Old 11-22-2012, 04:38 AM   #2881
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Nice day for a ride.
KTM 950se with our Dual sport fairing.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 11-22-2012, 06:28 PM   #2882
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
M10 Flashlight gif, low, medium, high.
60 ft (18m) Tree is 200 feet or 61 meters distant.
Old 11-24-2012, 09:17 PM   #2883
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Originally Posted by RoundOz View Post
In comparing lights output in Lumens with how many watts they consume, you are comparing the efficiency of the conversion of electrical power to light. Assuming that all the measurements are accurate, if one light puts out more lumens than another for the same wattage, then it is more efficient. The wasted watts don't just disappear however, they are converted into another form of energy, most likely heat. This is why fluorescents and LEDs produce so much more light and are cooler (generally) than halogens and incandescents.
Just because two lamps use the same type of LED (and not that I have done any research on this but I would guess that Cree makes many different grades of LED with different efficiencies and quality control levels) is not the whole story. The electronics package that drives the LED could be more or less efficient too. Less efficient means more heat and heat is the enemy of electronics. So maybe you should look for the lamp that uses the least watts? I doubt that the difference between the best and worst lamps amounts to more than a few watts in the driver board, but that is just opinion, based on the idea that if the board was producing huge amounts of heat in such a small space, even great heat sinking would not save it.
So Lumens per watt is the best way to compare lamps? Wait, there's more mud here. Lumens are a measure of the total light output of a source - in ALL directions. Even if the manufacturers are being truthful and accurate in what they state, the key to performance is getting the photons where you want them - the design and quality of the lens is the main variable here. A better measure of light output in a given direction is Lux, which measures the amount of light falling on a surface. As light from a lamp typically disperses with distance, more so with a flood beam than a spot beam, to compare output between lamps you would have to measure lux at the same distance from the source, and probably pretty close to reduce the errors of beam patterns. So what happens to the light that doesn't go where you want it to? It disperses uselessly (or usefully, depending on what you are trying to illuminate) or it bounces around inside the lamp and creates more heat.
If manufacturers are not quoting Lux, (and some do provide isolux diagrams - Lux maps, if they can be trusted or compared) and everything else is open to interpretation, what is the best way to choose lights. For my money, I guess I would keep wattage iin mind if my electrical supply was marginal...then look at beam patterns, ruggedness, customer satisfaction, return policies etc. that's where sites like advrider are a real resource.
The xm-l line is very efficient, but there are others out there that provide more lumens per chip. The xm-l line produces one of the highest lm/w. In the line the xm-l u2 is king of lm. Pushing chips to full potential produces a ton of heat on the upper limits and doesn't give many more lm.
Danjal is offline   Reply With Quote
Old 11-25-2012, 06:28 AM   #2884
Itapop
Itapop's Avatar
Oddometer: 6
The mystery remains*. Why AdvMonster model 60 with 4 Cree Xm-l T6 absorbs 29 watts while BD declares 44 watts for its Squadron light with same powerleds and lumens? The Advmonster data is real, I've tested it (more or less 30 watts depending on the actual voltage), and BD doesn't have any interest on declaring an higher consumption with same lumens.
Anyway as far to now I'm glad of the AdvM light which is probably the smallest 3,600 lumens led headlight, and that's very good for off road motorcycles.
*And curiosities grow: the led beam, despite its power, seems to me less deep than my feeble halogen high beam. I mean the possibility to distinguish something on the horizon. Maybe the parabolic reflector, or the led light for itself, determines an high contrasted beam without transitional zones.
The best from what happens.
Itapop is offline   Reply With Quote
Old 11-25-2012, 06:13 PM   #2885
hunter151
Oddometer: 67
Finally got around to installing my model 44s. Loving them so far! Each one individually is brighter than my stock headlight and combined its even better. The beam pattern is not ideal for roads, but I haven't seem any aux lights that have headlight like beam pattern.
hunter151 is offline   Reply With Quote
Old 11-26-2012, 01:07 PM   #2886
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Nice looking install
Thanks for your business.
Old 11-26-2012, 05:01 PM   #2887
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 828
What happened to the gas tank in the last 2 shots. Looks like you took it off.
Are your LEDs aimed low, or just the angle of the pictures?
Nice job, nice bike.
Sunday Rider is offline   Reply With Quote
Old 11-26-2012, 05:47 PM   #2888
hunter151
Oddometer: 67
The last 2 pictures were actually taken before the first 2. I took them while wiring things up before I had the lights actually mounted (the tank is removed to run the wires).
The LEDs are aimed fairly low. I pretty much aimed them at the same spot the headlight is aimed at. They could probably be aimed a bit higher, but I want to minimize the blinding of others.
Old 11-27-2012, 09:05 AM   #2889
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,624
Quick question: I have one of these.
and it humms when dimming the LED lights. Is this normal or is there an issue?
Thanks.
Old 11-27-2012, 11:07 AM   #2890
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Thanks.
It can hum, although it is usually inaudible. What lights are you using it with?
Old 11-27-2012, 06:49 PM   #2891
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,624
One BD Squadron.
Old 11-27-2012, 07:52 PM   #2892
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Sanjoh,
you've supplied us with Aux lights, turnsignals, an aux taillight, and now a fairing. Any plans for a Univeral taillight? Maybe with a warning strobe feature and/or turnsignals?? Please?! Us LC4 guys really need one!
Low594 is offline   Reply With Quote
Old 11-28-2012, 10:26 AM   #2893
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Originally Posted by Low594 View Post
Sanjoh,
No plans at the moment to offer a universal taillight.
Old 11-29-2012, 05:21 AM   #2894
frogy
frogy's Avatar
Oddometer: 873
Sanjoh,
+2
2002 R1150RT, 1985 Naked K100RT
frogy is offline   Reply With Quote
Old 11-29-2012, 05:23 AM   #2895
frogy
frogy's Avatar
Oddometer: 873
Do these lights make my ass look too big? Come on , build it and they will buy!!!!
Times are GMT -7.   It's 11:05 AM.
