Old 11-21-2012, 04:31 PM   #2821
SJktmRider
USMC Veteran
Oddometer: 13
thanks man
Originally Posted by Zuber View Post
Exactly the same top end as the 530's. They held up great if you kept after the air filter and didn't have an early 08 version with weak rings. I've seen one run for 60 miles in a race with no oil. It only needed on rocker and the plastic chain guides replaced. The valve train is all on roller or ball bearings, no slippers, no plain aluminum bearings.
Keep after the air filter. A tiny amount of dirt will effect the intake valves and they'll tighten up. More dirt or sand will get the rings/piston/bore. Get two filters and swap them out frequently. The original TwinAir is better than the NoToil. The Motorex oil is much better than NoToil also. TwinAir has an extra/optional dust filter that works for dusty or long rides. ALWAYS check around the sealing surface to absolutely MAKE SURE you have it installed correctly. It will fit perfectly or it will have a gap big enough to stick your hand in. I'd expect this topend to go over 20k miles with good filter replacement.
A friend has a 2012 500 exc with 7500 miles, mostly two track and pavement. It runs better than mine with 2000 miles.
thanks man for the info
SJktmRider is offline   Reply With Quote
Old 11-21-2012, 08:13 PM   #2822
jar944
jar944's Avatar
Oddometer: 344
Originally Posted by mnsnowhawk View Post
Here is what I use for winter riding.
looks like it would be a lot of fun, but id want more motor.
jar944 is offline   Reply With Quote
Old 11-22-2012, 06:18 AM   #2823
mnsnowhawk
mnsnowhawk's Avatar
Oddometer: 9
You would be surprised how well they work. As far as more motor, I've got this.
mnsnowhawk is offline   Reply With Quote
Old 11-22-2012, 07:44 AM   #2824
Foot dragger
beat up ex flat tracker
Foot dragger's Avatar
Oddometer: 6,753
Originally Posted by garrett View Post
Trelleborgs are scarce right now here in Canada, there's a waiting list apparently. I'm going to stud up a set myself but I'm wondering about a good tire to use. The lugs on the OEM tires look marginal. I think I need a set that have taller lugs. I'll look into the Maxxis ice tires. Any other suggestions?
Garrett
The knobs all ripped off at 1 time on the stock front tire on mine,with not many miles on it,they seem like a weak tire. I would get a set of real tires for studs.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W.
Foot dragger is offline   Reply With Quote
Old 11-22-2012, 08:05 AM   #2825
garrett
garrett's Avatar
Oddometer: 334
Thanks for confirming that. I had my doubts they'd be any good for studding.
Garrett
I like bikes...
garrett is offline   Reply With Quote
Old 11-22-2012, 10:04 AM   #2826
garrett
garrett's Avatar
Oddometer: 334
HDB fitment issue on the EXC
Hi Folks
Has anyone used the HDB instrument protector for the OE instrument on their EXC? I'm currently installing the HDB handguards, top clamp, LEDs, and protector. The instrument protector wont mount to the top clamp because the swivel bolts are in the way. The XCW probably doesn't have this issue because there are only 2 idiot lights but the EXC has 4 lights and they are mounted lower on the protector so they interfere with the swivels.
So if someone has already gone down this road and figured it out, I'd appreciate the assistance.
Garrett
I like bikes...
Old 11-22-2012, 10:11 AM   #2827
juvander
Oddometer: 27
Had same issue, I just moved the handguard bolts to other holes (can't remember which way it originally was...). After this it is ok.
juvander is offline   Reply With Quote
Old 11-22-2012, 10:15 AM   #2828
Honkey Cat
Honkey Cat's Avatar
Oddometer: 647
ride
I love the snow hawks, want to ride one one day.
watching the youtube videos makes me mad I live in florida
Honkey Cat is offline   Reply With Quote
Old 11-22-2012, 10:54 AM   #2829
Night Crawler
Night Crawler's Avatar
Oddometer: 52
I would like to eliminate the key switch on my bike and don't want to install the push/pull switch from Sicass, and their $5 plug leaves the running lights on all the time. Not sure about the KTM plug. Is there any easy way around this?
Night Crawler screwed with this post 11-22-2012 at 01:56 PM
Night Crawler is offline   Reply With Quote
Old 11-22-2012, 01:47 PM   #2830
garrett
garrett's Avatar
Oddometer: 334
Yes it will work with the handguards mounted in the lower hole but still can't mount the protector in the lower holes. I need to do this so I can mount the ipod switch key on the top clamp. Hmmm may have to shim the protector with washers but tat looks amateurish and the HDB stuff is very slick.
Garrett
I like bikes...
Old 11-22-2012, 03:03 PM   #2831
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
Garrett
I studded a set of Trackmasters last year with 20mm rally studs and I was pretty pleased with the results.I'm going to build a set with road legal car studs for days when the bare ground is frozen, the bare ground beats the long studs. I was lucky to snag a stud gun a few years ago. Looking forward to seeing what you come up with.
Just say'IN
crankshaft is offline   Reply With Quote
Old 11-22-2012, 08:10 PM   #2832
Stifdickerson2006
Stifdickerson2006's Avatar
Oddometer: 67
Garrett
I had the same issue. Used the spacers from the stock housing to mount it from the underside of the top clamp and ran the bolts from bottom to top. Worked out great and looks good. If you need a pic I can send you one on Sunday.
No Matter Where You Go, There You Are.
Stifdickerson2006 is offline   Reply With Quote
Old 11-23-2012, 12:29 AM   #2833
Hueychief
FNG
Hueychief's Avatar
Oddometer: 55
I went down this road and eliminated the high beam and blinker indicator as that's incorporated into the Sicass handlebar switch assembly already.
Waterboarding Works
KTM 500EXC
Hueychief is offline   Reply With Quote
Old 11-23-2012, 08:36 AM   #2834
garrett
garrett's Avatar
Oddometer: 334
Thanks Stif
I'm not sure what spacers you're referring to, but yeah send a pic. I did get it mounted but mounted the protector on top of the clamp and shimmed the protector opposite the Ipod key switch with some washers. It doesn't look too bad.
Garrett
I like bikes...
garrett screwed with this post 11-23-2012 at 12:02 PM
Old 11-23-2012, 08:40 AM   #2835
garrett
garrett's Avatar
Oddometer: 334
Nice looking with everything anodized black. You've got lots of room on the left side of the handlebar as well. The clutch hose is quite a distance from the handguard. Mine is ok but touching.
Garrett
I like bikes...
Times are GMT -7.   It's 03:20 PM.
