11-21-2012, 12:56 PM
#1 |
Oddometer: 3,691
Engine Tool
Anyone have the special tool to remove used when removing the balancer shaft sprocket from 2005+ engines that I could borrow?
It's part number 60029050000 "Bottom Part Pretensioning Tool"
"Civilize the mind, but make savage the body." To the house of a friend the way is never long. "Show respect to all, but grovel to none." '12 690 Enduro |
11-22-2012, 04:00 AM
#2 |
Andrew to most
Oddometer: 1,111
If you use a right sized drill bit, you can get around the having to use the tool. The bit must fit snug with as little play as possible. The gear is still a bit of a bitch to get out without it coming apart. But, not impossible.
Maybe some else has other "Mcgyver's" on hand if you don't come right.
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost |
11-22-2012, 08:25 PM
#3 |
MotorcycleMayhem
Oddometer: 2,153
Drill bit or machined shaft to fit the hole to lock out the lash take up works as Kamanya states. One thing to keep in mind here is it is MUCH easier to put the lock pin in place while the gear set is mounted to the shaft than after the fact... Major PITA to reload the spring and then lock it out with the pin.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
11-22-2012, 10:26 PM
#4 |
Andrew to most
Oddometer: 1,111
