11-22-2012, 03:05 PM
#49246 | |
Pig Wrangler
Oddometer: 1,569
Lots of polished parts. Looking good!
11-22-2012, 03:38 PM
#49247 |
Recovering Lurker
Oddometer: 80
Sweet that post didn't get eaten
![]() Anywhos, after following tons of bike builds and looking at tons of bikes I loved the motoard look especially a few from the likes of Kubiak, ASF, XRmanu and Carlos/Zipper(some are xr600s and one is a 650R but eh art is art imo ). so the original plan was to dismantle the bike, move it to the basement upgrade the motor a bit and throw some 17s on it, that was 2 years ago . In those 2 years i have found a wonderful little gall whom I will call my mrs this summer and with that all my cash went buh buy but not before stumbling across this fellow over at TT in the DRZ ( you can find him here in one of the GS forums) named ebrabaek the guy makes great tutorial posts on DYI carbon fiber too were even my sorry ass could get a clue and pick up some of his technique. So with the mods out of control i started fabing sanding ect to were you see her today and still getting stuff done as cash trickles in. List o Mods Aesthetics Gas tank while not shown is a 4 gallon IMS also painted black (using casewell sealent on a brand new tank should prevent gas fume bubbling of the paint) Almost all the body plastic is as you see all going to be replaced by CF some is 100% custom others are just re pops from available parts. Seat will be a Guts cover black Suspension Front forks are off a 2000 CR250 will get new oil and seals before any spring or valve changes, think i will get rid of the gold and polish them as well Upper triple is a RSW lower is a stock CR. think i will shoot these in red Rear shock will be mostly black (not painting the threaded section) new oil with the stock spring in red Rear swing arm will be polished on the outside with the cast section and inside being painted black Front and rear wheels will be off a CBR F3 painted red with custom spacers Brakes Stock calipers and most components painted black Stainless front and rear brake lines Custom front rotor bracket polished Engine & Transmission J&E 10.5 piston DLC coated wrist pin (hope to help with the galling) FCR 40 off a 2003ish CRF 450 with adjustable leak jet Megacycle 173-12 camshaft with rockers, shortened guides and such DYI port job on the inake ports ( tryed like hell to mimic those old TT stepho pics but with no flow bench might of done more harm then good and if it does kill the flow all a better reason to save the penny's for a tricked out CW head )Oil cooler of some Suzuki i got on fleabay XR600 countershaft with associated kicker bits NX 2nd and hopefully the 5th gear (still working on getting my hands on one of those) RSK xring chain red 45 tooth rear with a XRR 15 tooth front FMF power bomb header with those nasty ass welds ground down and polished up Yosh RS2 muffler with a DYI carbon body Engine is painted in the picks but a shoty rattle can job has recently been blasted and will be getting a better coat of paint black of course Side covers again as pictured will stay polished. Electrical Koso instrument cluster Innovative L1 wideband ( I HATE trying to figure stuff out with only a butt dyno) Piaa sports horn TRX 400 EX headlights Led blinkers and tail light Turn tech 5.0 ah lithium battery As you can see there isn't much I'm not messing with and all most got all my parts together. Santa is bringing me the rest of the fork bits and a nice new hvlp gun so once that stuff arrives along with a 5th gear i can start some progress again.
lots of dismantled parts to a 2007 XR650L |
11-22-2012, 04:22 PM
#49248 | |
Recovering Lurker
Oddometer: 80
holy crap! for that kind of cash can pick up a older ktm 200 (closet 2 smoker fan as well ).
lots of dismantled parts to a 2007 XR650L Schultz! screwed with this post 11-22-2012 at 04:31 PM Reason: i kern splell |
11-22-2012, 04:30 PM
#49249 | |
Oddometer: 641
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack Sierra Thumper screwed with this post 11-22-2012 at 05:05 PM |
11-22-2012, 05:19 PM
#49250 | |
What Voyager trim? |
11-22-2012, 05:47 PM
#49251 |
Crazy Diamond
Oddometer: 726
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
11-22-2012, 09:23 PM
#49252 | |
Pig Wrangler
Oddometer: 1,569
I managed to get my grip heaters installed today. Never being one to leave anything alone, I decided that they needed improvement.
I wired a relay into the circuit so they are only hot when the key is on (I know I will forget and leave the toggle switch on ) and I ditched the resistor and wired in a turn signal flasher in its place. I had several extra flashers in the tool box, so I figured I would give it a try. After all, I read about it on the Internet, so it must work . The driveway test indicates that it does, indeed work! Hopefully tomorrow will yield a more thorough test.
11-22-2012, 10:46 PM
#49253 | |
Oddometer: 130
11-23-2012, 05:41 AM
#49254 | |
Oddometer: 2,765
Your skills are quite impressive! I love the dash, front fender/fork slider protection, the side panel/rear fender assembly.... SWEET!!!!!! This deserves its own thread.. Please keep the updates current? |
11-23-2012, 06:31 AM
#49255 |
aka FiddyK
Oddometer: 246
shultz - i've been looking at oil coolers from about 50 different bikes. can yo provide any pics of your oil cooler install?
thanks, and can't wait to see your finished product ![]() paul
2011 Beta 450 RR - plated ![]() 2008 Honda XR650L - gone but not forgotten ![]() |
11-23-2012, 07:26 AM
#49256 | |
XRated
Oddometer: 810
That rear fender is really nice as well, any chance you would be making some for sale??
11-23-2012, 08:30 AM
#49257 | |
Oddometer: 2,800
11-23-2012, 08:57 AM
#49258 | |
Pig Wrangler
Oddometer: 1,569
The resistor is famously fragile and also reduces the power to the heater by turning it into heat. So... you have to be careful where you put it. The flasher simply steps down the juice to the heater by cycling it on and off repeatedly. Besides... if you haven't figured it out yet. I have to try shit just to see if it works
![]() Fortunately that spirit of experimentation never found its way into other parts of my life (kind of hard to stay married it if did!) ![]()
11-23-2012, 09:00 AM
#49259 | ||
Pig Wrangler
Oddometer: 1,569
11-23-2012, 09:42 AM
#49260 | |
Recovering Lurker
Oddometer: 80
The oil cooler was the driving motivation for the low mount fender so i could mount it on the down tube with out interferance from A SM fender i had already made (any one want a CF re pop of a I think ufo super moto fender?). With were i have it mounted it will interfere physically and wont provide any airflow unless you chop the back side of your fender off. here are a few better pics ![]()
lots of dismantled parts to a 2007 XR650L Schultz! screwed with this post 11-23-2012 at 10:00 AM |
