
Originally Posted by ME 109 View Post
Thing is, the solder diametre needs to be close to the ideal shim thickness so as to not bow the tranny cover when the screws are torqued down.
yeah, that was my thought too. I was thinking of trying to make a plait or twist of thinner soldering wire first, and try to use that to determine where your ballpark is, then see if you can get a thicker strand of solder that is just too thick. I was imagining it taking a few tries to raise (or destroy) the confidence level.
For putty, you could try that 'knead it' epoxy stuff (often used for metal repair). It is about the consistency you want- only problem is that the couple of tubes I've owned have all set-up pretty quickly. There must be a slow cure version?
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 11-23-2012, 02:45 AM   #64
ME 109 OP
ME 109's Avatar
Oddometer: 605
As far as I know, the way to use plastigauge is to measure the width of the squashed plastigauge after it has been removed from the test location (big ends etc) The specific size of plastigauge used can be cross referenced with the 'squashed width' to determine clearance.
Lord of the Bings
Old 11-23-2012, 02:59 AM   #65
ME 109 OP
ME 109's Avatar
Oddometer: 605
Just had a little play with the donor cover and found that I can get 2 thou difference with the depth gauge by moderately pressing on the cover.
Success with the solder depends on whether the solder can create as much resistance as my pushing on the cover...
The two options I see are starting with the solder diametre as close as possible to the correct shim size, and/or use a softer solder.
Talk about splitting hairs.
Lord of the Bings
Old 11-23-2012, 05:07 AM   #66
mendoje
Oddometer: 134
Still hope for Plastiguage
All of us who've used Plastiguage have probably used it to measure radial clearance for crankshaft bearings. I just found these on the Plastiguage website: http://www.plastigaugeusa.com/how.html
"Shaft end-float lends itself to direct measurement by PLASTIGAUGE"
"PLASTIGAUGE is particularly effective for the measurement of separation in moulding tools, and wherever it is required to determine the separation between hidden surfaces"
So, my assumption that the calibrated measureing tape it comes with was only applicable to radial clearance wasnt so!
I think the main issue now, is whether it will stand up under a heated part.
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 12-15-2012, 02:22 PM   #67
ME 109 OP
ME 109's Avatar
Oddometer: 605
Further on down the road...
I bought a shimming plate from Cycle Works.
It has been an interesting learning experience, this shimming business.
I remeasured everything again this morning and have come up with the following shim requirements.
Lay shaft needs .95 shim
Input shaft needs .876 shim
Output shaft needs .935 shim
Gasket included in calculations.
Anyone hear alarm bells?
Lord of the Bings
Old 01-08-2013, 02:22 AM   #68
ME 109 OP
ME 109's Avatar
Oddometer: 605
Even further on down the road.
I put the cover plate back on with very close to the shim stacks noted above. All good until I got towards the last three fasteners (I called them fasteners to avoid the bolt, screw, cap screw, machine screw thingy)
The input shaft tightened up. WTF? this, after 15,000,000 measurements.
Well off came the cover again and out came approx .02mm from each stack.
Frustrating trying to come up with the numbers again from a choice of about 16 shims.
Cover went back on, all buttoned up and a nice free input shaft. Minus the input seal.
I've had a couple of rides so far and all seems well. Smooth positive shifting with no false neutrals.
The taller 5th is a gem! The RS has plenty of power to pull with the reduced rpm.
With a 33/11 I'm quite sure 130kph on the speedometer ran @ 5000.
Now, 130kph is running @4500
120 @ 4000
100@ 3500.....used to be 3800
That appears to be a difference of 4-500 rpm @ 130 and 300 rpm @ 100
Bottom line, I like it.
All my fun in the mountain twisties is 2nd 3rd and 4th so nothing lost there.
Cross my fingers that it will do another 13 years before showing chips on the magnetic plug.
Lord of the Bings
Times are GMT -7.   It's 12:27 PM.
